hey everybody. i just recapped my epox 8k3a board and now its not posting. does anyone have any experience as to what i can do to fix it? its my second recap of this board, first time i recapped i scavenged gsc's (had nothing else on hand and a thin wallet) off an older epox and it rocked for about a year. they bulged and started having spontaneous power down issues under heavy load (WoW). this second time around i replaced all the 10v 2200uf caps with mallory's and its a no go. board posted just fine before i pulled the gsc's out. tried the wonderful reset trick and cleared cmos. sorry i have no pics at the moment. caps i bought were allied stock number: 852-6504. im thinking they might not be good enough for pc mobo use... any ideas?
Help on epox 8k3a recap, no post
Tags: None
Re: Help on epox 8k3a recap, no post
Umm, are they even LOW-ESR?
They need to be... Contact Big Pope if you're outside the US or Topcat if you're in the US if you have troubles sourcing caps..."The one who says it cannot be done should never interrupt the one who is doing it." -
that was what i thought too.. i have recapped a 8k3a before, the ones at vrm output (near proc) are gsc 2200 6.3v and else are gsc 2200uf 10v..
my guest is your mallorys aren't low esr enough for the board to function properly.. though have to look at mallorys caps datasheet for sure..days are so short when you actually do something..Comment
what esr rating should i be looking for, for said value caps? when i bought the caps that i did, i picked the lowest esr ones in the list which was 0.14Ohm.Comment
Edit for above: I think I see my issue, the Mallory caps are SK series which are labaled general purpose caps. I would still like to know, however, the esr rating I'm looking for to get this board working. It's the most stable board I've ever had even after tweaking every freakin setting in CMOS. I'd hate to see this board get the axe. I had an Asus A7S333 previously, yuck. The reset button was my only friend on that piece of crap.Comment
i personally will only recommend japan caps or samxons for recapping..
i suggest you not to take caps with higher esr than panasonic FC or nichicon PW as i know they at least will works.. that means caps that you need shouldn't be higher than 45-60 ohm esr.. (that's only my general rule of thumb). caps on vrm output are even should be much lower esr for optimum use (panasonic FM, ruby MBZ, sanyo WG etc), but i think caps like panasonic FCs or nichicon PWs will do if you push it..
2200uF 10mm 10v Caps
2200uF 10mm 6.3v Caps
just to give you the example (esr ~ impedance):
taken from "Comparison tables between 5 major Japanese Low ESR capasitors"
https://www.badcaps.net/forum/showthread.php?t=1822Last edited by yanz; 08-22-2007, 02:31 PM.days are so short when you actually do something..Comment
It's the most stable board I've ever had even after tweaking every freakin setting in CMOS.i still have one 8k3a running to this day with tbred 1700 @ 2ghz running FAH..
caps that i ever use for 8k3a boards : panny fc, sanyo wg, ucc lxz, ruby mbz. they all works. at least good enough..days are so short when you actually do something..Comment
Any cap in the region of 0.0xxOhm is considered a low esr cap.
For boards i think it should be below 0.050Ohm, depending on the design and total number of caps.
Generally, i would not recommend doing repeated recapping of a board, as you can`t do it unlimited times.
I am not sure, if your problem is really caused by the higher esr, in think it is more likely, that there is something damaged caused by repeated soldering.Comment
Originally posted by gonzo0815Any cap in the region of 0.0xxOhm is considered a low esr cap.
but i have seen several vp6 with marginal caps not bulging at all where the vrm would shut down.
get the right parts and do over. take care to get em in right.Comment
Originally posted by yanzthat means caps that you need shouldn't be higher than 45-60 ohm esr..it's typo, i mean 45-60 mili ohm, my bad..
boards for p4 or amd k7 need very low esr caps for their vrm.. but depends on design like what gonzo said
check also the page that willawake created:
Tips after a Failed Recapping
http://www.capacitorlab.com/failed-recapping/index.htmLast edited by yanz; 08-24-2007, 12:05 PM.days are so short when you actually do something..Comment
When I have to time to do some digging on some caps, I'll check with you guys when I find one I think will work before I make the order. Thanks for the helpComment
ok, found some rubycon mcz's. problem is i cant find a 6.3V @ 1500uF, only 1200uF or 1800uF. Which do you think I should choose? I'm guessing the bigger one as I have a little overclocking in mind. I bought the mobile version of my processor so its unlocked from AMD and doesn't consume as much power.Comment
i just put an order for the new rubys. theyre comin overseas, so it could take a while to get them. ill let you guys know how things turn out. thanks a lot for your help guys.Comment
I got MCZ's in and its a no go either. It's got me stumped and bummed a bit. This is the third try at getting this thing to work. I've looked the board over and couldn't spot anything wrong except one square lifted at the corner but most of it was still intact and I got it soldered down. Any ideas? All the components are known to be working. Tried 2 cpus, 2 vid cards, and 2 psus. It's a great board and don't want to have to part with itComment
can i get a clear picture of an mcz in case i got ripped off? thanksComment
well i broke down and bought a new board. the exact same onethanks for your help guys
got a new old 8k3a board. its got a pooped 1500 cap but no biggie. posted right out of the box. got 5 caps changed so far, half a million to go. i think this board is better than my last one though. it overclocks fsb really well compared to the last one, though the cpu vrm teapos are still in good condition unlike the last one had (maybe last was a bad egg/damaged?). i dont see much point in waiting for them to blow, so out they go.Comment
All is well with the new 8k3a. 23 caps changed to mcz. Old ones were GSC and Teapo. It overclocks decently, but heat is now my issue, 140 degrees is not cool. I'd love to get a peltier on it, but that's for another timethanks for all the help guys
Is there anybody here who could tell me what are the two caps marked bellow? Or atleast send me a picture of those two caps from their board. Size wise I think those will be 2200uF10v, the same as in the CPU VRM, but not sure.... -
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by momakaI've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
This one was actually suggested to me by ChaosLegionnaire.... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
What I've tried so far:
replace the original N-MOSFETs with beefier 60V ones for testing
Resolder the resistors near the Vcore Jumper block
Short Vcore...05-25-2025, 01:46 AM - Loading...
