I think my technique is improving.
  • gastorgrab
    • May 2007
    • 320
    Cap replacment #4 looks like a success.
    I just finished installing new capacitors in the board i pulled out of my video encoder. The capacitors weren't bad but i thought they were at the time i started yanking them out.
    Anyway, i think i'm getting better at it.
    The scorching on the underside occurs when my repeated attempts at getting the solder out of the holes keeps failing. (w/ desoldering braid)
    This part caused me a little grief until i pulled out the microscope. I tuns out that these lines the kept bleeding into one leg of the capacitors was in fact the same trace.
    EPoX chose to expose (to not coat in enamel/lacquer), areas that form parallel lines. Why would they do that? It should shield RF the same whether it is coated in enamel or not.
    BTW, i'm posting from this machine. It's not installed in any case because it's now orphaned.
    I'm thinking of giving it to my sister to replace the junk i've been fixing until now (Abit BX-133, EPoX 3VSA2).
  • gonzo0815
    • Feb 2006
    • 1600
    Re: I think my technique is improving.
    Those tined traces are thicker and thus can handle higher current`s (at least i think that this is the intension for them).
    Furthermore this is acting as a load balancing, avoiding hot spots.
    On many PSU`s the manufacturers are using very thick tin coverage in order to cheap out at the raw PCB copper thickness of the base material used.
    So i think it is cheaper to only put extra thick tin onto those traces who needs this, then to go with a thicker copper layer for the whole board (copper is $$$).
    • gastorgrab
      • May 2007
      • 320
      Then i hope it's still the same thickness. I had to run the iron along the length of one of the lines to make it pretty again.
      • Logistics
        • Apr 2007
        • 721
        that "scorching" = flux
        Get some flux-off! I think some here use denatured alchohol or solvents to clean it up.
        • gastorgrab
          • May 2007
          • 320
          The picture is of the board, after using flux cleaner. The scorched marks appear under the microscope as scale.
          I think maybe i've burnt the flux because whats left wont wash away, even with flux cleaner and a toothbrush.
          The coating of the circuit board still looks fine under th microscope.
          The microscope might be good for other beginners, such as myself, to see the impact of your changes. If your having a problem, and don't like the results your getting and decide to try something different, you need to be able to see if your 'something different' is making a change for the better.
          Noone can learn without feedback.
          • shadow
            • Feb 2007
            • 732
            Like me!
            I used simple, off the shelf methylated spirits on my recap job.
            I actually id go to a electronics hobby shop to buy some flux cleaner. However they did not stock any!!
            So I basically said stuff it and used the methylated spirits as I believe it is mentioned as being an alright flux cleaner in the FAQ section in this forum.
            • tazwegion
              • Jun 2006
              • 444
              Definately! I use methylated spirits (95% ethanol) too, though I'm lazy using an electric toothbrush to get the job done
              Viva LA Retro!
              • bgavin
                • Jan 2007
                • 1355
                Thanks to the sysops for putting the recapping FAQ in place. I use the stainless needle method for hole cleaning, and find it works the best by far, for me.
                The FAQ is worth reading a dozen times until you have it imprinted on the inside of your head. A good solder station is a must. I use a modest Hakko 936 ($78) and it works perfectly at 450C for removing caps and cleaning holes. I turn it down to 400C when soldering the new caps. Perfect.
                • gastorgrab
                  • May 2007
                  • 320
                  Will vodka disolve flux?
                  • Spacedye69
                    • Nov 2005
                    • 698
                    • US
                    Even if it doesn't, by the end of the recap you won't care anymore!
                    Denatured alcohol works well. I use non conductive rosin core flux, so I don't bother to even clean it off anymore. No one looks at the bottom of their boards anyway.
                    • kotel studios
                      Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                      by kotel studios
                      Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                      Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                      So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                      What I've tried so far:
                      replace the original N-MOSFETs with beefier 60V ones for testing
                      Resolder the resistors near the Vcore Jumper block
                      Short Vcore...
                      05-25-2025, 01:46 AM
                    • kotel studios
                      Epox EP 8K3A+/8K3A - need specs of 2 caps in DDR1 VRM arena
                      by kotel studios
                      Is there anybody here who could tell me what are the two caps marked bellow? Or atleast send me a picture of those two caps from their board. Size wise I think those will be 2200uF10v, the same as in the CPU VRM, but not sure....
                      01-18-2025, 08:54 AM
                    • bigbeark
                      EPOX EP-MGF6100-M No USB Sound
                      by bigbeark
                      This is a Socket AM2 Nvdia board with GeForce 6100 chipset.
                      The Onboard sound does not work if I use USB headphones but does work if I use the mini RCA jack. I did use the USB ports on the actual motherboard.
                      Made me wonder how USB talks to the audio chip in every other motherboard but not this one. I do find the audio a bit weak. I could replace the small caps near the audio port stack
                      but I don't expect it to fix the USB sound.
                      Any ideas on how to fix this? I could just add a PCI audio card but it's nice to have front-panel plug in sound.
                      02-25-2021, 11:05 PM
                    • Davi.p
                      HP Laptop not charging..
                      by Davi.p
                      Hi, exactly on the August 2023 i saw a YT video from "electronic repair school" channel, where it says a technique how to recover dead batteries not charging, probably them has been left uncharged for too long and became "locked" by internal circuitry to avoid wrong chargement by laptop, i'm still wondering why every cellular phone also the oldest and cheaper has a built in slow charge modality to avoid danger on li-ion cells, and on laptop i' ve never heard of that option, only stupid lock modes so those are ready for the trash bin, this maybe due to bigger size / more danger,...
                      10-03-2025, 05:15 AM
                    • Hitto
                      Improving CRT geometry by upgrading capacitors
                      by Hitto
                      I'm trying to improve the geometry of a CRT monitor by upgrading capacitors.
                      Compared to the original ones, I've upgraded by 15-20% the capacitance of each capacitor around the flyback trafo and used components with higher current capabilities.
                      Howewer, the scan capacitor (the big 3.3uF bipolar capacitor in the horizontal section) is what is giving me trouble.
                      Do you guys know if going higher with the capacitance will make possible to obtain a better geometry or will it only affect the horizontal width of the picture?
                      Is a polyester capacitor...
                      11-28-2019, 09:48 AM
