Chipped mosfet on P8Z77-V
  • Rob
    • Oct 2005
    • 47
    Long time no see
    I have a question regarding a mosfet I received on an open box P8Z77-V. The surface is chipped on the top. Could this cause trouble to the motherboard?
  • mockingbird
    • Dec 2008
    • 5484
    Re: Chipped mosfet on P8Z77-V
    No, I don't think so. Is gate shorted to source?
    If you need to desolder it and replace it, I can offer a tip: use a 60w+ iron. Better yet, use two irons. I ripped off pads trying to take one off with a lesser wattage iron after my 60W bit the bucket, and now the motherboard is finished.
    "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
    -Leonid Brezhnev (On the Yom Kippur War)
    • Rob
      • Oct 2005
      • 47
      If you think it won't cause issues I will certainly give it a shot. I just want to make sure it won't damage the motherboard.
        master hoarder
        • May 2008
        • 12160
        I would say just check the MOSFET first. If no short between the terminals, it should be fine. Usually the die of the MOSFET is much smaller and the chipped corner you see is only part of the case and won't affect the operation of the MOSFET... unless the MOSFET was hit so hard that the Gate terminal became disconnected. Either way, fire it up, and you will see. If the MOSFET is open, the motherboard either won't power up or if this MOSFET is used to control power for a certain device, then you won't get that device working. Unlikely you'll damage the motherboard, though.
        Also, since this was an open-box item and you saw that MOSFET chipped, visually inspect everything else on the motherboard too. Particularly, check the CPU socket for bent pins and look for any chipped capacitors, resistors, and cut traces.
        • Rob
          • Oct 2005
          • 47
          I did send pictures over to Amazon. It has a damaged ram slot and a scratched trace, not past the protective layer luckily. The damaged RAM slot pins are good still so it may work, if not then it will be a 2 slot mobo I guess. The CPU pins are fine and everything else seems to be in good shape. Amazon did refund me 50% of my money because of the issues so I got the board for $46.00. If it turns out to be fully functional then it's a win for me.
          I wouldn't recommend open box boards from Amazon at all. I ordered 3 and the first one was missing an IO shield and had arctic silver 5 all mashed in the pins, plus 1 pin completely missing. The 2nd one had bent pins and broken traces on the back side... and now this 3rd one ^.
          I really appreciate the help mockingbird and momaka. Glad to see this forum still has some great people after all these years.
            master hoarder
            • May 2008
            • 12160
            Glad to help.
            Just make sure the pins in the damaged RAM slot are not touching or shorting to anything else. Otherwise, you may end up with more problems.
            • hamsterball27
              • May 2013
              • 9
              • uk
              it should be fine... i once got given a old foxonn board that had a few chiiped mosfets im not sure how they got chipped though. i alsodropped a screwdriver in the case accidently and it chipped the edge of a small chip but it still worked good for about 3 years then i threw the computer away ecause it was outdated
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • Nooy
                VGA MOSfet permanently shorted and loss of MOSfet pad
                by Nooy
                Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                02-14-2024, 02:26 AM
              • AppleLover123
                Asus X712EA 3 volts after the first mosfet
                by AppleLover123
                Hey guys,
                i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                Now i thought something...
                12-15-2024, 07:49 AM
              • MicroSMD Lab
                by MicroSMD Lab
                I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                01-10-2024, 06:36 AM
              • Scotchmist
                Asus GA502D keeps blowing mosfet
                by Scotchmist
                I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                I have removed the mosfet and can run the laptop no problem
                The MOSFET is FDPC5018SG
                Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                08-24-2024, 02:23 PM
