GA-965P-S3 won't post
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    The motherboard won't POST, most of the time it won't even start properly - the PSU fan spins up but the CPU fan doesn't. It looks like it gets a little bit of power then the power is shut off.
    Last week I was able to get it to boot a couple of times with the CPU fan not spinning at all.
    All of the caps look OK but I'm still suspicious. Most are Nichion HM, a few Evercons, G-Luxons and two Panasonic caps (3300uF 6.3V). All 1500uF 16V caps around the CPU socket are Nichion HM H0609.
    Bad caps or not?
    UPDATE: I had some spare time so I decided to replace all four 1500uF 16V Nichions with Samxon GC caps.
    After I push the power button, the CPU fan starts to spin after 3 seconds. Still no POST, no beeps. Any other suggestions?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: GA-965P-S3 won't post
    More likely a bad socket pin, if 775!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • c_hegge
      • Sep 2009
      • 5219
      unlikely. It would be pretty obvious if that was the case. It's unlikely to be bad caps too. My money is on the chipset.
      • Half-Saint
        • Jan 2010
        • 213
        • Slovenia
        Is there any way to confirm this? Would bad chipset cause a delay in the mobo powering up?
        UPDATE: just checked and the CPU pins are fine. Also tried it with another CPU and two other PSUs but no dice.
        • crash-cyberdrive
          • Jun 2013
          • 62
          • US
          Have you tried verifying the basics Memory, Video Card. Sound to me like a MosFet is failing or already failed. But the same could be as simple as a cracked joint.
          A Picture of subject is always Welcome
          Things saved from the e-landfill:
          Vizio VA26LHDTV10T 26" - Bad EEPROM Cap
          Asus PTGD1-LA Full Recap - Cha1 DDR socket damage
          MSI PM8M3-V Unstable CPU Recap CPU VRM circuit
          ViewSonic VA712B - still working on it
          Kindle Fire USB Connector
          MSI G31M-F Full Recap - Record Breaker done in 3Hrs.
          MSI P67A-G43 BIOS chip Reprogram - Tested and Happy
          The list will go on thanks to the people of this forum and many hours of reading.
          • Half-Saint
            • Jan 2010
            • 213
            • Slovenia
            I tried it with known good video cards, PCI as well as PCI-e and known good memory modules. To me the symptoms look the same as when the separate 12V connector isn't connected.
              • 31014
              turn the pcb upside-down and power it up.
              then meter the voltage across the caps around the cpu.
              • Half-Saint
                • Jan 2010
                • 213
                • Slovenia
                I got 12V on 1500uF 16V caps, 1.3V on all the rest including both 3300uF 6.3V.
                  • 31014
                  then it sounds like you have the cpu voltage.
                  check the voltage on any regulator near the ram
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    I've fixed a few of those boards and it's either been the chipset/RAM regulator or the BIOS. Meter caps near the RAM slots and see if you get 1.8v on them. If you do, try flashing the BIOS.
                    A working TV? How boring!
                    • Half-Saint
                      • Jan 2010
                      • 213
                      • Slovenia
                      I get 1.8V on two out of three. Only get 0.9V on the last one. Is that normal?
                      Upon closer inspection, some elements left of the RAM slots appear to be covered in something sticky. Among them there are two K3918 transistors as well as 40T036H.
                      EDIT #2: BIOS is not socketed so I'd have to desolder it and put it back after flashing. Maybe someone has done it with UNIFLASH without removing the chip?
                        • 31014
                        and how would you run uniflash?
                        • Half-Saint
                          • Jan 2010
                          • 213
                          • Slovenia
                          I've read about people flashing the bios from floppy with a PC that wouldn't POST.
                            • 31014
                            that's using a recovery flasher in the bootblock of the bios usually.
                            most older boards dont have that.
                            • Half-Saint
                              • Jan 2010
                              • 213
                              • Slovenia
                              I'm seriously considering giving up on this board... spent too much time on it already. I don't have a suitable adapter for my Willem programmer so even if I managed to desolder the BIOS chip I wouldn't be able to program it.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Doesn't that board have a SPI flash? You can program it with a few resistors off the parallel port...
                                • Half-Saint
                                  • Jan 2010
                                  • 213
                                  • Slovenia
                                  I replaced one of the Samxon GC caps with a Panasonic FC 1500uF 16V and the board gets past POST now. I wonder, if Samxon GC caps are not a suitable replacement. I see that in some cases, Rubycon MBZ caps were used on this model and they seem identical to Nichion HM. Since MBZ caps are no longer made, would ZLJ be a suitable replacement?
                                  • Half-Saint
                                    • Jan 2010
                                    • 213
                                    • Slovenia
                                    Looks like one successful poly mod! Thanks to c_hegge for helping out.
                                    There's just one last piece of the puzzle. When you power it on, it doesn't start immediately. There's a faint click from the PSU then another one a second or two later and that's when it starts. The board goes past POST fine. I have yet to install Windows to see how everything runs.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      That's interesting I would never have thought it to be the caps. Samxon GC should have worked fine there. What brand/model of PSU are you using? I remember that my GA-EP45-DS3L would often do something a bit like that. When the power button was pressed, it would power on for half a second then off again. Then it would start properly a second or two later. If your PSU has a relay to bypass the NTC thermistor when it powers up, then the clicking as it powers on or off is quite normal.
                                      • mikail13
                                        • Aug 2013
                                        • 93
                                        • Turkiye
                                        and i have this board too. sent it to Gigabyte Turkey but they couldn't solve this problem. they changed CPU socket.
                                        after that i want to re-use solid caps around the CPU.
                                        all of them desolder and i see one is bad.
                                        and want to re-use mosfet near the rem slot that name's 40T03GH.
                                        i realise that they are under the voltages.
                                        must be 550 V but around 400 v.
                                        this is a good autopsy..
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
