I have p4sd v1.09 motherboard i bought from local store for cheap rate. i think this hp oem board.i found ther are 7 bulged capacitor(1800uf 6.3volt) near vrm section of motherboard( output of vrm ) before powering up i just removed those cap. i replaced with just 3300uf 6.3volt and 1500uf 6.3volt bcz i want to know this motherboard will work or not. i just powerd with just those 2 cap. succefully the motherboard booted. then i removed those cap and replaced with 1800uf 6.3v. but this time motherboard turn on after power pins shorted but no boot screen. then i agian cmpletly unpluged psu and pluged agian powerd mothrboard ,this time motherboard not turnd on but after 5 second its automaticaly power up fan spin but no boot screen also error code zero on debug card. then i again repeat same procedure but motherboard not power on at all. so i am expecting some strange problem on this board after recapping. pls help me to solve this problem. i am appreciating your answers
P4sd v1.09 not powering on
Re: P4sd v1.09 not powering on
what brands/series did you replace them with?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
i replaced with yageo capacitors. i check in datasheet and they are suitable for vrm output. so i think cap is not issue.somthing other problem. this board have security port and hood sensor. is it need to be connected to turn on mb properly? but its worked without these connection when i tried first time. also some times its turning on( occasionaly only) but no post screen. also pci debug card showing error code zero.Comment
This is the complete cap layout of the P4SD in case you need it (and also shows how to do a poly mod):
https://www.badcaps.net/forum/showthread.php?t=23503
Check the CMOS battery with the battery out of the board. These motherboards like to drain those CR2032 batteries fast! When that happens, you can get all sorts of weird behavior.Originally posted by srt1then i agian cmpletly unpluged psu and pluged agian powerd mothrboard ,this time motherboard not turnd on but after 5 second its automaticaly power up fan spin but no boot screen also error code zero on debug card.Comment
The cmos battery is new and also i checked its viltage its 3.1volt. Also i go through above thread but its didnt help me.wen i press power button the hard disk led lit wen i realse it it off.but some times motherboard power up ( occuring very rarely)after pressing pwer button and taking long time to power on almost 10 seconds but error code 00 on bebug card.This is the complete cap layout of the P4SD in case you need it (and also shows how to do a poly mod):
Check the CMOS battery with the battery out of the board. These motherboards like to drain those CR2032 batteries fast! When that happens, you can get all sorts of weird behavior.Comment
In that case, I would suspect the Yageo caps you used are not suitable (also Yageo = Teapo, and Teapo fail quite often). I think I've had only 2 or 3 of these boards give me problems. 2 of then had some kind of short that would trip the 5VSB of the power supply, so the boards could never power on. The other 1 would power on but never detect any drives. This is out of about 15 systems I recapped.
So bottom line is, you probably just need better caps like Nichicon HN and HZ. I highly recommend using polymers - at least around the CPU because everything in that area gets very hot. Also post a picture or two of the board if you can.Comment
i removed yageo now i am using capxon and 2 numbrs teapo in vrm .if i get panasonic or nichicon cap i will replace it later. this board now power up some times wen i plugged psu in power socket without pressing power button( need to wait almost 30 to 45 mintues to get power on next time). but error code 00 on bebug card . then i touch near the area of south bridge (around the 32 ghz crsytal) surprisingly motherboard strtd posting. wen i touch each time the post code changing and display came
. so i am suspecting some other invisible problem on it. i have a compaq bd-70g motherboard that also have same problem first time need to touch near crystal area to get post. but now after couple of hours working motherboard is fine now its perfectly working ,no need to touch anywere.anyone know what could be the reason for this type problem?i will
post pictures tomarrowLast edited by srt1; 09-21-2013, 11:29 AM.Comment
CapXon is probably one of the worst capacitor brands you can use. They are guaranteed to fail.
Also, you can't just use any Panasonic or Nichicon capacitor. You have to make sure the specifications match or exceed those of the original capacitors. In that case, you would be looking for Nichicon HN and HZ series. But those have been discontinued, so you are better off with polymers.Comment
Asus P4SD-LE-C Motherboard Schematic
ASUS P4SD-LA (HP OEM) is a motherboard based on the Intel 865G...-
Channel: Schematics and Boardviews
10-21-2024, 05:51 AM -
by Nagy DanielHi,
I'm new in the world of repair, and I have a laptop that does not turn on.
I don't know exactly the past of this laptop, I got it in a non-functional state.
The LDO3 and LDO5 are present, and it provides 3.3 and 5V.
When I started to diagnose the motherboard, the regulator for the LDO3V and LDO5V was quite hot, I checked it with a thermal camera, and the 3V from the DNBSWON was missing, so I replaced the IC Chip from a donor board (the ic chip is from the same type of motherboard)
Now, the regulator is fine, it's not heating,... -
by duravenHello! Embedded Software Engineer here, for fun trying to investigate a friend's laptop not powering up problem – first time opening a laptop.
- The physical power button has been broken on the laptop and the friend advised that they needed to poke the area with a pen to get it to start
- Eventually the pen poking stopped working and now the laptop does not power on at all.
I have stripped down the laptop down to the motherboard but I cannot simulate the button press or otherwise see anything happening when the power is applied.
Motherboard model TT 94V-0 E326167 <see image... -
by glovecapsHello,
I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by DocusHi everyone 😀,
I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:- I already own the exact same model, but its plastic chassis is badly damaged.
- Loading...
