G703GXR Dead CPU? shorted CPU power mofset replace, missing DRAMRST#
  • pc_okay
    • May 2022
    • 241
    • FRANCE
    Hello friends,
    I replace a shorted mofset (PU8104), now laptop is starting but no display, stopping at DRAMRST#.
    Resistance to ground on PL8104 is around 1-2 ohm, quite low but voltage seems ok 0.995V
    Any help would be appreciated it's a nice laptop !
    Thanks. πŸ˜ƒ
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Not gone thru bdv/schematic. So PU8104 is DRMOS for VCORE phase? If yes, no point troubleshooting unless u want to replace the CPU.
    If what i assume is right, after replacing the DRMOS, laptop will get triggered with perfect normal behaviour and will seem like display is about to come but the wait never ends.
    Observe the consumption pattern on dc supply and you'll realise its a loop.
    • pc_okay
      • May 2022
      • 241
      • FRANCE
      Yes that’s it … sadly.
      I ll try to replace cpu and tell you later.
      thank you.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        If you can manage a compatible H cpu,its worth the effort if customer agrees.
        However, its very difficult to get an H cpu with same specs and usually customer dont agree with the steep bill.
        Personally, i've not replaced an H cpu yet though i've all the stencils.
        • Yanleb
          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
          by Yanleb
          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
          D608, good
          D618 RF101L4S, good (See warning 1 below)
          D619 RF101L4S, good (See warning 1 below)
          D865 RF101L4S, shorted (See warning 1 below)
          IC464 Inverter HA MC74HC1G14, shorted...
          03-09-2020, 12:00 AM
        • Shuasmith14
          330S-15IKB Components to replace along with shorted power MOSFET
          by Shuasmith14
          Hello. I'm currently working on a Lenovo Ideapad 330S-15IKB that has no power, no power light, dead. I found the schematics and I'm seeing proper voltage at the drain of the first DC IN MOSFET and nothing after. After doing some research and finding the power supply troubleshooting guide in this forum. I tested the second DC IN MOSFET and it's shorted from drain to source. My main question is since I'm new to doing this, I thought I heard somewhere that any time a MOSFET goes, you're supposed to replace the controller as well. That may not be right but I want to check if there's anything else...
          08-22-2021, 06:16 AM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
        • barry101
          Apple 820-3662 VCore shorted to ground.
          by barry101
          Hi, Would appreciate some help.
          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
          Get charger light but no fan spin or chime. No liquid damage.
          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
          06-24-2025, 07:34 AM
        • guizmo1967
          Dell Latitude 5501 LA-H181P shorted power rail
          by guizmo1967
          This is my problem:
          Laptop: Dell Latitude 5501
          Motherboard: EDC51 LA-H181P
          I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
          I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
          I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
          I injected +1.05V - 2A...
          07-25-2023, 06:56 PM
