Palit RTX 2080 Super Jetstream Mats/Mods help
  • Maxim Bojko
    • Sep 2024
    • 7
    I have a RTX 2080 that is broken, but interesting thing is that the card works how it should work, but when playing the card crashes, black screen fans go to 100% and nothing happens anymore. I changed thermal paste because I thought it was overheating, but no. So I checked with gpu z and here is what I had.
    After a while a dude I got friends with told me to underclock the gpu via msi afterburner. First to underclock the core speed by 200 then open the chart for the mhz and voltage and said that I should change the mhz at 0,9v to 1900mhz. Since then I doesn't crash anymore.
    Now I want to go deeper and find out why it's crashing. So I started mats/mods and had this two things. I did
    •/mats -e 5 |less
    and then a script i found online
    • /mods gputest.js -test 118 -test 178
    • dramclk_percent 100 -oqa -matsinfo -fan_speed
    100
    The first one I failed and hat errors on every memory bank and on the second one I passed but had the error „Mode is not possible for display Ox100, head
    0"
    What does this error mean? Because after the second test the screen turned black the gpu resumed to behave normally but I had no signal on the monitor. The PC didn't freeze because I could type in poweroff press enter and the pc would shut off.
    Thermal pad thickness for various laptop GPU / Graphics Cards
    ASUS Dual RTX 2070 OC 8GB
    ASUS ROG STRIX RTX 3080 OC
    ASUS ROG STRIX RTX 3090
    ASUS TUF Gaming RTX 3080 OC Edition
    ASUS TUF GTX 1660 S-O6G GAMING
    EVGA RTX 3060 Ti XC GAMING 8GB
    EVGA RTX 3060 XC GAMING 12GB GDDR6
    EVGA RTX 3080 FTW3 ULTRA GAMING
    EVGA RTX 3080 TI FTW3 ULTRA GAMING
    EVGA RTX 3090 XC3 ULTRA GAMING 24GB
    Gainward RTX 2080 Phoenix GS Specs
    Gainward RTX 3070 Phoenix 8GB
    Gainward RTX 3080 Ti Phoenix
    GIGABYTE AORUS RTX 3080 MASTER 10G
    02-09-2024, 08:08 AM
  • chronic519
    Mats / mods: detected and repaired GPU fault. Cant seem to test after!
    by chronic519
    Hello.
    GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
    Found issue with a RAM block
    Replaced, green lines gone.
    Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
    Used a good card to test and same results low errors 32+.
    I am just search for some form of command to do a full test on the GPU.
    I just ran the mats command with my good GPU and passed after roughly 40 min.
    The repaired one, ran...
    05-20-2025, 07:56 PM
    NVIDIA GeForce RTX 2080 Schematic & Board View
    The GeForce RTX 2080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2018. Built on the 12 nm process, and based on the TU104 graphics processor, in its TU104-400A-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU104 graphics processor is a large chip with a die area of 545 mm² and 13,600...
    10-02-2024, 07:57 AM
  • 00__Nomad__00
    About MODS & MATS
    by 00__Nomad__00
    Do MODS & MATS work with older nVidia GPUS, specifically the G71 M ?
    I've tried versions 173.48, 400, and 455, but it can't detect the GPU, even though the GPU is detected in Windows and functioning properly. I couldn't find any lists of supported GPUs.
    11-12-2023, 04:12 PM
    NVIDIA GeForce RTX 2080 Ti Schematic & Board View
    The GeForce RTX 2080 Ti is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2018. Built on the 12 nm process, and based on the TU102 graphics processor, in its TU102-300A-K1-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2080 Ti. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU102 graphics processor is a large chip with a die area of 754...
    10-02-2024, 08:01 AM
