PNY XLR8 RTX 3090 dead. Is this PEX shorted? Am I cooked?
  • FeerBaron
    • Sep 2018
    • 39
    I rebooted my computer and suddenly it didn't detect. It was nvlinked to another card that works. Lights don't light up. I checked around with DMM from youtube videos but didn't find a really good diagram except the one from 3090 FE. Going by that it looks like this is PEX? In that case the last option is to lift the coil and see which side is shorted or GPU is gone?
    This card started out used with a bad HDMI port and worked for about a year. Guess it doesn't work anymore. I was going to send it to a repair service in case of mosfet or some tiny IC they can air station swap. If the core is dead, it seems there is no point. Thoughts?
    In this case 5v is bottom left? 12v bottom right and then 1.8v top left? Not sure if I have this right.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3634
    • slovakia
    buy a riser and check it running
    • FeerBaron
      • Sep 2018
      • 39
      I am sending it off to get fixed. For next time I will buy a riser. Someone helped me out with a diagram of where everything was and I'm putting it here to help others in the future.
      Pex tested good, 2 caps near the fan connector are badly discolored. Nothing is obviously wrong from an unpowered test besides that. Maybe someone can suggest a cheap dock
      for this type of thing.
      • BalkanBoy
        Dead Razer Blade 14 2022, shorted CPU?
        by BalkanBoy
        today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
        Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
        I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
        Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
        I removed coil and injected 0.7V, it draw around...
        09-27-2024, 12:44 PM
        NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
        The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
        10-02-2024, 08:52 AM
      • pc_okay
        G703GXR Dead CPU? shorted CPU power mofset replace, missing DRAMRST#
        by pc_okay
        Hello friends,
        I replace a shorted mofset (PU8104), now laptop is starting but no display, stopping at DRAMRST#.
        Resistance to ground on PL8104 is around 1-2 ohm, quite low but voltage seems ok 0.995V
        Any help would be appreciated it's a nice laptop !
        Thanks. 😃
        04-02-2025, 04:48 AM
      • fallenapples
        Acer Helios 300 N20C3- Dead Shorted mosfet blows
        by fallenapples
        Hey all
        Have the above laptop which is shorting out the power supply. 19v when plugged into the wall then when inserted into the laptop ir reads nothing untill you remove it from the wall and plug it in again.
        i found PQZ3 shorted so removed and confimed short gone.
        replaced PQZ3 and it shorted again?
        ive removed PQZ3 again and tested pads but theres no shorts there.
        11-07-2023, 09:44 AM
        DELL OptiPlex 3090 OptiPlex 3000 i5-1145G7 Specification for Upgrade or Repair
        This specification for the DELL OptiPlex 3090 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3090 boardview and OptiPlex 3090 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
        09-12-2024, 03:44 PM
