Just last week, December 23, 2004, my K7S5A V1.x died. Upon further investigation I discovered the following:
!! BAD CAPS !!
I received an ECS K7SEM with the same "GLUXON" capacitors in the power section of the mainboard. So far the GLUXON brand capacitors have proven themselves to be hit or miss in quality. Hind sight is 20/20, I should have checked my K7S5A...so my loss is now your gain in knowledge.
As a result the power section of the board destroyed itself, the FET's are destroyed, pieces have literally exploded off of their packages. Catastrophic failure.
This is just a heads up to fellow K7S5A owners. If you mainboard has the GLUXON brand capacitors try to have them replaced by a competent technician.
MD
!! BAD CAPS !!
MD
The 3 double-diodes were good. Some of the smaller caps around were destroyed from the heat.
I've downloaded the datasheet and compared the most important parameters (is logic level?, RDS(on), Id) with mosfets found on boards in my junk pile. The ones I used were from dead Abit KT7A board. They're better than original mosfets (lower RDS(on) -> less heat, higher Id). High quality mosfets like these can be expensive and hard-to-find - and I have a lot of irrepairable boards with them
