GTX 1070: No output, VRAM? Issues with mats
  • SiO2
    • Apr 2022
    • 24
    I have an Inno3D Herculez X3 GTX 1070, which does not show any image. After ~30s, the monitor turns on and displays a black screen.
    The card however is detected by the OS, GPU-Z shows 0 MB VRAM. The driver crashed during boot.
    Visually the card is in very good condition. No visible signs of defects, all voltages are present and within reasonable range, but on the high side I think: Vcore = 0.9 V, Vmem = 1.5 V. Vcore measures ~250 mOhm according to my DMM.
    This leads me to the assumption, that something VRAM-related is off. So the natural first step would be to run mats and check for errors.
    Unfortunately, when I run mats (367) with two GPUs installed (monitor connected to the working one), I can run the test on the working card, but not on the 1070. It throws a warning that I should run
    Code:
    mods gputest.js -skip_rm_state_init -mfg
    but when I do, the following error messages appears:
    Code:
    CPU
    Foundry  : AuthenticAMD
    Name   : AMD Ryzen 5 1600X Six-Core Processor
    Family  : 15
    Model   : 1
    Stepping : 1
    Version
    MODS      : 367.38
    OperatingSystem: Linux (x86_64)
    Kernel     : 4.1.2-gentoo
    KernelDriver  : 3.63
    HostName    : tinylinux
    Smbios version [0x208] is not supported
             gpu 0 dev.sub 0.0
    PCI Location  : 0x00, 0x27, 0x00, 0x00
    DID      : 0x1b81
    Raw ECID    : 0x005ff5800000004568470191
    ECID      : PHMX70-22_x-1_y02
    Device Id   : GP104
    Revision    : a1
    NV Base    : 0xf6000000
    FB Base    : 0xe0000000
    IRQ      : 11
    ERROR: No responses on codec 0!
    Error 000000000723 : AzaliaController.InitExtDev Codec error detected
    Error 000000000723 : Global.CheckForAndInitAzalia Codec error detected
    Error 000000000723 : Global.InitPexAspm Codec error detected
    Error 000000000723 : Global.PerGpuInitializeCallback Codec error detected
    Error 000000000723 : Gpu.Initialize Codec error detected
    Error 000000000723 : Global.PrintGpuInitError Codec error detected
    Error 000000000723 : Global.InitializeGpuTests Codec error detected
    [COLOR="Red"]ERROR: Unable to determine current VGA mode, ax=0x4f03
    ERROR: Unable to set VESA mode 0x3, ax=0x4f02
    Error 000000000237 : Global.EnableUserInterface unable to set mode
    RmDestroyGpu failed[/COLOR]
    Error Code = 000000000723 (Codec error detected)
    The 723 error codes are familiar to me, they also appear with other cards and I couldn't figure out what's the reason, but they never seem to actually matter... maybe the tools are not compatible with my mainboard/CPU?
    Whatever, the lines highlighted in red seem to be related to the 1070 and don't look too good, right?
    I cannot run mats even after running the above mods command and I'm kind of stuck.
    Installing only the 1070 and running mats via the automated startup script yield no results. No logfile is created and the computer proceeds to the poweroff command.
    Any suggestions are very much appreciated.
  • benwaterson
    • Aug 2008
    • 202
    Re: GTX 1070: No output, VRAM? Issues with mats
    Do you have access to an Intel cpu based system to try in that (I had issues with an old AMD cpu and mods/mats before)
    • zefrench
      • Feb 2022
      • 27
      what is the output of ./mats -n [card index] -e [memory size to test in MB]
      • SiO2
        • Apr 2022
        • 24
        Good idea to test on an Intel platform. I might have a 4th gen combo somewhere... mats -n with the card in question leads to a segmentation fault .
        Let's see if this leads somewhere. Maybe I just get rid of the card to save me some headache.
        • dreico33
          Asus Strix 1060 GTX NO VMEM Voltage & MATS Shows READ Error on Every VRAM.
          by dreico33
          Hellow guys,
          I have 5 Asus strix 1060 with the same problem. No Singal, MATS Shows in every VRAM Read Errors. and i dont have present VMEM Voltage.
          12V Present
          5V Present
          1.8V Present
          PEX Rail 1V
          GPU CORE Present 0,7v
          VMEM NO Volts
          PWM Controller
          VCC 5V
          EN 3.1 V
          VREF 2.1 V
          As far as i can understand or is a problem with the memory Controller ( in this case there is no solucion?) or for some reason the vram do not have Voltage. By the way i...
          09-02-2024, 10:31 AM
        • chronic519
          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
          by chronic519
          Hello.
          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
          Found issue with a RAM block
          Replaced, green lines gone.
          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
          Used a good card to test and same results low errors 32+.
          I am just search for some form of command to do a full test on the GPU.
          I just ran the mats command with my good GPU and passed after roughly 40 min.
          The repaired one, ran...
          05-20-2025, 07:56 PM
        • kuba2102
          Configuring VRAM Straps resistor Acer Nitro 5 LA-H501P GTX 1070 after replacing VRAM
          by kuba2102
          Hi. My laptop was water damaged and many things didn't work. I managed to get it up and working but had problem with GPU and at the end it turned out to be a faulty VRAM (Hynix H5GC8H24AJR-R2c) and I replaced it with (Samsung K4G80325FB-HC25) and it worked sort of. On standard drivers I was able to play fine but once exit the game laptop thrown blue screen “video tdr failure”. When I installed gaming drivers it worked fine ok, but when was running on a battery only was giving me blue screens. I think the problems is due to a wrong Straps...
          02-20-2023, 05:04 PM
          Gigabyte P series P56XT-1070-702S Notebook Specification for Upgrade or Repair
          This specification for the Gigabyte P series P56XT-1070-702S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P56XT-1070-702S boardview and P56XT-1070-702S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 05:54 AM
          Gigabyte P series P56XT-1070-701S Notebook Specification for Upgrade or Repair
          This specification for the Gigabyte P series P56XT-1070-701S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P56XT-1070-701S boardview and P56XT-1070-701S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 05:46 AM
