Intel D915PBL
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Intel D915PBL
    Hi
    What are the views of the forum members as to cap replacement on this mobo?
    I should add it is not failing (so far...) and I intend to work this up for production use.
    From a physical inspection, I have found the following;
    5 of KZE 16V 1200uF 10mm dia, Height 25.4mm, 105 deg C
    3 of MCZ 10V 1000uF 10mm dia, Height 15mm, 105 deg C
    8 of SME 6.3V 100uF 5mm dia, Height 10mm, 85 deg C
    16 of SMG 10V 470uF 5mm dia, Height 10mm, 85 deg C
    12 of Nichicon 25V 100uF, 5mm dia, Height 10mm, 85 deg C
    4 of Nichicon 25V 220uF 7.5mm dia, Height 10mm, 85 deg C
    1 of Nichicon 16V 470uF 7.5mm dia, Height 10mm, 85 deg C
    1 of Rubycon 6.3V 220uF 5mm dia, Height 10mm, 85 deg C
    2 of Rubycon 25V 22uF 3.5mm dia, Height 10mm, 85 deg C
    The ALU (presumed solid) caps are;
    8 of can size 10mm dia, Height 10mm - marked as 452 SEPC 560 4
    1 of can size 10mm dia, Height 15mm - marked as A 4DT 560 4V
    Any advice, help and insight - greatly appreciated
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Intel D915PBL
    imho its fine
    - intel are usually using 85oC caps in non critical areas of the board.
    - i guess you have a full row of polymer caps ie oscon sepc and chemicon psa by the cpu
    - the nichicon affected were only 105oC HN and HM series and yours are 85oC I guess they are VR or something.
    - some chemicons, some rubycons
    what more you want? attach a seasonic to it and ur good to go
    • starfury1
      • May 2006
      • 1256
      Re: Intel D915PBL
      well the others round here are bit more familiar with the brands and series's
      Since (except for the polymers, I dont know) they all look like good brands I would say that they should be fairly ok for a reasonably long life.
      SMG SME not sure on them. (possible a GP from the same stable as KZE)
      the 85 C caps are most probably of the General Purpose variety and that fine if being used in those types of positions
      The caps that usually cop the worst workout are the VRM caps
      (and probably thats were the polymers are being used)
      Fromm what I understand 470uf and below you don't need to worry about
      I suspect since the caps are of quality they are being used in the right positions for there intended purpose, so you should have no dramas
      I am of the opinion if its works Id leave it alone
      but yeah there is alway room for improvement and I am not 100% sure on this
      so lets see what others think
      Cheers
      Are will you bet me but yeah...me too.... think it will be fine
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Intel D915PBL
        hehehe i hate it when that happens to me or even worse to end up on the next page all alone
        its not really an overclocking board.
        but if we consider anyway, one thing that could be done is replace
        which are probably on the 12v in, with a lower esr brand.
        difficult to say about the rest without seeing a diagram. but yeah i dont think its worth messing with a decent set of caps unless its some balls to the wall overclocking project
        • JEWilson
          • Sep 2007
          • 369
          Re: Intel D915PBL
          Eventually got round to replacing the +12V rail caps in this mobo.
          I'm frustrated on, of all things, the last cap on the positive pole which refuses to come out of this mobo.
          When I was removing the KZEs, I used a technique where first,
          the negative pole was lifed a bit, then the positive, then the negative
          and so on until the caps come out.
          I always use this technique for removal.
          The last cap (isn't it always) pole on the positive side refuses to budge and
          now I'm in a position where a fragment of the cap positive pole is left in the
          via remains and will not come out!
          I've tried solder braid, needle method, solder pump - nothing works!
          Any suggestions? I do not want to damage the mobo.
          • Super Nade
            • Jun 2006
            • 294
            Re: Intel D915PBL
            I would suggest a generous dab of solder to get the leg out. The hole can be easily cleaned if it is filled with solder as opposed to a thin layer blocking the center of the hole.
            Q6700 @ 3.6 GHz
            Zippy GSM-6600P
            Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
            Abit IP35Pro
            ATi HD4870
            • gdement
              • Jan 2007
              • 690
              Re: Intel D915PBL
              Yeah, when that happens I just melt the solder and pull the leg out with pliers. Add more solder if you can't get it to melt.
              • Super Nade
                • Jun 2006
                • 294
                Re: Intel D915PBL
                And, do not yank out the legs, odds are you will rip the thermal pad out as well..
                Q6700 @ 3.6 GHz
                Zippy GSM-6600P
                Abit IP35Pro
                ATi HD4870
                • JEWilson
                  • Sep 2007
                  • 369
                  Re: Intel D915PBL
                  I been here before - you need to be patient to do this without damaging
                  the board
                  Just a thought - it may be my iron is a bit cold. Never had a problem before though.
                  I've seen Willawake details use of temps for cap removal and cap replacement
                  I use a 50W Antec TCS at the mo. It is wired but you can adjust the
                  temp from 200 to 450 C +/- 1 %.
                  What temps are acceptable? Would like to make sure.
                  • Super Nade
                    • Jun 2006
                    • 294
                    Re: Intel D915PBL
                    Just make sure your tip is big enough. Fine pointy tips don't work as well as a chisel tips.
                    Q6700 @ 3.6 GHz
                    Zippy GSM-6600P
                    Abit IP35Pro
                    ATi HD4870
                    • JEWilson
                      • Sep 2007
                      • 369
                      Re: Intel D915PBL
                      Ok
                      Patience has been exercised and the cap removal for the final
                      problematic one has been resolved! - yeh.
                      Q - whereas most modern boards are built to a cost, esp. with
                      caps, what of the case where caps silk screen show cap
                      placement and have associated vias but are left unpopulated?
                      As example, this particular mobo had room, for what I believe to
                      be for two more OSCONs at the CPU VRM. I knew this as;
                      1. They were physically located at CPU VRM and
                      2. They were electrically in parallel with the other OSCONs in situ as well as;
                      3. They silk screen decals re - cap numbers were the same series.
                      So far as that was the case for the OSCONs, I added another Panasonic FM
                      16V 1200uF to the +12V rail over and above the former 5 KZEs
                      as the mobo, again, could cater for this give the three conditions above.
                      Is there any inherent danger in doing this?
                      • davmax
                        • Dec 2005
                        • 899
                        Re: Intel D915PBL
                        I am curious how the Oscons have surfaced, not in the original list.
                        Extra caps can be inserted without any real hazard. All parallel connected caps share ripple current therefore should be of the same part number so that sharing is at best. I note that you added an FM with KZEs.
                        Oscons are recommended to be replaced.
                        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
                        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
                        160Gb WD SATAII Server grade
                        Nvidia 8500GT 256Mb
                        160Gb WD eSATAII Server grade for backup.
                        Samsung 18x DVD writer
                        Pioneer 16x DVD writer + 6x Dual layer
                        33 way card reader
                        Windows XP Pro SP3
                        Thermaltake Matrix case with 430W Silent Power
                        17" Benq FP737s LCD monitor
                        HP Officejet Pro K5300 with refillable tanks
                        • JEWilson
                          • Sep 2007
                          • 369
                          Re: Intel D915PBL
                          Perhaps I was not clear - sorry bout that
                          There were 5 KZEs on the +12V rail.
                          There was room for another but this was not populated on the mobo.
                          Therefore, replaced 5 KZEs with 6 Panasonic FMs - same values
                          I was of the opinion, the Alu OSCON SEPC 560uF 4V were good caps.
                          These are supplied by Sanyo. See further;
                          http://www.edc.sanyo.com/english/pro...n/outline.html
                          These was originally listed as 8 Alu caps at CPU VRM.
                          As a further two caps were made available but were not populated,
                          I added a further two Alu OSCON SEPC 560uF 4V.
                          I replaced the Alu A 4DT 560 4V cap beside the PCI-Express slot
                          with a further Alu OSCON SEPC 560uF 4V
                          Thanks for the advice on populating free (linked) vias
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: Intel D915PBL
                            I'm not 100% clear on what you are doing but here are some comments.
                            Panny FM are rated for higher ripple and are lower ESR that KZE by a good margin so you might have gotten away with using 4 FM's.
                            (You went in the safe direction though so don't worry.)
                            They don't usually mix OSCON and Electrolytic in parallel with each other.
                            If you are putting those 4v OSCON on any voltage greater than 4v they are going to live a very short life. Possibly minutes.
                            The unoccupied cap positions are left over from the reference (design) board.
                            After they build and test the prototypes they may decide the other caps aren't needed but they don't change the PCB.
                            There are a few valid reasons they will leave them there.
                            It costs money to re-do the silk screens and reprogram the CNC machine that drills the holes in the PCB.
                            It leaves them more options in parts procurement.
                            It leaves the board open to later revisions that might support faster CPU's (that will need more caps) without re-engineering the PCB.
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • davmax
                              • Dec 2005
                              • 899
                              Re: Intel D915PBL
                              My mistake. Oscon are perfectly fine. Mistook for a bad brand starting with O.
                              Nvidia 8500GT 256Mb
                              33 way card reader
                              Windows XP Pro SP3
                              • JEWilson
                                • Sep 2007
                                • 369
                                Re: Intel D915PBL
                                PCBonez
                                Agreed - I was aware of the reasons why mobos are produced this way
                                Just a check with other forum members views
                                As to the matter of recap
                                The OSCONS and lytics are not in parallel, perhaps I did not make this clear
                                Apologies
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Re: Intel D915PBL
                                  Just an FYI: The SME and SMG are chemi-con 85c caps.
                                  SME is discontinued and was replaced by SMG
                                  - Dr Seuss
                                  • JEWilson
                                    • Sep 2007
                                    • 369
                                    Re: Intel D915PBL
                                    Ok,
                                    Finally got round to firing this board up.
                                    News - it powers up ok and I am currently testing memory.
                                    Note I am running Memtest 86v3.3 in VGA mode.
                                    Running test 5 and 8 for 20 iterations.
                                    One issue however.
                                    The graphics display and screen have tinged the formerly, white text, green.
                                    The PCI-E adapter is an R37L-SC3B 128MB Graphics (ATI X300 based).
                                    As I recall from my basic TV servicing, green tints are a sign of ripple distress
                                    with a CRT.
                                    I'm running the screen from the vga port of the adapter.
                                    So far as I have recapped this board as described, would that project
                                    necessarily effect the CRT or, alternatively, is it a sign the adapter is
                                    about to give out?
                                    Any advice/insight appreciated - thx
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: Intel D915PBL
                                      Take a look at the caps on the video card.
                                      They go bad too.
                                      Does the monitor work properly on another system?
                                      If not it may be the problem.
                                      Verify that your monitor is compatible with the frequency settings the card is running at. [Not usually a problem since plug'n'pray but once in a while it happens.]
                                      - Dr Seuss
                                      • JEWilson
                                        • Sep 2007
                                        • 369
                                        Re: Intel D915PBL
                                        Must be the CRT or the vga cable as the mobo and graphics adapter
                                        work ok with another CRT
                                        • DrewPhillips
                                          Capacitor Diarrhea - Nichicon PL Series
                                          by DrewPhillips
                                          Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                          The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                          03-02-2025, 10:18 PM
                                        • nick3092
                                          Mid/late 80's Nichicon Yellow Caps
                                          by nick3092
                                          I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                          08-28-2022, 03:56 PM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • ssl6
                                          MSI K7T266 Pro (Ver. 1.0)
                                          by ssl6
                                          Hey Everyone,
                                          Long time lurker, but I think this is my first time posting.
                                          Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                                          I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                                          11-09-2023, 01:00 PM
                                        • chth96
                                          Is there datasheet for nichicon LXJ series?
                                          by chth96
                                          I want to calculate capacitor ESR referring to below guide.
                                          https://forum.digikey.com/t/calculat...-from-tan/2633
                                          I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                                          I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                                          Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                                          11-20-2022, 08:11 AM
