Comparison tables between 5 major Japanese Low ESR capacitors
  • yanz
    • Nov 2004
    • 910
    I have developed below, comparison tables of the characteristics of 5 major Japanese Low ESR capacitors which i hope you find useful for ease of comparison instead of referring to the PDF technical data sheets.
  • yanz
    • Nov 2004
    • 910
    Re: Comparison tables between 5 major Japanese Low ESR capasitors
    Direct links to the tables
    Sizing / Capacitance of each manufacturer's series
    Chemicon | Nichicon | Panasonic | Rubycon | Sanyo
    Complete List of the tables:
    1000uF & 1200uF Caps
    6.3v 8mm 10mm
    10v 8mm 10mm
    16v 8mm 10mm
    1500uF & 1800uF Caps
    6.3v 8mm 10mm
    10v 8mm 10mm
    16v 10mm
    2200uF Caps
    6.3v 8mm 10mm
    10v 10mm
    16v 10mm 12.5mm
    2700uF Caps
    6.3v 10mm 12.5mm
    10v 10mm 12.5mm
    16v 12.5mm
    3300uF Caps
    6.3v 10mm 12.5mm
    10v 12.5mm
    16v 12.5mm
    3900uF Caps
    6.3v 12.5mm
    10v 12.5mm
    16v 12.5mm
    • yanz
      • Nov 2004
      • 910
      1000uF & 1200uF 8mm 10v Caps
      • yanz
        • Nov 2004
        • 910
        so far so good...
        1000uF & 1200uF 10mm 10v Caps
        • yanz
          • Nov 2004
          • 910
          1500uF & 1800uF 8mm 6.3v Caps
          • yanz
            • Nov 2004
            • 910
            1500uF & 1800uF 10mm 10v Caps
            • yanz
              • Nov 2004
              • 910
              1500uF & 1800uF 10mm 16v Caps
              • yanz
                • Nov 2004
                • 910
                2200uF 10mm 6.3v Caps
                • yanz
                  • Nov 2004
                  • 910
                  2200uF 10mm 10v Caps
                  • yanz
                    • Nov 2004
                    • 910
                    2200uF 10mm 16v Caps
                    • yanz
                      • Nov 2004
                      • 910
                      3300uF 10mm 6.3v Caps
                      • yanz
                        • Nov 2004
                        • 910
                        Well, after 6 hours nontsop working on this, i give up. That's as far as my blood (& eyes) could go , honestly it took tons of drink to complete them. And im not satisfied yet with the result. A scripted webpage would be more excellent...
                        At 1000uF range, diameter of the caps became less important as they are easy to obtain at 10mm and 8mm. So it would be simpler and more compact if I include the 8mm and 10mm at the same table.. But that can not do, i have to keep my table consistent.. doh!!
                        Comments are always welcome..
                        to be continued..
                        • PeteS in CA
                          • Aug 2005
                          • 3583
                          • USA, Unsure of Planet
                          Yanz, you've done a lot of work! I would suggest grouping the caps by similar performance rather than by vendor. Since many vendors' have series whose specs are very, very similar (e.g. KY and HE, or LXZ and PW), users of your chart could both see what is available for a specific value and voltage, and the grades of performance.
                          PeteS in CA
                          • yanz
                            • Nov 2004
                            • 910
                            Thanks! Yup, you are right. That gives me an idea of how the data would be useful for they who need it.. The work is still far from finish.
                            Altough i have done a caps comparison by performance, let me think again how to put the data in the table. I ask to myself: should I use one table or several tables.. or no tables at all just links to them. What is the easiest arangement so it can be read easily... etc..
                            Another idea: table of relation between endurance and temp (range from 105C, 95C, 85C... 35C)
                            Anyway i hope my raw data are easy to read, and i hope the color code do some help .
                            I will attach the excel documents when it is ready.
                            We'll have to do sorting and grouping those series/brand by their performance. Pls give me input/opinion about that...
                            BTW I include my own observation. Caps with very close characteristics:
                            • group 1: Chemicon LXZ = Nichicon PW = Panasonic FC
                              group 2: Chemicon KZH ~ Nichicon HV ~ Rubycon ZLH
                              group 3: Chemicon KY = Nichicon HE = Rubycon YXG
                              group 4: Chemicon KZE = Nichicon HD = Rubycon ZL = Sanyo WX
                              group 5: Chemicon KZG = Rubycon MBZ = Sanyo WG
                              group 6: Chemicon KZJ = Rubycon MCZ
                              group 7: Nichicon HZ
                            Performance grade:
                            • group 1 < group 2 < group 3 < group 4 < group 5 < group 6
                            This rise some question:
                            • Where is Panasonic FM belong in the comparison?
                              group 5 < Panasonic FM < group 6
                            • Or, Nichicon PM ?
                              Nichicon PM = Chemicon LXY/LXV ~ group 1
                              Why are'nt they belong to group 1 ? They are longer size so they are slightly better in impedance. But if that isnt enough to justify it, we can add them to group 1:
                              group 1: Chemicon LXZ = Nichicon PW = Panasonic FC = ( Nichicon PM + Chemicon LXY)
                            Now this gives me a headache. There are a lot of series with almost the same spec but different in case size (advanced technology) and endurance . Wait, should we create comparison by endurance?
                            Isn't endurance = performance?
                            Man, i would avoid complexity as much as possible. *double headache.. help!
                            • yanz
                              • Nov 2004
                              • 910
                              Check also the thread made by Big Pope:
                              (Comparison Table of 4 Major Japanese Low ESR Capacitors)
                              https://www.badcaps.net/forum/showthread.php?t=1191
                              He made this:
                              Code:
                              Nichicon 	NCC 		Rubycon 	SANYO 		Remarks
                              VZ 		KMG 		YXA 		MV-CZ 		105C General Purpose
                              PW 		LXZ 		-		MV-CX 		Miniature, Low ESR
                              HE 		KY 		YXG 		MV-CA 		K6, K6-2, P2, P3 grade
                              HD 		KZE 		ZL 		MV-WX 		K7, P3 grade
                              HV 		KZH 		ZLH 		- 		Extra long life, miniature, Low ESR
                              HM 		KZG 		MBZ 		MV-WG 		K7, K8, P4, P4+ high quality grade
                              HN 		KZJ 		MCZ 		- 		Ultra Low ESR
                              HZ 		- 		- 		- 		Lowest ESR of all electrolyte capacitors
                              What i disagree from that table are:
                              - Sanyo CA is far worse than Rubyon YXG and Chemicon KY/Nichicon HE
                              - Should we include Nichicon HN/HM?. They are on badcaps list.
                              - I would avoid Nichicon VZ, Chemicon KMG, Rubycon YXA, because of their higher ESR. But their quality are better then some LESR Taiwanese Caps. I know some people use some general purpose of japanese caps (like Rainbow ) for recaping with no probs. I was once using Chemicon SXE (general purpose) with no success. I have to ask japlytic though, wether he use the SXE for PC board or Audio hardwares.. Probably SXE is good for certain board that fine with higher ESR Caps.
                              - Panasonic caps should be included in the comparuson due to the popular use of FJ series..
                              • yanz
                                • Nov 2004
                                • 910
                                1000uF 8mm 16v Caps
                                • yanz
                                  • Nov 2004
                                  • 910
                                  1000uF & 1200uF 16mm 16v Caps
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3583
                                    IMO, PM, like PR and PJ are getting near to being near to series end-of-life.
                                    I did a similar exercise with 50V, 16x25 parts and came up with similar groupings, except:
                                    * Group 2 >> HV, KZH, and YXG
                                    * Group 3 >> HE, KY, YXH
                                    * Group X >> KZM, ZLH
                                    The HM, HN, HZ and equivalents don't go high enough in voltage for my purposes, so I didn't look at them very closely.
                                    PeteS in CA
                                    • yanz
                                      • Nov 2004
                                      • 910
                                      Sory, long time no updates.. i've got busy This thread doesn't get much attention anyway.. so..
                                      @Petes, well, my bad that the performance comparison i made in the last post is wrong, so for the caps with rated voltage of 6.3v - 16v IMO the right grouping is like this:
                                      Code:
                                      Group	Chemicon	Nichicon	Rubycon		Sanyo		Panasonic
                                      1	LXZ		PW		-		-		FC
                                      2	KY		HE		YXG		-		-
                                      3	KZH		HV		ZLH		-		-
                                      4	KZE		HD		ZL		WX		-
                                      5	KZG		MBZ		-		WG		-
                                      6	-		-		ZLG		-		FM
                                      7	KZJ		MCZ		-		-		-
                                      8	-		HZ		-		-		-
                                      group 1 < group 2 < group 3 < group 4 < group 5 < group 6 < group 7 < group 8
                                      I am pretty much sure that's the final arrangement.
                                      (We could see some samxon series on group 5 - 8 but samxon caps quality are still under monitoring by some of us.. I guess that will need about 3-4 years ).
                                      Like you've mentioned, some of the series are being near to their end-of-life. Some series even has been discontinued. But I still see plenty of supply of them, example is the HFQ series from Panny.
                                      The rule of the grouping can be different for voltage range of 25v - 50v like you've mentioned. Some of the manufacturers are pretty consistent in using the 'standard' can size, but some others use widely (odd) variation for the can size, so two series that have similar spec/formula on 6.3v - 10v can be different in spec for 25v-50v range.
                                      • yanz
                                        • Nov 2004
                                        • 910
                                        i think we need some maps:
                                          MEDION ERAZER Major X20 Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION ERAZER Major X20 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Major X20 boardview and Major X20 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                          09-07-2024, 06:31 AM
                                          MEDION ERAZER Major X10 Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION ERAZER Major X10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Major X10 boardview and Major X10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                          09-07-2024, 06:11 AM
