MSI Master2-FAR7 (MS9617) multiple problems
  • tmiha71
    replied
    Re: MSI Master2-FAR7 (MS9617) multiple problems
    Is this a single VRM for both CPU-s (all FPCAP in parallel) ?
    Nice fun ahead...
  • Uranium-235
    replied
    with the exception of the KZG's in IMG_3089, they're all good caps. I actually have this exact same motherboard /w 2 opteron 240's, still in working order
    still not sure if its the caps though, have you tried a different video card? PSU? Taking everything out but the bare minimum and seeing if it works from there?
    "System date loss after extended power loss"...
    replace the CMOS battery?
  • Hadakajime
    replied
    Sorry about the delay, turns out it was too difficult to compile this post on my iphone during the bus ride home.
    Here are the photos a little larger, with links to flickr if you want to see them in full resolution. Sorry the thumbnails are a little large..
    IMG_3078
    IMG_3079
    IMG_3080
    IMG_3081
    IMG_3082
    IMG_3083
    IMG_3084
    IMG_3085
    IMG_3086
    IMG_3091
    IMG_3087
    IMG_3089
    IMG_3090
  • Hadakajime
    replied
    Oops sorry about the pics, I thought they would link through to flickr. I'll try fixing that now..
    The only measuring tool i have on hand is an old multimeter that needs a new battery.
    An interesting note on the dropped keys is I don't remember it occurring with board #1
  • DJduck
    replied
    The pictures are tiny for some reason
    Do you have an ESR meter? Sometimes caps go bad without bulging.
    And yes, KZG are defective, and so are KZE.
    Keyboard dropouts- software issue probably
  • Hadakajime
    started a topic MSI Master2-FAR7 (MS9617) multiple problems
    Hi. I just found this site a few days ago.
    My system has had multiple problems since I got 2 of these motherboards secondhand some years ago. I have always thought they were just crappy BIOS related problems. I do not overclock the CPUs. I have tested very briefly but it eventually bluescreens. However, I have enabled Catalyst Overdrive for the video card and have had a tremendous amount of success with it. It is extremely important to note that the problems experienced occur regardless of Overdrive being enabled or not, and I have not been able to prove any direct link between Overdrive and any stability problems.
    I am posting here for help determining if it is all likely NOT cap related, otherwise I will be sending it off to the badcaps workshop.
    Here is the MSI (manufacturer) web page for the board:
    link: MSI K8T Master2-FAR7 (MS9617)
    First, here are the system specs:
    • Latest BIOS at 1.2
    • New CMOS battery
    • MSI K8T800 Pro Master2-FAR7 (MS9617)
    • 2 x AMD Opteron 290 @ 2.8GHz
    • 2 x Thermalright Venomous X-RT SB-E
    • 2 x Scythe Gentle Typhoon 1850rpm
    • 2 x Infineon 1GB HYS72D128320GBR-6-B (ECC disabled)
    • HIS Radeon HD 3850 512MB @ 720/950MHz
    • Arctic Accelero Xtreme III
    • Creative X-Fi Elite Pro w/ console
    • 2 x WD RaptorX 150GB (RAID 0 onboard)
    • Seagate 60GB PATA backup drive (second channel)
    • FSP Aurum CM Gold 750W
    • Samsung SH-B123A BD-R/multi (via the SiI3214 controller)
    • Antec 1200v3
    • Corsair Dominator Airflow RAM cooler
    • Silicon Image SiI3124 SATA controller
    Here are some photos of the caps. It's not all of them, just to show most of the different ones used. I didn't take the tiny surface mounted ones. I think the fat yellow ones might look a bit questionable, but all the rest have very flat tops and no stains on the board. So there aren't any obvious visual signs, unless those yellow ones are clearly bad (?).
    From what I've briefly read, those KZGs are very troublesome, correct?
    Both boards share a lot of the symptoms, however #2 is clearly worse than #1 in terms of crashing. #1 only had infrequent random hard crashes, or reproducibly with 48hours after mains power loss. #2 experiences reproducible hard crashes whenever certain tasks are performed.
    What I mean by "hard crash" is the system is performing normally with no prodromes of a crash, then it's as if the power cord is suddenly unplugged and the system cannot be powered on until the CMOS is cleared. Hard crashes are the same for both boards. Generally the system will be pretty stable against the "infrequent" crashes once the CMOS has been cleared and BIOS reset.
    Here is a list of symptoms board #1:
    • No USB standby power
    • No ethernet standby activity
    • No residual standby power - unplugging from mains then immediately powering on results in no brief spin up
    • Changing some BIOS settings results in system date loss (I think enabling the SATA controller - possible BIOS bug?)
    • Booting with any disc in the BD drive results in the drive option being corrupted in BIOS. It shows up as blank or as unrecognisable chars in the BIOS device list (possible BIOS bug?)
    • System date loss after extended power loss (either minutes or hours?)
    • Hard crash within 48hrs after power loss
    • Infrequent random hard crash
    • Cannot load Windows with more than 1GB RAM in each channel (reset/bluescreen)
    • Any hard crash requires clearing CMOS before system will power on again
    Here is a list of symptoms board #2:
    • No ethernet standby activity AFTER a hard crash
    • Hard crash when performing particular tasks (REPRODUCABLE!) - Eg. Installing Tribes Ascend via steam, loading specific websites (not pr0n), applying a specific photoshop filter, I noticed once when doing Windows update with heavy RAID activity, I remember a total of 2 times during Windows update
    • Keyboard dropouts - keys stop responding in counter strike global offensive. Does not happen in Doom 2 (zDoom)
    I hope I haven't forgotten much.
    Like I said before, if it's obviously NOT a cap problem then I won't be sending it to the badcaps workshop.
    Regards
  • cappernicus
    Satellite r945-p440 - Hard crash coming out of sleep
    by cappernicus
    Toshiba Satellite r945-p440
    Motherboard: FAM2SY2 A3256A
    I do not have a schematic or board file
    I usually let it go to sleep every time I use it because it is nearly always plugged in, with occasional shutdowns to reset things. Then it started to hard crash every time it tried to come out of sleep. The lights would come on for half a second but before anything shows on the screen they would all shut off and it would boot up as if I had shut it down completely (except that windows knows it didn't), and when it comes back on the fan ramps up to full and stays there perpetually...
    04-16-2025, 05:31 PM
  • federalhouse
    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
    by federalhouse
    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
    **Background:**
    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
    **What I've Tried So Far:**
    1. I accessed
    08-01-2024, 07:03 PM
  • ash91
    Hp pavilion 15 not detect hard drive
    by ash91
    Hello gentelmen .... this is my first post and sorry for my bad english,
    so my proplem is my laptop keep losing hard drive even if i but the
    hard disk in the cady (the box that can replace the dvd rom with hard disk)
    when i turn the laptop on the massage that said no boot media found pop on
    the hard disk is fine and to be sure i try another hard
    i also update my bios to the last update
    the 5 volt is present on the hard connector on the motherboard
    the dvd rom work fine when i but a windows dvd in it
    also when i boot from flash...
    06-07-2023, 01:45 PM
  • madura2010
    DAY11AM6E0 hard disk drive and optical disk drive not detected
    by madura2010
    Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
    i checked the connectivity of ribbon=good communication with hard and motherboard
    changed hard disk and checked=3f0 error persist
    sata power=+5v available
    Then checked data capacitors=all good
    Then checked data lines path connectivity to pch=all good
    reflashed...
    03-12-2023, 09:09 AM
  • jean luc ferre
    laptop hp g72 b52sf screen problems
    by jean luc ferre
    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
    06-07-2025, 03:27 PM
