ecs h61h2-m12 v1.0 bios no display
  • hamza.dz
    • Sep 2025
    • algeria
    hi
    The BIOS won't save settings.
    I flashed the BIOS, but the motherboard no longer displays the image.
    I replaced the BIOS chip.
    The problem remains the same
    Can anyone help me?
  • m1ch43lzm
    • Mar 2019
    • 2952
    • Peru
    Try post 2
    https://www.badcaps.net/forum/troubl...-m12-v1-0-bios
    • lezsimply
      The Wanderer
      • 674
      • Philippines
      • Fixing Computers
      If bios settings won't save even after replacing bios chip, check RTC line. Usually it is found around cmos battery or close to it. Most of the time is a 3 pin diode.
      • hamza.dz
        • Sep 2025
        • algeria
        Originally posted by m1ch43lzm
        thanks i try this but the same
        • hamza.dz
          • Sep 2025
          • algeria
          Thanks I will search
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • MTT97
            I managed to brick the XPS 15 9550 Bios just by changing some settings and hit save...
            by MTT97
            Long story, i bought this XPS 15 9550 that came without a ram and ssd. I had a known working Crucial 8GB 3200Mhz DDR4 ram laying around so i tried it and the laptop would boot to bios but once exiting bios (without making any changes) it will get stuck on a black screen and only fans and keyboard would turn on. To get it ''working'' again i hard reset it by unplugging the battery and ac adapter and leave it for 5-10 min. I attempted to install windows but it froze before i even got to the language and region selection page. I then ordered some 2400Mhz rams which worked and i was finally able to...
            01-31-2026, 06:18 PM
          • lanovey
            SF314-41 BIOS without internal display
            by lanovey
            Hello there,
            I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
            I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
            06-13-2025, 02:38 AM
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
