Asus M2N68 & M2N68 PLUS
  • delta2k2
    • Mar 2015
    • 6
    • Romania
    Hello
    I have 2 motherboards , Asus M2N68 & Asus M2N68 PLUS.
    Both board running OK, BUT only whit old card on PCI slot.
    If I boot whit old PCI card , i can install SO, make other tests etc ... all is OK
    If i mount PCI Express video card, no boot, just beeps.
    I try :
    - different PCI Express video cards (nVidia & ATI)
    - bios update (whit old PCI card)
    - other RAM, power source
    Both motherboard have problem whit PCI Express slot.
    Please give some solution.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    • Romania
    Re: Asus M2N68 & M2N68 PLUS
    Tried setting the BIOS to boot using the PCI-E VGA card? There should be an option in the BIOS named "Primary graphics adapter". Check if that option is set to PCI-E VGA or PCI-E.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • delta2k2
      • Mar 2015
      • 6
      • Romania
      Already tried...
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Those boards of yours have the nForce 630a/GeForce 7025 chipset. There you have your problem. Reflow the Northbridge and the PCI-E will work again... for a few months that is.
        Only heat up the die in the center of the chip and not the whole package, as this issue has nothing to do with the solder balls, the chip itself is defective. Needless to say, it is absolutely not worth replacing.
        A working TV? How boring!
        • delta2k2
          • Mar 2015
          • 6
          • Romania
          I will try reflow ... tomorrow
          • delta2k2
            • Mar 2015
            • 6
            • Romania
            3 time reflow ... same result
            L.E.
            I rise up temp , reflow again, motherboard boot OK whit PCI Express card
            • delta2k2
              • Mar 2015
              • 6
              • Romania
              Just reflow and second board. Again, boot OK whit vga PCI Express card.
              Reflow at 430 C , 30 sec
              Thanks for help
              • Dan81
                SNES-powered
                • Oct 2013
                • 1865
                • Romania
                Maybe with good cooling those chipsets will survive?I've seen people put some big heatsinks and fans on nVidia chipset boards (anything over nF4) so maybe it helps cooling down the chipset?
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  On a desktop motherboard you have better chances of keeping them alive, indeed. If the nForce chipset is kept under 60C there are good chances of it running fine for 1 year or more.
                  • lbwlow
                    • May 2015
                    • 125
                    • Malaysia
                    I owned this particular model before (M2N68), in my opinion, Asus is using low quality pcie slot or faulty component maybe. I was using a Geforce GT210 at first, after few attempt of changing cpu case, which require me to remove the graphics card for a few time, then it started to not detecting my cards. I have tried a lot of cards with this motherboard, 9600GT (i have 3 of it), X1300XT, HD2400XT and all of it won't detect and give display. But the miracle was, it will detect my MSI 7600GS no matter what, even if I plug in the card half way, it still can detect it and give display, my guess was the 7600GS pcie connector was slightly thicker than others, because when I slotting in the card i can felt more tightness than other.
                    And btw, this board is very picky with ram as well, with my 7600gs in, it won't give me display if i was using Kingmax ram.
                    • jtctolits
                      • Jul 2010
                      • 10
                      nvidia.....again
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • trbovan
                        Asus GL731GT Boot loop
                        by trbovan
                        Laptop is a GL731GT with the I7-9750h and GTX1650.
                        Full model number is gl731gt-rb71-cb
                        Serial: (placeholder for when I get home)
                        Board model: G531GT REV. 1.5
                        Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
                        I assembled and tested anyway. The bios worked, I was able...
                        10-04-2023, 07:27 AM
                      • jrodefeld
                        Asus laptop won't boot (no power) - possible bad caps?
                        by jrodefeld
                        I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                        The model:
                        Asus Zenbook Pro Duo UX582L
                        I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                        However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                        09-02-2024, 04:55 PM
                      • acata
                        Asus X450LC REV 2.2 can't boot to anything
                        by acata
                        I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                        Power on normally. Boot to bios ok.
                        But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                        10-10-2023, 05:15 AM
                      • futadmytro
                        Asus g713qm-es94 stuck on boot bios problem
                        by futadmytro
                        sn^M4NRKD02753616E
                        MB- g533-6050a3250201-MB-A03
                        Stuck on boot after ROG logo, did not enter to bios
                        In flash bios , laprop boot but have video issue
                        orig bios...
                        06-25-2025, 08:07 AM
