No POST after writing single bit to CMOS; any solution?
  • Behemot
    • 4845
    • CZ
    #41
    Re: No POST after writing single bit to CMOS; any solution?
    Nothing. No change in behaviour.
    • Behemot
      • 4845
      • CZ
      #42
      Bloody hell. I got MSI K8N Platinum but it does not POST. Not sure if it is old BIOS (with Opteron 180), incompatible memory, graphics or anything else, but I am not able to solve it now. I am going home in like 10 hours so I will just have to leave it be :-(
      As for the DFI board, I have noticed one small SMD transistor which may be burned on the board. The other ones around are glossy, this one is not and has something like excessive heat marks. I'll check it as I return, as well as other stuff around.
      • Behemot
        • 4845
        • CZ
        #43
        Fuck me! That transistor was good. I was messing with diodes when I encountered one which seemed to be bad. OK, took it out. Measures good? WTH…placed it back in…and it works fine ever since with several restarts and messing in BIOS!
        May it be something like tin whisker?? It's a bloody DFI after all, they wanted to be first everywhere…it may have included PB Free stuff.
        Will be doing more extensive research tomorrow with the original CPU (Opteron 180) and RAM (4 GB high-density) with all the rest original HW. Keep ya posted.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5039
          • New Zealand
          #44
          Perhaps the diode\transistor were slightly bad and heating them did something good to them... or bad soldering, wouldn't you be able to *see* tin whiskers?
          -David VanHorn
          • Behemot
            • 4845
            • CZ
            #45
            No idea, too many micro SMD components. I've been using two 150W transformer irons so may have heated it quite extensivelly
            • Behemot
              • 4845
              • CZ
              #46
              I don't even dare to say what the problem was after all.
              First, I have these cheap high-density memories. They need command rate 2T and disabled bank interleaving if you want to use 4 of them. I forgot so each time the board POSTed with safe settings (after clearing CMOS), it POSTED, other than that, it have not.
              Scond, one of the moduels just failed, the memories heat quite extensively here, it copes with what dad told me - first, the PC jsut dropped off. Than it started having some POST problems, finaly they gave uit to a guy to fix it and not sooner than that I got it in this state. So now I am using 2 HD + 2 LD memories, seems to be good.
              • questore
                XPS 13 9370 CMOS battery voltage always low
                by questore
                Hi Everyone,
                I have brought you a mistery item
                This laptop have come with some strange faults.
                1. CMOS battery was flat 0v
                Symptoms:
                - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                Amp drawing was stuck at 0.005 milliamps.
                - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                After inverstigation RTCD1 diode had a low value...
                09-30-2025, 05:47 AM
              • Exim
                ASRock N100M, no picture no boot, but semi-alive
                by Exim
                Hi guys,
                I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                ASRock N100M special features:
                - CPU soldered to board, small Intel 12th gen
                - iGPU
                - four POST LEDs
                Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                Symptoms:
                - no picture/signal on any of the display connectors,...
                04-01-2025, 02:36 PM
              • HammyCheesy
                Lenovo ThinkStation P720 BIOS Request
                by HammyCheesy
                Hello all,
                I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                Type: 30BB
                Model Number: S03600
                S/N: MJ07N68C
                Things I have tried:
                1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                2. Attempted to boot with just a single CPU...
                04-11-2025, 01:02 AM
              • titomno2
                Gaming Laptop Zephyrus S17 TFT not detected every time !
                by titomno2
                Hi guys,
                I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                Then the screen won't work for a long period of time.
                If I wait 1 or 2 hours it work again most of the time.
                When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                01-19-2025, 08:27 AM
              • Kokopolokoks
                H110T-SI01 ECS Motherboard bios
                by Kokopolokoks
                Good day guys, I have this Atec all in one from korea that have a ECS Motherboard H110T-SI01 with bios password that does not remove after removing the CMOS battery and clear CMOS jumper. I tried the RCUnlocker but it does no support it i was wondering is there a solution to this here's the dump BTW. I have 20 of this item on hand and my first time to encounter this on a desktop motherboard that doesn't clear.
                i can provide some pictures if needed thank you in advance....
                09-12-2025, 12:33 AM
