No POST after writing single bit to CMOS; any solution?
  • Behemot
    • 4845
    • CZ
    Re: No POST after writing single bit to CMOS; any solution?
    The battery is slightly weaker, 2,84V or so, but even if it is removed, once I save the BIOS, it won't POST again.
    • SteveNielsen
      Retired Tech
      • 2327
      Perhaps CMOS has been damaged by ESD. The ease and subsequent potential frequency of changing the battery by unknowing people it seems a high enough probability to consider. Regardless of the cause, I think your CMOS is damaged.
      • Behemot
        • 4845
        • CZ
        Nobody touched it inside, my parents are not capable of it. I just know previously the problem was the system was suddenly hanging on POST, than some guy took it, found nothing and gave back. I've reset the CMOS and you know the rest. I'd say the previous problem was already a sign of bad CMOS memory…
        • SteveNielsen
          Retired Tech
          • 2327
          I agree. Just thinking out loud about what may have caused it.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Why have you not tried doing the simplest thing yet, or did I miss it?
            Replace the battery
            • Behemot
              • 4845
              • CZ
              #26
              It does not work with battery (2,84 V is OK for operation), it does not work without (running on +5 V SB), do you think using different battery will help?
              • Agent24
                I see dead caps
                • Oct 2007
                • 5014
                • New Zealand
                #27
                Is that measured in-circuit or unloaded? Either way it may be too low.
                A brand new CR2032 I just measured shows 3.4v without load.
                -David VanHorn
                • Behemot
                  • 4845
                  • CZ
                  #28
                  Most batteries I've replaced started to to loose time all not sooner than under 2,5 V, still plenty to go
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    Geez, how hard is it? Try a new cmos battery at least to be able to rule that out as a possible cause of trouble.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #30
                      Just an idea, although it probably won't work (and you may have tried this already), but still...
                      Have you tried disabling everything in CMOS? That is, the floppy controller, IDE controllers, serial and parallel ports, onboard audio and LAN (if present)... even stuff like SMART and L2 cache, if such options exist.
                      Also, make sure RAM is set to run by SPD or underclock it to its minimum, just in case. Set its voltage to SPD or normal settings too. Same with CPU - normal voltage and underclock to the minimum FSB.
                      But leave the time and date same as before.
                      Agreed.
                      It likely won't fix the problem, but it's still better to try it than not. After all, what if it really did fix the problem?
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #31
                        All CMOS designs I've seen differ greatly.
                        The big name brands like Dell often manage to design it well so that the battery is run really low, and they also warn of low battery in time.
                        Other boards just say nothing and stop working properly.
                        (My Asus Maximus Formula is an example, the clock simply start running slow).
                        I'm not saying it's it, but changing the battery is a really easy thing to do.
                        Plus so far in your troubleshooting all we can deduce is that the 2.8v or whatever and 0v (no battery) results in a corrupt CMOS.
                        • Behemot
                          • 4845
                          • CZ
                          #32
                          I told ya, storing single bit in there results in corrupt CMOS. No matter what I do, even if I don't change anything and save, it's bad. If I exit without saving, it is able to start. Does not seem to me like battery problem if it does the same without battery.
                          Even if it worked with battery, it is useless, that would mean the stand-by supply is not being used. In such case only battery will hold the settings and I'd have to replace it every half a year. I'd rather throw the board to river and replace it than this.
                          Will remove it and check the circuitry as soon as I get some time.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5014
                            • New Zealand
                            #33
                            Check for bad connections or open parts in the standby supply line to the RTC etc then?
                            -David VanHorn
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              Just for shits and giggles try changing the keyboard out with another working keyboard. Could be a corrupt key signal or dirty off frequency signal geting into the bios registers. Also highly suggest using a NEW BATTERY for the tests.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                #35
                                Okay, that's fine. But just try a new bat. for the sake of curiousity / scratching everyone's itch here (mine too). It takes like 5 seconds anyways. Don't say you don't have time for that.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  Different keyboard was used, I took only the case with me to Prague, no change in here.
                                  Not really sure why you guys try to get most crazy explanation. I opened this thread because I have seen TOO MANY different motherboards with the same problem so far. One of them was some better 775 board with burned RJ-45 connector, probably from lighting so it strongly suggests CMOS or similar defect. The boards is long gone but I have seen more. Hell for sure at least once I have also tried replacing battery, last time it was some Socket 478 board and IIRC it was too weak already. Guess what? It never helped, otherwise I would not start this thread, right? I am trying to find if that is CMOS (and if, where the hell it is located), BIOS or something on the way (e. g. standalone controller responsible for writing into the CMOS).
                                  So far best possible explanation was with some diodes, just did not get time so far to remove the board from the case and have a look after them. But the rest is just - pardon me - rubbish. Clearly the easiest expanation does NOT apply here, this is more serious problem.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5014
                                    • New Zealand
                                    #37
                                    In older machines the BIOS settings used to be stored in a separate battery-powered RAM chip, nowadays it is usually integrated into the Southbridge.
                                    http://en.wikipedia.org/wiki/Nonvolatile_BIOS_memory
                                    http://en.wikipedia.org/wiki/Real-time_clock
                                    -David VanHorn
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      Been using HDMI graphics in this machine for testing plasma so I fed it with new CR2032, guess what…
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5014
                                        • New Zealand
                                        #39
                                        I don't know, you tell us?
                                        -David VanHorn
                                          • 31158
                                          suspense is killing me
                                          • Exim
                                            ASRock N100M, no picture no boot, but semi-alive
                                            by Exim
                                            Hi guys,
                                            I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                                            ASRock N100M special features:
                                            - CPU soldered to board, small Intel 12th gen
                                            - iGPU
                                            - four POST LEDs
                                            Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                                            I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                                            Symptoms:
                                            - no picture/signal on any of the display connectors,...
                                            04-01-2025, 02:36 PM
                                          • HammyCheesy
                                            Lenovo ThinkStation P720 BIOS Request
                                            by HammyCheesy
                                            Hello all,
                                            I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                                            When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                                            Type: 30BB
                                            Model Number: S03600
                                            S/N: MJ07N68C
                                            Things I have tried:
                                            1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                                            2. Attempted to boot with just a single CPU...
                                            04-11-2025, 01:02 AM
                                          • titomno2
                                            Gaming Laptop Zephyrus S17 TFT not detected every time !
                                            by titomno2
                                            Hi guys,
                                            I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                                            So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                                            On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                                            Then the screen won't work for a long period of time.
                                            If I wait 1 or 2 hours it work again most of the time.
                                            When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                                            01-19-2025, 08:27 AM
                                          • Kokopolokoks
                                            H110T-SI01 ECS Motherboard bios
                                            by Kokopolokoks
                                            Good day guys, I have this Atec all in one from korea that have a ECS Motherboard H110T-SI01 with bios password that does not remove after removing the CMOS battery and clear CMOS jumper. I tried the RCUnlocker but it does no support it i was wondering is there a solution to this here's the dump BTW. I have 20 of this item on hand and my first time to encounter this on a desktop motherboard that doesn't clear.
                                            i can provide some pictures if needed thank you in advance....
                                            09-12-2025, 12:33 AM
                                          • Swedishpower
                                            Dell G3 15 3500 black screen
                                            by Swedishpower
                                            Hello
                                            I have search everywhere for a solution for my problem, but cant find it anywhere.
                                            When I was away to trow some garbage i always look in the electronic bin.
                                            and this time i find a laptop.
                                            Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                                            the lamp for charmig is white.
                                            Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                                            but no Dell logo.
                                            I tryed with a hdmi cable to another screen, still black.
                                            I started to search solution and tryed...
                                            07-06-2025, 06:18 AM
