MSI - K7T Pro Version 1
  • marfou
    • Nov 2004
    My Board has the following caps:
    7 - Green 4700uF 6.3V - 12.5mm KZE
    2 - Black 2700uf 6.3V - 10mm CHHSI
    9 - Green/Gold 1000uf - LP 10mm TAYEH
    2 - Black 470uf 16V - LP 10mm TAYEH
    One of the CHHSI has exploded. Reading here it appears CHHSI was one of the problem vendors.
    Obviously I need to replace CHHSI's. Should I replace the others? Are KZE and Tayeh known to be a problem?
    Thanks.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    can you post a pic of the kze?
    and tayeh is a known junk brand.
    so is chhsi.but you already know that.
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • TJ65
      Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
      by TJ65
      i made out of two broken Samsung Galaxy Tabpro S one that works partially.
      The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
      I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
      The problem is, that the micom Version doesn't match with the bios version, see picture.
      How can i update the Micom Version? The Samsung bios update wont work.
      With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
      01-09-2025, 01:35 PM
    • ssl6
      MSI K7T266 Pro (Ver. 1.0)
      by ssl6
      Hey Everyone,
      Long time lurker, but I think this is my first time posting.
      Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
      I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
      11-09-2023, 01:00 PM
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
