IBM Netvista 8309-16A recap
  • stevo1210
    • Oct 2006
    • 4156
    Hey there,
    I have an IBM Netvista 8309-16A motherboard which i have successfully recapped. I only got one problem, the newer cap is bigger than the old cap, therefore it touches some of the SMT components around it. Currently it just touches the side of a transistor which is the size of a rice grain. Does this pose a problem?
    The computer is booting and running fine btw.
    I just hope that the transistor doesnt fall off one day....
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: IBM Netvista 8309-16A recap
    As long as one of the legs of the cap is not touching anything, you should be OK. If in doubt, try insulating it.
      ASUS P5GC-MX motherboard recap
      by momaka
      Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
      So here is what the motherboard looked like with its original caps:
      CPU VRM area up close…...
      01-27-2021, 11:59 PM
    • magneh
      Behringer Eurolive B205D repair - help identifying transistor
      by magneh
      Hello
      Got this speaker from a friend , defective. Power led comes on and off , in a loop.
      Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
      After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
      I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
      Still, I need to replace this transistor....
      06-18-2025, 02:34 AM
    • elsomer
      help to identify transistor msi ms-15ck1
      by elsomer
      hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
      02-17-2025, 05:30 PM
    • rddube
      Help with blowing transistor NAD T752 receiver
      by rddube
      I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
      Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
      I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
      09-01-2022, 05:19 AM
    • amigo744
      xbox series x u82 5 pin transistor voltages ?
      by amigo744
      hello there,
      xbox series x hdmi u82 transistor 5 pin,
      can anybody tell me voltages of this transistor in standby and power on mode ???
      on which pin of this transistor are the voltages ?
      regards
      08-16-2023, 08:05 AM
