Gigabyte GA-K8VM800M recap worked but now dead?
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 662
    • samsara
    Thought I'd try out a 64 bit motherboard
    It's very tidy with no scratched traces
    I recapped this motherboard's input and output VRM caps (previously had bloated output caps) with new HM's.
    And after a few days of it running nicely, just when i had nearly finished with sorting out a dual boot, it packed a sad.
    What happens now is this:
    When the wall socket switch is turned on, the computer starts immediately.
    Then it makes a long high pitched beep followed by (a few seconds later) a long low pitched beep then nothing more (not repeating).
    Using the computer power button, the machine can be powered down (and also restarted after pushing it again).
    I have removed the board from the case, disconnected all periphial devices and IDE cables - same result as above
    Tried another CPU - same result as above
    No video display from either the onboard video or the AGP video card (when inserted)
    Tried another PSU - no difference
    Tried different RAM/slots - same result
    Removed all RAM - get correct repeating beep code for missing RAM
    Seems that the Award BIOS is at least partly OK
    Any idea what to look for next?
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Gigabyte GA-K8VM800M recap worked but now dead?
    Sometimes Nichicon HM is not quite low enough ESR replacements. Try resoldering/ reheating the caps just incase of a cold or incomplete joint exists somewhere. It is easy to see the solder on the bottom of the board but not on the top being covered up by the caps bung.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Hm should work fine for a motherboard, check that they are all soldered properly including polar direction and the actual solder joints.
      • Sparkey55
        • Jan 2010
        • 1523
        Some of Gigabytes motherboards require much lower ESR values than HM series. Especially the VRM outputs. Also we do not know exactly what he replaced the original caps with. Real or fakes? Also some socket 754 boards a finicky about the DDR choices. A lot yet to be confirmed.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          I think we need pictures?
          Correct type of ram DDR less the 2gb 2.5V ?
          Reset the cmos?
          Plugged in the 12v 4pin lead
          • c_hegge
            • Sep 2009
            • 5219
            Disagreed. Almost all Gigabyte boards with lytics originally came from the factory with either Nichicon HM or an equivalent (NCC KZG, Sanyo WG, Ruby MBZ). I've never seen any gigabyte board with lower ESR caps than that.
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 662
              • samsara
              Thanks,
              The original caps were HM's - 3 X 1500uf input, and 3 X 3300uf output, so they are exactly the same.
              Thought that i did a tidy job of the soldering - no dry joints/solder splashes
              Yes,
              Correct polarity
              Reset cmos
              Replaced battery
              4-pin 12v connector plugged in
              Correct RAM
              It was running OK for a couple of days
              Just rechecked continuity on the end of the cap leads (where they were snipped)
              The ouput caps all test to be connected in parallel as they should be, and likewise for the input caps.
              So, therefore the solder joints are all good
              Also, both fans are spinning (cpu and sys)
              Any more thoughts?
              • Sparkey55
                • Jan 2010
                • 1523
                You can disagree with me all you want. It still does not change the fact that I have seen a few with my own eyes original factory equipped motherboards from Gigabyte with lower esr ratings than Nichicon HM series.
                • Sparkey55
                  • Jan 2010
                  • 1523
                  Originally posted by socketa
                  Thanks,
                  Yes,
                  Correct polarity
                  Reset cmos
                  Replaced battery
                  Correct RAM
                  Any more thoughts?
                  http://pcsupport.about.com/od/fixthe...beep-codes.htm
                  http://www.bioscentral.com/beepcodes/awardbeep.htm
                  You could have something wrong with either the CPU, the socket, the fan not reaching a high enough RPM, the fans RPM sense wire not outputting a reading or a bios setting related to overheating thus shutting down the motherboard.
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    Thanks,
                    Yes,
                    Correct polarity
                    Reset cmos
                    Replaced battery
                    Correct RAM
                    Any more thoughts?
                    Also I have seen and expirenced SOME Gigabyte boards that develop warpage causing the ram modules to not completely seat into the slots even though they will lock in place. This is due to the placement of the memory slots in relation to the cpu socket heatsink retention mechanics.
                    • socketa
                      Asbelowsoabove
                      • Jun 2014
                      • 662
                      • samsara
                      yes, had previously spent quite some time searching pages of award beep codes.
                      And note that the high/low tone is documented as repeating, whereas mine does not repeat (waited for 5 minites)
                      (note that both of those links use the word "repeating").
                      The CPU is not the problem because i tried another one, and still the same result
                      Last time the computer was running the bios was reporting the fan speed with no warnings
                      What i am slightly suspicious of, is that when i first got the board, after recapping it, it was not working, so i removed the heatsink and forgot to twist it off, hence pulling out the CPU without lifting the CPU lever.
                      Anyway, after that i stuck it back in, reapplied thermal paste and it worked with no problem.
                      Then a couple of days later it's playing up.
                      I've reinserted the CPU's several times, and still no joy.
                      Also neither CPU just falls nicely into the socket, a slight push on one corner is required to pop either of them in.
                      Seems that the bios is seeing the RAM, because when i remove both sticks i get a No-RAM beep code
                      • Sparkey55
                        • Jan 2010
                        • 1523
                        You could have damaged the cpu socket when pulling the cpu out while the locking mechanism was in place. I have done that myself but I got lucky and did not damage either.
                        • socketa
                          Asbelowsoabove
                          • Jun 2014
                          • 662
                          • samsara
                          Thought that i got lucky also
                          So what now?
                          It looks like the Bios is seeing the CPU, because when i remove the CPU and switch on the PSU, and the mobo automatically turns itself on (i can't remember it doing that before when it was working - shouldn't the computer power switch determine if the compuer turns on or not?), i get no beep codes.
                          • Sparkey55
                            • Jan 2010
                            • 1523
                            So what now?
                            That is normal reaction. With no cpu detected the post sequence is early in count and will not advance to the alert loop.
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              The cpu should not need any force to align with the socket, it should drop in. Check for bent or misaligned pins on cpu.
                              • Sparkey55
                                • Jan 2010
                                • 1523
                                Some advice on using TIM. Apply a small amount of thermal grease in the center of the cpu's IHS. Then insert the heatsink straight down on top of the grease to evenly spread it outwards. DO NOT TWIST the heatsink when doing this.
                                • Sparkey55
                                  • Jan 2010
                                  • 1523
                                  If the heatsink does not want to lift off easily do not twist it. Carefully put a screwdriver edge between the bottom of the heatsink and the outer hard plastic retention base that surrounds the socket and then gently pry the heatsink up. You may need to do this at two opposite corners.
                                  • socketa
                                    Asbelowsoabove
                                    • Jun 2014
                                    • 662
                                    • samsara
                                    Thanks again,
                                    Will remember that trick for next time.
                                    Yes, there was some slightly bent pins in the original CPU (i bent them when lifting the CPU up from one side because it was stuck a bit in one corner of the socket) and i straightened them up.
                                    On the replacement CPU there is no bent pins.
                                    I've tried both, with same result.
                                    I don't think that the CPU is the problem
                                    Both CPU's go down all the way, after a gentle nudge in the corner.
                                    • Sparkey55
                                      • Jan 2010
                                      • 1523
                                      Thanks again,
                                      Okay, a slite detour. Where did you get the caps to replace the bad ones from?
                                      • socketa
                                        Asbelowsoabove
                                        • Jun 2014
                                        • 662
                                        • samsara
                                        One of the major reputable suppliers like digikey, forgotten which one exactly - not ebay
                                        They are not fakes
                                        Date code H1316
                                        Had them in storage for a few months
                                        The mobo was working without a problem for a couple of days after they were used to replace the bad caps
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                        • Prott
                                          Gigabyte GTX1080 - identifying a dead short on vmem
                                          by Prott
                                          Hey!
                                          I have a problem with Gigabyte Aorus 1080. The card seems fine (expected resistance on vcore, pex, 5v, 1.8v, 12v and reset) except for a dead short on vmem (FBVDD). It's interesting failure mode, cause usually (in my experience) when memory fails it still retains a few ohms - this one is literally a dead short.
                                          I removed the inductors and tried inject voltage (0.8 V at 6 A) which only seemed to warm up the cables to the card while the card itself didn't show any hotspots.
                                          Is there any way to narrow down the search for a short? I would prefer not to remove...
                                          07-04-2023, 06:29 AM
                                        • JimMc0
                                          Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
                                          by JimMc0
                                          Hi there,
                                          I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
                                          The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
                                          03-27-2024, 08:36 AM
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
