Like the title states. I have done a successful recap of an MSI 694D Pro motherboard, complete with the C390 mod! And it was the first time I did such a thing!
It was damn hard to find appropriate capacitors down under, however I settled for Nichicon HE series capacitors. Works like a charm now. Before the recap, it would not run correctly with two CPU's installed. Took a very long time to diagnose the problem as a badcaps problem. Mainly because the motherboard was never run in two CPU mode in its lifetime!
Now I have another problem, I have no case fans for this case. So I bought a couple of 120mm fans. Due to negligence, I did not measure them. I knew that this case fits fans that are larger than 80mm since I had a 80mm fan lying around. The shop only had 80mm or 120mm fans, so I bought the 120mm one's. Only when I got back home did I actually measure the spaces for the fans on the case and was horrified that it actually took 92mm fans and not 120mm fans. Now I am thinking about modifying the case to fit 120mm fans.
What methods would anyone recommend to me in modding this case. I am unwilling to buy speciality tools that I would use once in 10 years!
So far the feasible options that I can think of is the following options:
* Just drill some holes around the existing perforation to increase airflow from the larger fan when fitted.
* Drill some holes around the existing perforation and take a hack saw and cut out a rough hole which I then could file down with a file. Long procedure but I have all the required tools.
* Make my own 92mm to 120mm transition.
I am unwilling to:
* Drill out the hole with a hole saw,great idea but these hole saws are damn expensive and I would use it once or twice in 10 years! I would go down this route if someone from Melbourne could possibly let me borrow a 4.5inch hole saw.
* Use a dremel or similar device to cut a hole, I am basically not willing to buy one, I also read that it is quite difficult to use.
* Use a jigsaw, do not have one, of all the speciality tools, this one I would most likely buy. I have also read that a fine tooth bit is required and it is quite difficult to cut a round hole.
Any ideas are welcome!
Btw, sorry the pictures that I took are quite large and not exactly high quality.
I am unwilling to:
