MSI 6378v1
  • Pud
    • Jan 2006
    • 9
    MSI 6378v1
    hey,
    board just decided to stop booting altogether after a system freeze in outlook express.
    the caps appear to be in good condition yet it is running teapo's which i would presume are likely to be bad. No bulge on top and none underneath that i can see... they are mounted reasonably high and don't quite sit flush on the board like the other caps on there so was wondering if they would likely be the cause?
    any help appreciated.
    cheers,
    pud
    I love GSC.
  • tazwegion
    • Jun 2006
    • 444
    Re: MSI 6378v1
    Is there any power coming from the PSU? ie. are fans spinning, HDD's tracking etc.
    When you say it stopped booting... does it even get to the POST screen?
    Viva LA Retro!
    • Pud
      • Jan 2006
      • 9
      Re: MSI 6378v1
      mate the thing powers up just fine... it's a case of lights on but nobody's home.
      have done everything with it and changed the caps for the hell of it but still no juice so i ended up repairing a badcap biostar with the same chipset and replacing it with that.
      writing the board off it's not worth my time!
      cheers anyway bro.
      Pud
      I love GSC.
      • SchoolDaGeek
        • May 2009
        • 20
        Re: MSI 6378v3
        I just fixed this exact same problem using a higher powered power supply.
        The machine turns on but does not produce a video signal or any POST beeps.
        I checked the PSU with a volt meter and all the rails checked out fine. In fact the machine ran for months/years with this PSU. The only voltage that was slightly off was the 12v rail at 11.68v. It was a Fortron/Sparkle PSU and had internal adjustments but I could not adjust the 12v better than where it was glued to begin with.
        The old PSU was 'newer' in the sense it had a P4 connector and NO -5v white wire, but the PSU that ended up working with the board was simply a stronger PSU by 20watts and did have the white -5v wire, but no P4 connector.
        So if anyone has the "lights on but no one home" scenario, try a different, much stronger PSU and see how it goes.
        • Aeisens
          Samsung UE50RU7170 not booting /no picture
          by Aeisens
          Dear all,
          My issue is the following:
          Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
          I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
          Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
          Question 1: Where should I start to...
          06-24-2025, 03:07 PM
        • Daniel Kubica
          Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
          by Daniel Kubica
          I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
          I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
          06-14-2025, 09:24 AM
        • sylvain_92
          iMac 2009 A1312 2009 not booting - 3rd led not on
          by sylvain_92
          I am trying to repair my iMac A1312 late 2009 intel i5.
          First of all it was booting but no screen on internal lcd but working with external one,
          I tried:
          - another screen and led power board (booting no screen - same as before)
          - another mxm graphic card (not booting missing 3rd led)
          * screen and mxm gpu tested are 100% working on another A1312 iMac.
          I putted back the original mxm graphic card and what a surprise, now it's not booting anymore even with the stock parts.
          The main...
          12-23-2022, 03:36 PM
        • slimmy182
          MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
          by slimmy182
          Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
          Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
          Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
          C81DC PP3V8_AON_VDDMAIN
          And
          Q5800
          What should I test as next step?
          Thank you very much!
          02-01-2024, 01:08 PM
        • Bimad99
          No SLP_S5 signal - SAMSUNG NP350V5C shut down while booting
          by Bimad99
          I have this case a SAMSUNG NP350V5C, board number is QCLA4 LA-8861P Rev : 2.0.
          the laptop was dead because of triggered 3.3v and 5v supplies, the problem solved and the laptop fired up, I tried to boot to Linux at first but the laptop completely shuts off while booting all the times i try and it doesn't turn on only after couple hours, So i decided to change the RAM and install windows 10, the installation was successful but when it was booting to windows for the first time it shut down again, But this time it is refusing to turn on even after waiting for hours....
          08-10-2023, 03:42 AM
