Abit VT6X4 problems
  • Sammy
    • Jul 2004
    Abit VT6X4 problems
    Hi everyone
    A great deal of good information on this site. Has anyone had experience with the failure rate of the Abit VT6X4?
    After system freezes using some graphics programs and going through all the usual procedures to locate software and/or driver problems, uninstalling/reinstalling, w2k repair, and more, the next step was the hardware. Memtest shows lots of errors on tests 5 and 8, nothing on the others. I happens with all modules, alone or together. The error shows up when sending either ffffff7f or fffffff7, and getting ffffffff back. I dont play games on this machine very much, except for tying out simcity4 for awhile. But I do alot of graphics work and 3D rendering.
    A kind soul suggested checking out the motherboard capacitors and sent a picture of what to look for. Sure enough one of them was bulging at the top, like in the picture. But no leakage. The offending part (if this IS the whole problem) is black with a gold stripe.
    The bad part is listed as EC19. Anyone know what this one is used for? Could this one part be the problem? Of course the board is already quite old by todays standards... around 5 years I think.
    Thansks :roll:
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    If one cap has swelled up, I guarantee there's more than 1 bad cap, even if only one is showing signs... I would replace all your caps 680uF and up. This will guarantee that you get all the bad ones.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Sammy
      • Jul 2004
      How messy/delicate of a job is it to do? Im pretty handy with various types of repair work large and small (no electronic boards tho), but it might be worth it to send it out for repair so I am certain it would be done correctly. I fear I might break something fragile. Also, there is always that little voice that tells me something else might be contributing to the problem. Probably not, but that voice tends to nag alot 8)
      • drchaos67
        • Nov 2008
        Re: Abit VT6X4 problems
        My VTX64 failed recently. Even with bulged caps it had been reliable for years. Symptoms were a very long wait with constant resets before the system would POST. I replaced all the 1000uf 10V caps with Nichicons (DigiKey part 493-1747-ND). Soldering and desoldering were a chore due to tight lead-hold clearance and the thickness of the motherboard. Upon reassembly the system POSTed and booted immediately. Victory!
        Dale.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          had one in a surface grinder last week.
          recapped it and got rid of glitches the operator had been living with for several years.
          the breaking point to spend the money on it came when it started moving without command and slammed the hard stops.
            by Vesko356
            08-11-2023, 03:27 AM
          • jean luc ferre
            laptop hp g72 b52sf screen problems
            by jean luc ferre
            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
            06-07-2025, 03:27 PM
          • Hondaman
            USB problems?
            by Hondaman
            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
            08-12-2024, 03:26 PM
          • clabr
            Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
            by clabr
            Need help to solve some problems with this laptop.
            After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
            After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
            Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
            Before this had happened I observed some other problems:
            When I tried replacing original mecanical HDD with a SSD HDD could not get them...
            12-02-2021, 08:09 AM
          • Foetuss
            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
            by Foetuss
            Hi all
            Hope this is in the correct place.
            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
            Could use some double checking to see if I'm not doing something stupid .
            Pictures of the boards are attached.
            What I will be replacing with what : (planned)
            Soltek Golden ::
            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
            01-18-2025, 11:44 AM
