RX580 MSI armor OC 8gb no post
  • chaos-theory
    • Apr 2024
    • 44
    • Africa
    I have a card that does post at all, the owner said it does go into windows but it gets stuck on the logo with artifacts, I have no idea if he is lying or not... I tried the card on my pc and it does not post at, no beeps, no bios nothing just all fans turning and nothing else. I tried plugging DVI or hdmi but nothing, I tried unplugging the 8 pin plug from the power supply and it's the same thing.
    I just want it to post and get into the bios at least.
    Forgive me if I am wrong, but I tested the 3 PCIe 12v power pins on the left(550ohm) and the 4th one from the right 3.3v (400ohm), and there is no short, i tested the 8pin connector (475ohm) on the power pins to ground, and I have tonl switch the multimeter probes so it doesn't show an erratic readings because of the capacitors.
    Now after my understanding of GPu repair these look fine, so I started testing coilsI will post pictures instead, because I dont know what most of them are for.
    Click image for larger version  Name:	IMG_20240418_091932.jpg Views:	0 Size:	1.20 MB ID:	3254979
    now I don't know if these coils are all for vram, since there are 8 coils and 8 memory chips I supposed they all should be the same, but the 2 on the left are reading differently?
    Click image for larger version  Name:	IMG_20240418_093130.jpg Views:	0 Size:	4.33 MB ID:	3254980
    I have several questions.
    - Can you power the card without the 8 pin connector? Does the PC boot and post without it, can anyone test this for me please.
    - What should I test next? I have read several articles and watched many videos, but I cannot pinpoint on this exact card.
    - Can a molex to 8pin adapter power this card enough to post? Since I have seen most people use it, and there are 2 12v pins connected to each other instead of being separate, does that do anything since i read somewhere that the gpu 8 12v pins are separate and not interconnected.
    thanks guys, and later I will be posting some close up macro images of the card for future reference in case anyone needs them as onboard view or to check for missing parts!
    PS: I have tried this card on another pc with an ASrock h61m and the same thing happens it just keeps spinning but at least some LEDs turn on on the PC but nothing no display and nothing.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3607
    • slovakia
    why dont u first see some videos on youtube, so u have some starting knowledge. there are hundreds of them. msi schem and BV are widely awailable so find them.
    PCIe power MUST be attached to post, else u dont have post o just screen that tells u that PCIe power is not connected
    u have low knowledge so u need to learn some things first
    • chaos-theory
      • Apr 2024
      • 44
      • Africa
      Thanks for answering one of my questions mate, I did watch plenty of videos but I could not apply it to this card, I couldn't find much about this MSI armor, most of them are sapphire and nitro+, if you're generous enough you can give me more resources.
      IF anyone can confirm about the coils resistance being different than others please do.
      PCIe power must be attached for this specific card? Does it show the "plug in power cables" screen, if anyone has this card please try it and reply to me.
      I have a background in electronics and programming but not much in gpu repairs.
      PS: the core was getting warm and hot enough when plugged! So I guess it's receiving power
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3607
        • slovakia
        if u watch some videos u know starting sequence and what to measure first
        • ductranvinh
          • Dec 2021
          • 127
          • Republic of Vietnam
          First: you need boardview (MSI) because MSI boardview can be same structure of all this brand model
          Second: you need road map voltage and mesure follow this
          Third: All High members are so uncomfortable because you didn't post the result after mesure, and can't how to help you.
          Road Maps Voltage for AMD Graphics Card
          12v Rail,3.3v Rail (have first, if 3.3v short stop mesure because gpu was dead)=> 1.8v => 0.9v at GS9230 (or GS9238,APW8713) => 0.9-1.1v GPU => 1.35-1.75v RAM => 0.9-1.1v Boot
          And result after when you were informed of block?
          12v Rail => ?
          3.3v Rail =>?
          5v Block =>?
          1.8v Block=>?
          0.9v Block (GS9230,GS9238,APW8713)=>?
          0.9v GPU Block=>?
          1.5v Ram Block=>?
          1.01 Boot Block=>?
          If all results are good last you flash bios on your graphics card
          The sub 12v from 8pin PCIE it supply for vrm 80% and main 12v rail supply for vrm 20%
          READ,LISTEN,WATCH BEFORE YOU ASK SOME THING
          PC work for schemaltic:
          Mainboard: Gigabyte Z68XP-UD4
          CPU: I3-3240
          Ram: 16Gb
          Graphic Card: GTX 1050Ti zotac 4Gb Mini
          SSD: 120Gb
          HDD: 2Tb
          • chaos-theory
            • Apr 2024
            • 44
            • Africa
            Alright I stayed late at night gathering information and reading around the forum and doing some trouble shooting, no matter what I did the card still doesn't post, I have read the beginners post and organisation rules and I have to agree that this thread is a disaster, is it possible to be deleted so I can make a more detailed and proper thread.
            now, to the point I found a broken resistor on the board, it's a 0 ohm resistor, as human nature I had the urge to just replace it from a car ECU, same thing.
            The card still doesn't post, here is the placement for that resistor
ID:	3255936this is the newly welded resistor in place a bit smaller but does the job.
            SO I measured all the 12v PCIe pins from the mobo and 3.3v and everything seems good, I also measured most voltage references requested, except for the BOOT block since i have no idea where to measure, and the different regulators blocks, I have gs7256, gs7103. which pins to measure?
            And my bios is 25x40clnig, and I read the pinout, but some people advice to short pins 1 and 8 and some other 1 and 5, and it doesnt work for me, but for shorting pin 1 and 5, 5 is SPI is that dangerous?
            So I measured the pins and some of them are 3.17 some have no voltage. After reading through the datasheet VCC max voltage for this chip is 3.18, so I guess it's too close to limits, can anyone confirm.
            I made a table which I will update soon and add the close up pictures of the board in case anyone needs them for reference in another thread.
            So I researched more about the 8 pin connectors of the rx580 and some people mentioned that the pc will boot normally if you dont plug the cables, I don't know if it's the same for the Armour MSI edition, and I tested the 8 pin connectors and they all have voltage,and every though I disconnect the 8 pins there is still power to the bios.
ID:	3255940Click image for larger version
            • ductranvinh
              • Dec 2021
              • 127
              VDDCI i call it vBoot
              CPU: I3-3240
              Ram: 16Gb
              SSD: 120Gb
              HDD: 2Tb
              • ductranvinh
                • Dec 2021
                • 127
                So the result you were mesure very beautiful. All block voltage not missing. Last work you need to do reflash the bios chip
                hai-ya..... you should connect 8 pin connectors. this port very important
                CPU: I3-3240
                Ram: 16Gb
                SSD: 120Gb
                HDD: 2Tb
                • chaos-theory
                  • Apr 2024
                  • 44
                  • Africa
                  That's the problem, the PC is not starting, there is no post, no beeping, nothing, just the fans turning at full speed, both the pc and the graphical card, I tried to short the bios at 1 and 8 pin but nothing, still doesn't post, should I short 1 and 5 pin
                  So what should I do here, I am in a corner and I have no idea where to go next
                  my Bios is W25X40WLCN and this is the pinout
                  • ductranvinh
                    • Dec 2021
                    • 127
                    you was tried reprogram bios chip yet ?
                    if you was, him was dead (GPU) or measure hertz by Oscilloscope make sure him real dead
                    CPU: I3-3240
                    Ram: 16Gb
                    SSD: 120Gb
                    HDD: 2Tb
                    • chaos-theory
                      • Apr 2024
                      • 44
                      • Africa
                      Thanks mate, the bios is not the culprit, I managed to boot the graphics card by throwing it into another motherboard and disabling CSM I will make a new thread to explain it in detail and to ask a new question, this thread can be closed! Thank you all for the feedback, it's greatly appreciated!
                      In case anyone is curious it's showing artifacts, dynamic artifacts here are some pictures
ID:	3256635Click image for larger version
                      • chaos-theory
                        • Apr 2024
                        • 44
                        • Africa
                        Hello, after I managed to boot my PC with the MSI armor rx580 OC 8gb with CSM disabled, i went durect and booted Linux mint in CLI mode, did both direct mem test and dmgg.
                        But dmgg is showing that all chips are faulty
                        ​​​But when I specify only 4 chips it says no problem all chips are good, now the lspci -v is showing this card as a 4gb card is that weird, was the bios tempered with or anything?
                        these are the results, thank you!
                        Card crashes when loading drivers and showing weird dynamic artifacting on uefi bios
ID:	3257297Click image for larger version
ID:	3257298Click image for larger version
ID:	3257299Click image for larger version
ID:	3257300Click image for larger version
                        • ductranvinh
                          • Dec 2021
                          • 127
                          So when you post picture with crash image,i think you should check with mats, and replace ram chip was fault. RX 580 so cheap. Try and get experiance
                          CPU: I3-3240
                          Ram: 16Gb
                          SSD: 120Gb
                          HDD: 2Tb
                          • ductranvinh
                            • Dec 2021
                            • 127
                            In my opinion,only replace ram chip for higher model begin rx 5000 series
                            CPU: I3-3240
                            Ram: 16Gb
                            SSD: 120Gb
                            HDD: 2Tb
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3607
                              • slovakia
                              i dont know how u get courage to advice something, when u advice test AMD card with mats. U better learn something before advice any of this crap
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3607
                                • slovakia
                                chaos-theory
                                this dmgg test is crap. never get normal result from it.
                                u can use tserver or agt
                                this picture can u maybe serve better, but rx580 have more problems with balls under gpu than bad ram chips
                                • ductranvinh
                                  • Dec 2021
                                  • 127
                                  chaos-theory
                                  it's ok! with me,i think rx 400 & 500 series usually i meet 80% ram chip fault when display signal out crash and 20% is fault at gpu. Thanks for your pic
                                  CPU: I3-3240
                                  Ram: 16Gb
                                  SSD: 120Gb
                                  HDD: 2Tb
                                  • chaos-theory
                                    • Apr 2024
                                    • 44
                                    • Africa
                                    Hello, I am back again, sorry for disappearing!
                                    I was working on an Asus motherboard which might have a bad PCH.
                                    So I had this Graphics card which seems to be showing something on the screen but it's full of artifacts, and I decided to make a new thread because I was in a wrong path!
                                    I reballed the A0 channel, and then removed both A0 and D1 vram chips and the card is still showing the same artifacts with only a bit of change on the corrupt lanes.
                                    I am starting to suspect the core.
                                    I tried tserver memfa test but it gives me an error : [error][Framework] Exception during attempt to execute test: TcoreSiliconTarget: Failed to load ME microcode using toollib on Tonga/Ellesmere
                                    I made some researches and it seems to be caused by either bad vram contacts or GPU contacts.
                                    So I went and did ./agt -mccfg
                                    And it's showing the vram manufacturer as UNKNOWN
                                    Very weird since it should show SAMSUNG, I researched more and some people implied that the channel A0 vram chips is responsible for defining the information about the vram chips, so I had to reball the vram chips, and saw that D1 has discoloration so I decided to remove it to to see if it's causing the artifacting, that's how I got here, the card is going into bios normally but full of artifacting without both vram chips present, and I still get the same errors.
                                    I didnt want to use dmgg because the results are not reliable in this case as it's showing all chips are faulty.
                                    I really don't know how to proceed, here are some pictures to show the artifacts with and without the 2 vram chips installed.
                                    Some of the artifacts are static and some are dynamic.
                                    Without vrams llvmpipe
                                    Caption
                                    Artifacts with vram installed
                                    Please keep this thread as it's very important to me, I have done plenty of researches and I need experience here instead of luck, thanks everyone!
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3607
                                      • slovakia
                                      Caption
                                      mostly bad solder joints under gpu
                                      • chaos-theory
                                        • Apr 2024
                                        • 44
                                        • Africa
                                        Have you encountered that error before? Do you think reflowing can solve this?
