P5GC-MX/1333's Atheros L2 network weird problems
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Acquired this motherboard as dead / stopped working one day - got it going by reflashing its BIOS chip
    Everything seems to be working, except on-board Atheros L2 network
    Testing with XP, tried all drivers from Asus download
    Also tried what I believe is very latest driver for XP, v2.5.7.16 from an ECS download - same version number as letting Windows update do its thing
    Problem is IP address will be allocated by some modems, but cannot Ping gateway address, much less connect to it with browser
    By some modems, I mean I've tried four different modems - some will not even assign IP address
    Modem I settled on for testing is Thomson TG782T updated with latest firmware
    Also cannot Ping if I assign IP address to Atheros, taking DHCP out of equation
    Have tried plugging in PCI SMC EtherEZ network card, making two network connections available - and if LAN cable plugged into SMC, no problems
    Also tried different LAN cables
    Finally tried downgrading BIOS to oldest available version for download, seeing third latest version mentions a fix for PXE problems
    Before giving up on Atheros, tried board with Windows 7
    Surprised to find it worked perfectly - also worked perfectly with Linux Mint 17.1
    - what's with XP and Atheros L2 ?
    Anyone have any insights ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: P5GC-MX/1333's Atheros L2 network weird problems
    FWIW, I tried it with Vista, which also does not have Atheros L2 support built-in
    Used the same ECS driver Zip as above, and Vista worked perfectly too
    Pity XP won't accept, or be forced to accept, the NDIS 6.0 driver applicable to Vista
    Seems to me there's a fundamental problem with the NDIS 5.1 driver applicable to XP
    Does anyone have an Atheros L2 NIC working with XP ?
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I've had this issue with this board. There is nothing wrong with your OS. What did you update the BIOS to, 413? I had this same issue until I updated the BIOS. I had to use a floppy disk to update the BIOS since the BIOS update utility was not working for me.
      • mockingbird
        • Dec 2008
        • 5488
        As Pentium 4 said, use the latest BIOS 0413. It has Atheros OROM 1.0.20.20.
        The latest one is 1.0.20.22, but I couldn't replace it, because Asus used some sort of shrunken down version for this BIOS, and there isn't enough room for the stock OROM from Atheros.
        If you really want 1.0.20.22, I can replace it, but the only way to get it to fit is by removing some old microcodes.
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          I started this saga with BIOS 0413, which is what I used to recover the board in the first place
          Then downgraded to 0207 after encountering LAN problems with XP
          I update BIOS from a USB key booting with DOS
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Figures doesn't it - Attansic (Atheros) was a majority owned subsidiary of ASUSTek Computer
            What gets me is all the drivers I've tried are WHQL certified - what's necessary to get certified, pay M$ a fee ?
              • 31304
              blame M$ for using the bios, it should contain whatever it needs like linux does.
              • mockingbird
                • Dec 2008
                • 5488
                Here you go. Try this combination of BIOS and driver, option rom 1.0.20.22 and Driver 2.6.7.17 (XP x86). Both are included in the zip.
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  Thanks for your effort
                  Unfortunately no change with XP Pro - even did a clean install, to be 100% sure
                  Vista still works though
                  • Calchaqui
                    • Oct 2005
                    • 112
                    pfrcom. What do you think was the cause of the first owner bad bios chip? , a mistake bad-flash or bios just got corrupted?
                    What kind of mounting has the Athero chip? BGA?
                    I LOVE WWW.BADCAPS.NET
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      I believe it just didn't work one day, so, BIOS just got corrupted - original owner gave me the board after buying a replacement P5B from me
                      Not BGA, the older type with fine leads from all four sides of the chip
                      • mockingbird
                        • Dec 2008
                        • 5488
                        That's called a quad flat pack or QFP...
                        I'll see if I can replace it with an even newer Atheros OROM. IIRC, Atheors L2 can take the newer OROMs, unlike Atheros L1, which is a legacy PCI chip.
                        • davg
                          Home network connection problem
                          by davg
                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                          03-06-2021, 07:13 AM
                        • japlytic
                          Maximum speed should be marked on network ports
                          by japlytic
                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                          12-19-2024, 05:04 PM
                        • hikomalek
                          SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                          by hikomalek
                          Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                          When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                          Transformer:
                          |Info| Primary | Aux | AB | CD|
                          |Ratio|1|25|40|12|
                          |Voltage AC|230V|9.2V|5.8V|19V|
                          |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                          I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                          09-19-2025, 03:30 AM
                        • howardc64
                          Samsung UN55JU650DF network/streaming problem
                          by howardc64
                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                          07-09-2025, 12:44 PM
                        • jean luc ferre
                          laptop hp g72 b52sf screen problems
                          by jean luc ferre
                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                          06-07-2025, 03:27 PM
