p2b-ds fan headers not working
  • Spacedye69
    • Nov 2005
    • 698
    • US
    I just bought a p2b-ds and everything works great except none of the onboard fan headers seem to be working. With none of the 3 working at all, I would figure it is some kind of setup or conflict issue, but I'm not sure. The cpu fans work hooked to psu.
    I have a couple more strange questions on the same board. It came with 2 procs withe the following specs- 400/512/100. The 512k cache would lead me to believe they are Katmai, but I can only find reference to 450mhz and up on PIII.
    Also, I have scsi issues. I have 2 drives Seagate Barracuda ST3xxxxW series drives that are SE and have self termination jumpers. One drive just beeps and does not spin up, so I assume it is dead, but the scsi adapter recognises the drive. The second will spin up but the green hd light stays on and the adapter will not recognise it. I have tried both drives with standard cable and cable with active term. I'm not that familiar with scsi, but do have them set up according to the manual(adapter termed, last drive termed, etc.) I have no idea what the other settings are for. I have tried them both on the p2b-ds on board adapter(Adaptec 7xxxx I think) and an Adaptec 2940UW pci card.
    Any info would be great!
  • Operandi
    • Jul 2006
    • 46
    Re: p2b-ds fan headers not working
    All fan headers eventually lead back to the same place (I believe) so if one fan header saw too much current all of them could have effectively been killed.
    • Rainbow
      • Aug 2005
      • 1375
      On Asus boards, there is often a transistor next to one of the headers that controls all of them. It's probably bad.
      • Spacedye69
        • Nov 2005
        • 698
        • US
        I'll look for the transistor. Not really important, as I can just get power from ps connector, but I would still like to fix it.
        • Rainbow
          • Aug 2005
          • 1375
          Should be in TO-252 package.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            and if id/term/lvd-se jumpers are right the second drive is likely bad too.
            • Spacedye69
              • Nov 2005
              • 698
              • US
              That was my guess on the drives. Just wanted to make sure. Thanks. I'll buy some new ones.
              • Spacedye69
                • Nov 2005
                • 698
                • US
                I'm a moron, kinda.
                I assumed the fans were completly fine, since I could plug them in to an adapter and plug them into the ps and they would spin. So in poking around with my meter, I decided to check fan headers for voltage. +12v! Dammit! For some reason, the fans would not work with the tach lead plugged into the board, but would work on 12v without the tach lead. If I had just been the typical parts swapper and tried new fans to begin with, I would have been fine. The other fans work fine on the headers.
                • Rainbow
                  • Aug 2005
                  • 1375
                  BTW. The 12V presence check is not enough as on some boards, the GND is switched on/off instead of 12V.
                  • TyMercer
                    Can I flash a working BIOS from one computer to another of the same make, model, etc?
                    by TyMercer
                    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                    Yesterday, 09:39 PM
                  • MMH3
                    Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                    by MMH3
                    i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                    Never ever i experienced problems with that.
                    Now i have one 5050sff machine, where this jumper isnt working at all.
                    I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                    The history of the machine is that i used it in my office...
                    03-23-2025, 09:28 PM
                  • DynaxSC
                    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                    by DynaxSC
                    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                    The board is generally working now, all PCIe ports are working, Windows installs normally.
                    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                    03-10-2025, 12:27 PM
                  • obelix24
                    Macbook Air 2020 (a2179) - touch id not working
                    by obelix24
                    Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                    I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                    02-09-2025, 12:57 PM
                  • hopkok
                    Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                    by hopkok
                    Hi masters, I need your help.
                    I am working on Lenovo Legion 16ITHg6
                    Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                    INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                    My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                    AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                    Power LED is not working as well, power button working well.
                    UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                    Motherboard...
                    05-04-2025, 09:35 AM
