KVA2 RTX 2060 Super 8GB Desktop artifacts
  • klugec
    • Sep 2023
    • 5
    Hello (sorry for my bad English),
    I have a strange problem with my KVA2 RTX 2060 Super. As soon as Windows 11 is loaded, artifacts appear. Now the crazy thing: When I start Furmark the artifacts are gone and Furmark runs great without crashing. Mats test shows me no errors (PASS). Drivers can also be loaded without any problems.
    Mods shows me the following error:
    Code:
    MODS start: Thu Feb  1 19:16:00 2024
    Command Line : gputest.js -oqa -old_gold -test 94 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 70 -matsinfo
    CPU
    Foundry   : AuthenticAMD
    Name      : AMD Ryzen 5 2600 Six-Core Processor
    Family    : 15
    Model     : 8
    Stepping  : 2
    Version
    MODS           : 400.281
    OperatingSystem: Linux (x86_64)
    Kernel         : 4.17.4-gentoo
    KernelDriver   : 3.87
    SBIOS Version  : 4901
    SBIOS Date     : 07/25/2022
    HostName       : tinylinux
                     GPU 0 [08:00.0]  dev.sub 0.0
    DevInst        : 0
    PCI Location   : 0x00, 0x08, 0x00, 0x00
    GPU DID        : 0x1f06
    PDI            : 0x33d91aab89d9290c
    Raw ECID       : 0x014045c00000007028442191
    Raw ECID (GHS) : 0x1647028442000000017020280
    ECID           : PS2X48-23_x04_y10
    Device Id      : TU106
    Revision       : a1
    NV Base        : 0xfb000000
    FB Base        : 0xd0000000
    IRQ            : 59
    WARNING: GPU 0 [08:00.0] PCIE speed capability (8000Gbps) higher than down stream port link speed (2500Gbps)
    ERROR: SMBus controller Not found
    Setting Fan 1 of GPU 0 [08:00.0] to 70%
    Foundry        : TSMC
    Subsystem VID  : 0x10de
    Subsystem DID  : 0x13a3
    Board ID       : 0x0160
    Chip SKU       : 410-0
    Project        : G160-0062
    Fuse File Fmt  : JSON
    Display        : 0x00000100 (id)
    SBIOS Init     : Primary
    Native Mode    : 1920x1080
    Memory Size    : 8192 MB
    FB Vendor      : Micron
    RAM Protocol   : GDDR6
    RAM Config     : 1
    ROM Version    : 90.06.44.80.5d
    ROM Type       : Partner Production
    ROM OEM Vendor : NVIDIA
    ROM Partner    : galaxy
    ROM Project ID : 107293galaxy
    ROM Timestamp  : 2019-6-12 17:09:31
    ROM Expiration : 2019-12-9 17:09:31
    ROM GUID       : 2D6AC2F846E34A8DBF8F581AA44D2AD8
    PPC Pri/Sec FW : Unknown
    PPC Driver Ver : Unknown
    PState (mode)  : 8 5 3 2 [0]
    PState Version : 3.5
    EDC            : Disabled
    GPC Clock      : 1890.0/1885.3 MHz NAFLL
    DRAM Clock     : 7001.0/7014.0 MHz DEFAULT
    Host Clock     : 1350.0/1349.7 MHz NAFLL
    XBar Clock     : 1800.0/1800.1 MHz NAFLL
    Sys Clock      : 1890.0/1888.4 MHz NAFLL
    Power Clock    : 540.0/540.5 MHz DEFAULT
    NVDec Clock    : 1755.0/1746.2 MHz NAFLL
    Display Clock  : 1330.0/1329.0 MHz DEFAULT
    NVVDD          : 1062 mV
    GPC  Mask      : 0x07 (3 GPCs)
    TPC  Mask      : [3f 3f 3e] (17 TPCs)
    FB   Mask      : 0x0f (4 FB Partitions)
    ROP/L2 Mask    : [3 3 3 3] (8 ROP/L2s)
    PES  Mask      : [7 7 7] (9 PESes)
    FBIO Mask      : 0x0f (4 FBIO Partitions)
    FBIO Shift Mask: 0x00
    XP   Mask      : 0x03 (2 3gio Pads)
    Nvdec Mask     : 0x07 (3 engines)
    Nvenc Mask     : 0x01 (1 engine)
    Gpu Temp       : 48 deg C
    PEX Rx Lanes   : 0x00ff
    PEX Tx Lanes   : 0x00ff
    PEX Det. Lanes : 0x00ff
    PEX Width, ASLM: 8 lanes, Not Supported
    PEX Link Speed : 8.0 Gbit/s
    PEX BandWidth  : 64.0 Gbit/s
    ASPM, ASPM-CYA : (L0s/L1, Disabled)
    ASPM L1SS, CYA : (Disabled, L1.1/L1.2)
    LTR            : Disabled
    Chipset
    VID            : 1022 (AMD)
    Chipset DID    : 1450 (Unknown)
    Chipset ASPM   : L1
    ASPM L1 SS     : Disabled
    RM Version     : rel/gpu_drv/r400/r400_00-823
    resumehandler.js: 1
    gputest.js     : 81
    oqa.spc        : 3
    boards.js      : 3
    Running test(s) on GPU 0 [08:00.0] (DID: 0x1f06)
    Enter SetPState (test 0)
    Switched to PState 0 (0.max). Pcie Speed=8000, x8
    Speed = 8.0Gb/s,  expected 8.0Gb/s
    UpStreamWidth = 8,  expected 16
    Error 020000000143 : Global.SanityCheckLink PCI Express bus error
    Exit 020000000143 : SetPState (test 0) PCI Express bus error
    Error!
    Error 020000000143 : SetPState (test 0) PCI Express bus error
    Enter NewWfMats (test 94)
    Exit 000000000000 : NewWfMats (test 94) ok
    GPU tests completed.
    Failure(s) :
     LOOP           TEST                 CODE               MESSAGE
       1   SetPState                 020000000143  PCI Express bus error
    Error Code = 020000000143 (PCI Express bus error)
    MODS end  : Thu Feb  1 19:16:26 2024  [26.301 seconds (00:00:26.301 h:m:s)]
    What could be the problem?
    Many thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    it is hard fault. simple mats shows it
    • klugec
      • Sep 2023
      • 5
      Is there a chance to repair? If so, what should I look for? Equipment is available (microscope, soldering station...)
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        maybe. u have bad memory ic, bad solder joint under it or bad solder joint under gpu chip
        first u neet to run mats. to remove memory chip u need preheater, hotair station, new chip or stencil to reball original, solder balls, flux, soldering iron
        • klugec
          • Sep 2023
          • 5
          Mats doesn't show me any errors, I also tried with 1024 MB. Mods shows me some errors at dramclk_percent 120. But I guess that has nothing to do with it? Should I reball every memory chip (stencil is available for DDR6x) or can I exclude the chips?
          • piernov
            • Jan 2016
            • 4439
            • France
            GPU might be unstable at lower voltages.
            • klugec
              • Sep 2023
              • 5
              Would it help to increase the voltage? The best thing would be to write this directly into the BIOS. Can this be edited and flashed?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                is that rtx only gpu in system? dont u have integrated gpu?
                • klugec
                  • Sep 2023
                  • 5
                  i have a test bench, AMD 2600 without integrated gpu. I have also a riser cable for testing (pci-e x1).
                  I have a second GPU to test, an ATI card.
                  • skrakapuku
                    • Mar 2024
                    • Italy
                    Got the same problem with Asus 1080Ti Error Code = 020000000143 (PCI Express bus error), Furmark runs great without crashing, crashes only in games without artifacts, did you find the cause?
                    • naruto22
                      • Oct 2020
                      • Maroc
                      your cpu cant support pcie x16 try it with other cpu.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3627
                        • slovakia
                        check memory marking. i bet it is older micron and u must replace whoe memory chips
                          NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                          The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                          10-02-2024, 07:51 AM
                        • benwaterson
                          Gigabyte Aorus 1080ti - card not initialising
                          by benwaterson
                          Hi there.
                          Have searched various forums but haven't come across the exact issue I am having.
                          Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                          I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                          Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                          02-05-2022, 11:42 AM
                        • myth77
                          UV solder mask - high temp resistent, recomendation?
                          by myth77
                          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                          Is there any solder mask...
                          03-28-2022, 04:04 AM
                        • mindoverflow
                          ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                          by mindoverflow
                          hello,
                          there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                          I changed pads and thermal paste.
                          I run mats test but it is reporting 0 errors.
                          I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                          After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                          02-09-2022, 03:22 PM
                        • N3Star
                          Retro 8800 GTX from EVGA artifacts
                          by N3Star
                          I need help identyfing what is broken on this GPU - GPU core or VRAM. Let's start with what I did and know so far:
                          - disassembled, added missing SMD capacitors from same GPU
                          -(If anybody knows what Q518 is and would share this information I would be very grateful)
                          - artifacts during Windows booting are blue vertical stripes, I can take a photo if that would help
                          - artifacts in Windows are yellow-ish horizontal lines
                          - in BIOS/ text on black screen text gets extremely garbled
                          - GPU-Z doesn't show GPU or VRAM frequency
                          - GPU error 43...
                          06-14-2022, 03:45 AM
