GA-7VKML Mother board .
  • aanan
    • Dec 2010
    • 222
    • India
    GA-7VKML Mother board no display cpu fan start power supply ok ram check
    other board its ok .please suggest how to trouble shoot. & schematic.
    Thanks.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: GA-7VKML Mother board .
    check for bloated caps. I saw a few pics looking up the board online with bad caps
    • aanan
      • Dec 2010
      • 222
      • India
      Thanks for reply uranium-235
      i check all ready all capaciter i need schematic this board.
      • Sparkey55
        • Jan 2010
        • 1523
        Thanks.
        sometimes when I run into a problem like that you have to "Dumb Down" your hardware. Try setting any jumpers onboard that set the CPU Bus Speed to a frequency that is at least one step LOWER than the actual cpu that is installed. That might get the vga to light up and get you into the BIOS. Make any changes then shut down turn off power and set jumpers to correct positions.
        • crash-cyberdrive
          • Jun 2013
          • 62
          • US
          Have you tried a PCI VGA card? I have a spare card for those kind of things and it do work most of the time.
          A Picture of subject is always Welcome
          Things saved from the e-landfill:
          Vizio VA26LHDTV10T 26" - Bad EEPROM Cap
          Asus PTGD1-LA Full Recap - Cha1 DDR socket damage
          MSI PM8M3-V Unstable CPU Recap CPU VRM circuit
          ViewSonic VA712B - still working on it
          Kindle Fire USB Connector
          MSI G31M-F Full Recap - Record Breaker done in 3Hrs.
          MSI P67A-G43 BIOS chip Reprogram - Tested and Happy
          The list will go on thanks to the people of this forum and many hours of reading.
          • luke10050
            • Mar 2013
            • 209
            does it make any beeps when it starts up?
            • aanan
              • Dec 2010
              • 222
              • India
              no beep when it starts up.
              thanks
              • Sparkey55
                • Jan 2010
                • 1523
                You can download the manual and drivers from Gigabytes website. More info would help us help you. Like what cpu, memory modules, PSU wattage, etc. are you using? Also have tried doing what I suggested earlier?
                • Sparkey55
                  • Jan 2010
                  • 1523
                  If you can not download the manual i will supply it here.
