P5G41C-M LX stuck on brand image
  • c4passion
    • Jul 2014
    • 29
    • Spain
    Hi all, i have this mobo, the problem:
    i power on the pc, it show Asus Logo on screen and it hangs there, no power off, no bios acces... i have to force shutdown presing the power button or removing power supply cable.
    I cant see bad capacitors on the board.... any tip?
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    Re: P5G41C-M LX stuck on brand image
    Try hotflashing a newer BIOS if the BIOS chip is a square PLCC chip.
    If that doesn't work then I'm out of ideas.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      • 31214
      go into the bios with the "del" key and turn off the quickboot logo so you can see the diagnostic text.
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        • Romania
        He said he has no BIOS access,as it hangs on the logo.
        Main rig:
        Gigabyte B75M-D3H
        16GB DDR3-1600
        Delux MG760 case
          • 31214
          he may get in by pressing the button before the logo apears.
          this is why you dont set the stupid logo on in the bios.
          it may be bitching about the ram or a bad gfx card, but if you cant see it then you dont know.
          i'd like to know what cards and how many dims are in this machine!
          • c4passion
            • Jul 2014
            • 29
            • Spain
            System hangs, no beeps, I can't enter to bios, it freezes on Asus logo screen
              • 31214
              did you reset the cmos with the jumper?
              • c4passion
                • Jul 2014
                • 29
                • Spain
                yes, it was the fisrt thing i have done.
                tryed another 2 processors, varius tested rams, and the same.
                  • 31214
                  what cards are fitted?
                  • Majestyk
                    • Nov 2013
                    • 96
                    Bad PSU?
                    (just to rule this out)
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Using PS/2 or USB keyboard ?
                      If USB, try a PS/2 keyboard to see if its Del key gets into BIOS settings
                      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        If this occurs with 4 sticks, take half of them out, increase the DRAM voltage, save then put the other sticks back in.
                        (Increase the DRAM voltage to 1.90 V for DDR 2)
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • brethin
                          • Dec 2008
                          • 1907
                          Replace the Cmos battery with a new one, Some ASUS boards will do this when the battery drops below 3v.
                          • c4passion
                            • Jul 2014
                            • 29
                            • Spain
                            First the aswers:
                            wirh integrated card: Nothing changes
                            with graphic card: The same thing
                            i have tried various cards, X300, hd 5450, hd 3850...
                            Originally posted by Majestyk
                            Bad PSU?
                            the psu is working fine, i have tried at least 4 working PSU and no changes.
                            Im using ps2 and usb, it freezes always in same point.
                            It happen with 1 or 2 modules
                            I will try this.... I dont know that.
                            it get stuck on this screen:
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Does the "Num Lock" key on the keyboard stop responding too? Keep pressing so that it turns ON and OFF. If it stops responding, the motherboard truly is getting stuck on boot. May need to reflash BIOS chip externally.
                              • Dan81
                                SNES-powered
                                • Oct 2013
                                • 1866
                                • Romania
                                Well,he'll have a hard time flashing the chip I guess,since it's neither DIP32 nor PLCC.
                                Main rig:
                                Gigabyte B75M-D3H
                                16GB DDR3-1600
                                Delux MG760 case
                                  • 31214
                                  what is it, SPI ?
                                  if it is then it may be pretty easy from a parallel port.
                                  • Dan81
                                    SNES-powered
                                    • Oct 2013
                                    • 1866
                                    • Romania
                                    what is it, SPI ?
                                    Yes,it's a SPI flash.
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    16GB DDR3-1600
                                    Delux MG760 case
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      Does it have an SPI port ?
                                      http://www.mylesgray.com/hardware/fi...n-motherboard/
                                      http://mondotech.blogspot.com.au/200...spi-flash.html
                                      http://rayer.g6.cz/elektro/spipgm.htm
                                      • c4passion
                                        • Jul 2014
                                        • 29
                                        • Spain
                                        it have pararel and serial port, i will check those links
                                        • Ugur87
                                          MacBook Air M4 A3240 Brand New Water Damage no Image
                                          by Ugur87
                                          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                          08-28-2025, 01:09 PM
                                        • Stunt
                                          Hp Laptop Stuck on Hp protected by hp sure start screen
                                          by Stunt
                                          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                          screen that's it and stuck there. I left it until the following day and i still...
                                          09-02-2025, 01:51 PM
                                        • Stanley1843
                                          BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                                          by Stanley1843
                                          has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                                          06-22-2024, 11:06 AM
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • shlomim412
                                          samsung ua55es6800 - no image
                                          by shlomim412
                                          hi
                                          having problem with samsung ua55es6800
                                          tv had backlight on, sound working - responds to the remote control but no image.
                                          check tcon board - had 12v in but no other voltages present.
                                          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                          when leaving only left side connected - again no voltages and no image.
                                          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                          kept trying to block less pins on the left ribbon cable...
                                          05-15-2024, 05:00 AM
