Please Help!!
  • JenovaXP
    • Mar 2007
    Please Help!!
    hey i have an msi kt3 ultra ver 1.0 in front of me and i have an issue. it took me a while to find it but i can't identify this chip to replace it. i have some super high res photos for you here
    it's right by the cpu fan plugin inbetween the cpu and ram if any1 can help me identify the chip so i can replace it and get my comp back that'd be great.
    PS : btw i have plenty of dead boards for this sorta thing.
    http://www.imagehosting.com/show.php..._mobo.JPG.html
    just incase u cant see it
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Please Help!!
    looks to have once been an inductor .
    the markings above it are the part numbers.
    l= inductor.
    bet someone shorted the fan header.
    btw
    WELCOME TO BADCAPS!
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Please Help!!
      need someone with same board to test to see what spec the replacement devices are. pity it was the cpu fan header
      nice pic btw
      here is a crop of OA version board from here http://www.hwsw.hu/hir.php3?id=13973
      • Rainbow
        • Aug 2005
        • 1375
        Re: Please Help!!
        Just take the inductor of the same size from another dead board.
        • shadow
          • Feb 2007
          • 732
          Re: Please Help!!
          That would be ideal!
          Just need to get the value of the replacement inductor.
          I may be wrong but if this inductor was used solely for the CPU fan header, wouldn't it be a standard value. Would it have to be exactly the same value as the original?
          If the inductor does not have to be exact then you may not need to find out the exact inductance of the inductor and be able to just take one from one of your faulty boards and just stick it in even thou the value may be off.
          • Rainbow
            • Aug 2005
            • 1375
            Re: Please Help!!
            Try anything with the same size. It usually works as the value is not critical.
            • thesame
              DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
              by thesame
              Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
              The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
              02-27-2024, 04:31 AM
            • silver60618
              Lenovo Legion 7 - Help Identify IC
              by silver60618
              Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
              I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
              Any help would be appreciated...
              07-02-2025, 12:16 PM
            • chth96
              How can I identify varistor which have been blew up?
              by chth96
              I mistakely pluged 100v japanese retro game console to 220v outlet.
              So It seems that glass fuse and varistor have been blew up.
              I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
              Is there any way to identify varistor type in my sega saturn PSU?
              Any reply would be appreciated.
              EDIT:
              It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
              11-26-2023, 08:52 AM
            • freakorio
              Need Help To Identify Component on Ymain LJ41-05120A
              by freakorio
              Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
              05-21-2024, 02:32 AM
            • baiceanu_stefan
              nm-f251 Schematic, boardview or help identify componente
              by baiceanu_stefan
              Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
              04-24-2024, 12:49 AM
