Asus P7H55-M LX missing fet
  • chad720
    • Jan 2011
    • 16
    Hi there!
    I recently got an asus P7H55-M LX mobo, with a missing mosfet.
    The one missing is at position PU203, and I can´t get a high res pic so I can´t identify it, so I´m asking if any of you have one to please tell me wich code does it have.
    To further references, I´m adding a pic with the position of the mosfet.
    Thanks in advance
    Chad.
  • chad720
    • Jan 2011
    • 16
    Re: Asus P7H55-M LX missing fet
    nobody? anybody? please help...
    • c_hegge
      • Sep 2009
      • 5219
      I have the non-LX version of that board (P7H55-M). It's slightly different, but I think I might have located the equivalent FET on it. On the board I have, it's between the two PCI-E X1 slots. It's a BCD Semiconductors AZ1085D.
      • spleenharvester
        • Mar 2010
        • 902
        Is the board malfunctioning? What does it do?
        Different revs of the board may have certain parts removed. Are you sure there was a MOSFET there, even though soldered pads are present?
        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
        • Duncanbest
          • Jul 2012
          • 81
          • Taiwan
          FYI
          http://diy.yesky.com/uploadImages/20...S_DSC03113.JPG
          UTC UZ1085L
          • chad720
            • Jan 2011
            • 16
            Many many thanks to all of you!! I will buy (or recicle from scrap) this 3A ADJUSTABLE/FIXED LOW DROPOUT LINEAR REGULATOR and see how it goes... I will keep you updated.
            Thanks and good luck!!
            Chad
            • chad720
              • Jan 2011
              • 16
              hi guys! how´s everyone? I have tested with two diferent 1085AD (adjustable) with no luck, fet overheat and the power led light but dim... if I try without that fet power led bright well but I think I have no power voltage as it doesn´t start.
              Does any of you have the shcematic for this mobo? or know how that 1085 should be working? no short on board, maybe a cap is bad or something.
              Any help would be really apreciated
              Thanks for reading and good luck
                • 31025
                check for shorts between ground and the output pad/pin - it may be a bad ceramic capacitor.
                • Chewy6288
                  Asus FA506QE missing MOSFET
                  by Chewy6288
                  I recently bought this laptop to try to fix up because it was so cheap. It has no power so I figured it was a MOSFET or cap issue so I started with taking it apart, but when I had it apart I noticed one of the MOSFETs was missing. I'm new to this so I don't know where or how to look up what to replace it with. I do have the boardview for it so I somewhat know what was there which I attached ,and the missing piece is PQ303....
                  07-30-2025, 07:24 AM
                • khabib
                  ASUS STRIX G531GT MISSING PM_SLP_SUS#
                  by khabib
                  Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
                  here what i measure already:
                  EC_RST# 3.3V
                  SRTCRST# 3v
                  +3VA_RTC 3V
                  RTCRST# 3V
                  ME_SusPwrDnAck 0V
                  AC_PRESENT 3.3 V
                  AC_IN_OC# 0V
                  PS_ON 3,3V
                  +3VA_DSW 3.3V
                  DPWROK_EC /R 3.2V
                  PM_BATLOW# 3.3V
                  SM_INTRUDER# 2.8V
                  PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
                  THat is can confirm PCH relate issue...
                  05-28-2024, 01:30 AM
                • gurj1979
                  Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                  by gurj1979
                  Hey guys.
                  Need help with this one.
                  Fan not spinning due to missing PWN Fan signal.
                  Also 5 seconds from powering up it freezes, unless in BIOS.
                  But as soon as Windows starts to load, it will freeze.
                  CPU is COLD / Room temp when it freezes.
                  I've replaced the CPU, same problem.
                  Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                  Replaced fan - same problem.
                  Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                  Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                  08-19-2024, 05:22 PM
                  ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                  This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                  09-07-2024, 02:50 AM
                  ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                  This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
