[HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
This is a sticky topic.
    master hoarder
    • May 2008
    • 12170
    #81
    Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
    Originally posted by mockingbird
    Does anyone know how to fix "New CPU is inserted in your system !"?
    According to our Romanian friend, Th3_uN1Qu3 , this should be another transistor, just like with the chassis intrusion .
    Extra bit of fun info: The transistor right next to it will make the board report "New CPU installed!" every time until you clear CMOS, if you touch it or probe it. But at least it lets you boot the system.
    That is post #5 in the first page. Linked here for convenience:
    https://www.badcaps.net/forum/showpo...86&postcount=5
    Now, as far as how to find that transistor... I haven't a clue! But probably some SOT-23 transistor either near LPC Super IO chip or perhaps even CPU socket itself.
    • mockingbird
      • Dec 2008
      • 5484
      #82
      Thank you my friend. He gave great instructions on finding the chassis intrusion detection transistor, so it should be located adjacent to it, but you're right, personally, I have no way to be certain at the moment.
      So I came up with an easier solution (Will not work with chassis intrusion, but should with "New CPU detected"):
      So hardwiring that in there should bypass the message permanently. And I also disabled "Express Gate", because it also seems to re-trigger it (But all the other options stay put IIRC).
      • drag
        • May 2016
        • 18
        • finland
        #83
        Hard to give you more advice how to repair it without pictures and more info. Need to know what you shorted, what the motherboard does now, etc.
        Worst case, put it on eBay for sale as "parts or not working" and mention the problem.
        I start PC and motherboard working fine! Its not broken afterall
        I not found 3.3.v supply but I found 5v. supply. Is 5v supply be good enough or is it too much?
        And motherboard battery has 3v. Can I use it somehow?
        I think i can remove battery case from old motherboard and connect it straight to Asus P6T SE chassis
        intrusion connector.
        Sorry for my bad english.
          master hoarder
          • May 2008
          • 12170
          #84
          I don't know if 5V would be too much - that depends on the LPC SIO chip.
          But just take 3.3V from one of the orange wires on the PSU connector - that's 3.3V for sure, so it should work fine.
          No, don't use motherboard battery for anything.
          • drag
            • May 2016
            • 18
            • finland
            #85
            I was thinking that too. But can i just take one of the orange wires? I think that all power supply wires must be connect to motherboard?
              master hoarder
              • May 2008
              • 12170
              #86
              I'm not sure I understand what you mean by this.
              Just use your multimeter to find a 3.3V source near the ATX connector and run a wire from that to the Drain of the Chassis Intrusion MOSFET. Make sure the Gate of that MOSFET is grounded, otherwise that MOSFET will try to pull 3.3V rail to ground and *will* burn out.
              • drag
                • May 2016
                • 18
                • finland
                #87
                I remove the Chassis Intrusion transistor and then I run a wire from ATX connector (3.3v) to that spot and...
                THAT WORKING
                But Windows 10 then makes some updates and reboot and...
                HORRIBLE CHASSIS INTRUDED ERROR SHOWS ITS FINAL POWERS AND APPEARS ONE MORE TIME
                Then I boot again and now Asus P6T SE working almost normally
                Its been a very interesting project and thanks to momaka who helped me!
                • drag
                  • May 2016
                  • 18
                  • finland
                  #88
                  Accidentally wire from ATX connector disconnect but motherboard still works normal and not showing chassis intruded?
                  Is the wire useless?
                  I have wrong bios (P6T WS) if its matter.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    #89
                    The transistor may stay charged for a while and thus not show the error. Best to keep the wire connected.
                    A working TV? How boring!
                    • virus023
                      • Aug 2016
                      • Thailand
                      #90
                      I have Asus P5QL-E with Chassis Intruded Fatal Error...
                      Can I fix it by the same as P5QL
                        master hoarder
                        • May 2008
                        • 12170
                        #91
                        Yes, very likely.
                        If you read the entire thread, Th3_uN1Qu3 mentioned that this problem possibly affects many other ASUS P5___ motherboards.
                        • virus023
                          • Aug 2016
                          • Thailand
                          #92
                          Yes, very likely.
                          Thank you.
                          If I replace the Chassis Intrusion transistor that from another p5ql-e motherboard will fix this error ?
                          I have 2 of p5ql-e ,1st work with Chassis Intruded error and 2nd can not turn on
                            master hoarder
                            • May 2008
                            • 12170
                            #93
                            I don't think the transistor is the problem with these motherboards. Rather, it is the Super I/O's pins having a really weak pull-up current. Thus, even the transistor from the "working" motherboard might not work.
                            Again, it is best to apply 3.3V to the Drain of the chassis intrusion transistor (preferably through a 100-1000 Ohm resistor to avoid damage if you accidentally short-circuit something) and ground the Gate of the same transistor (if you are NOT going to ever use the chassis intrusion function.
                            The second motherboard might have a different problem if it doesn't POST.
                            • virus023
                              • Aug 2016
                              • Thailand
                              #94
                              Thank you,momaka.
                                master hoarder
                                • May 2008
                                • 12170
                                #95
                                No problem. Please let us know if you got your motherboard working. Would be good to see if another motherboard was saved.
                                • yudhistira
                                  • Indonesia
                                  #96
                                  hello, I have same problem with my old asus p5pe-vm, no chassis intrusion connector on this board
                                  I have observed near winbond chip area, and I found no transistor, it has a solder pad but no transistor soldered on it
                                  this board use winbond W83627 series on it, I have looked on the datasheet and found that pin 76 on this chip is controlling CASEOPEN# function
                                  what can I do now? I have no idea how to fix this old board
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    #97
                                    Connect pin 76 of the WinBond W83627 chip to 3.3V with a resistor (anywhere between 1 KOhm and 100 KOhm should be okay).
                                    • rstudio
                                      • Apr 2017
                                      • Portugal
                                      #98
                                      Originally posted by fu-raz
                                      So, there we go... Thanks for the help Th3_uN1Qu3! Found a new 3.3v point, cleaned the board and reset the CMOS. Everything is working now.
                                      In the attachment is my final solution for the Asus P5E Deluxe
                                      I think i save my board too.
                                      It's a asus p5E and in the board are print maximus formula, i have done exactly what you do , and i think it's work.
                                      I have reboot 3 times and no error, let's see, cause i have to put the cooler in processor, so i can't test to much time right now, but so far so good!
                                      Thank you
                                      • fixr
                                        • May 2017
                                        • canada
                                        #99
                                        Thanks, for the instructions to repair the chassis intruded error. I have an Asus P5KC and did the fix, however, it turns out jumping 3.3v back to the transitor pad was unnecessary. When I connected back the pin chassis intrusion connector it would not boot, so I unconnected it and boots fine with the exception that if I disconnect the power cord then the bios settings are lost.
                                        • Galvatron
                                          • Jun 2017
                                          • 5
                                          • polen
                                          #100
                                          Is there any way of fixing it without removing transistor and soldering wire? I had this problem before and somehow things started to work fine after some time, all by themselves. But the problem is back again, and I have no idea what to do.
                                          Also, does anybody have transistor/3.3v locations for P5B-Deluxe? It was one of most sold P5 boards out there. Pics are easily available on google images.
                                          • playit
                                            ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                                            by playit
                                            my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                                            my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                                            few years back ps2 mouse stopped working, but ps2...
                                            12-23-2024, 06:05 AM
                                          • harp
                                            Howto open schuco rubber plug
                                            by harp
                                            Oh, sadly it has no screw...
                                            What is the proper way to open this so that not destroy rubber?
                                            I feel if go on forward with not knowledge howto open, that it be broken rubber seal on it....
                                            12-16-2022, 02:35 PM
                                          • OKRPKCOMP
                                            B85m-e rev 1.02 chassis intrude error
                                            by OKRPKCOMP
                                            Asus board B85M-E bios is ok, motherboard is ok, everything is fine but i am facing this error at startup
                                            Chassis intrude,pls check yours system
                                            Fatal error, system halted
                                            Remember, there is nothing in bios setup to disable chassis error. Anybody can help me to solve this prob
                                            Thanks in advance...
                                            07-20-2022, 10:12 AM
                                          • vishal24
                                            Lenovo ideacenter B320
                                            by vishal24
                                            I m Having Lenovo Ideacenter B320 all in one.
                                            when i Press F1 for BIOS, Asking for password. after 3 times wrong password, give error Fatal Error System Halted.
                                            i forgot my bios password.
                                            08-10-2021, 03:18 AM
                                          • angelos
                                            LG 42" Plasma TV - Howto invoke AUtO GEN?
                                            by angelos
                                            I got in this beast of a tv of which i am needing advice on how to access the AUTO GEN function so that i can test if my main board is perhaps faulty.
                                            There is a 4 pin plug on the plasma control board but i don't know what to do there and i cannot find any reference on the web to it.
                                            I have added photos to jar your memories...
                                            This is PDP42V8 chassis.
                                            Any suggestions would be greatly appreciated.
                                            Angelos...
                                            06-07-2020, 10:10 AM
