Elna Bad Cap?
  • nsx29
    • Jan 2006
    • 26
    Elna Bad Cap?
    http://pg.photos.yahoo.com/ph/nsx29c...?.dir=/4d64scd
    hmmm... img attach not working.
    This Elna looks bulging. As far as i can see it's general purpose and surface mount so recap is impossible. This is very rare stuff. hmm.
    feedback welcome
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    Re: Elna Bad Cap?
    Ugh. Not Elna now!?
    Damnit! So much for me wanting to get Cerafines to replace the Scatronics in my speakers.
    It is possible to replace surface-mounted caps without the proper equipment... if you don't mind running the risk of tearing up the solder pads.
    BTW where did you find this cap?
    Last edited by UraBahn; 09-02-2006, 12:18 AM. Reason: "Lousy scatronics" ... that was really redundant :lol:
    The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
    I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
    • arneson
      • Sep 2005
      • 1267
      Re: Elna Bad Cap?
      With an exacto knife and a moderatly hot fine tip chissel, that cap should be easy to replace.
      Jim
      • nsx29
        • Jan 2006
        • 26
        Re: Elna Bad Cap?
        This cap is on a Elsa X1300 video card pci-e. Very recent stuff but according to date code. The elna cap is manufactured in 2004 which is very old stuff. I have no clue why it was used. I thought most computer stuff uses low esr stuff not general purpose.
        By the way, the system is running a zippy powersupply with chemicon ky caps. so i am confident that this must be some sort of manufacture defect or expired capacitor (not likely but i heard caps are good for 2yrs shelf life.)
        • japlytic
          • Oct 2005
          • 2086
          Re: Elna Bad Cap?
          Even the best capacitors are not immune from failure...
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            Re: Elna Bad Cap?
            its no big deal to replace that cap.i replace sometimes 50 tiny ones at a time in old sony camcorders.
            10 minute job for me to replace that one and all others like it.
            • whiz
              • Aug 2006
              • 48
              Re: Elna Bad Cap?
              Originally posted by UraBahn
              Ugh. Not Elna now!?
              From where??? is it possible to get some Elna RFS (silmic II) and buy them from you?
              • linuxguru
                • Apr 2005
                • 1564
                Re: Elna Bad Cap?
                It's probably a misapplication of a general-purpose, 85c cap instead of a low-ESR, 105c cap. Even Pannies and Rubies will fail quickly in such situations.
                There are probably no better caps than Elna R** for most small-signal audio use. For large caps in the Power Amp, Elna RJH works fine - but Panny FCs or Nichicon P* probably have a small edge for high dynamic-range performance. The differences are slight and highly subjective.
                Black Gates, Cerafines, etc. are probably wasted money, but if you've got a well-heeled customer who wants them, you might as well take the money first, and skip the common-sense explanations.
                • gonzo0815
                  • Feb 2006
                  • 1600
                  Re: Elna Bad Cap?
                  I consider Elna as good cap. They are long in business and have good Q/S.
                  And those SMD typs are very easy to desolder. Have replaced alot of them from a charging unit for Motorola GP900. Never needed something else than a soldering iron and something to pick up the hot cap.
                    Surface Mount Fuses Fundamentals Datasheet
                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                    10-07-2024, 06:07 AM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
                  • Olkus
                    Elna capacitors - fake?
                    by Olkus
                    I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                    09-01-2023, 02:45 AM
                  • Mark R
                    Does Elna Make any Cap Kits??
                    by Mark R
                    Been searching the universe internet. Can't seem to find a Cap kit with a Nice assortment of Elna caps. Low values and High Values. Anyone have knowledge in regards to this?
                    01-27-2025, 04:07 PM
                  • dragometin
                    Hitachi 40HYC42
                    by dragometin
                    TV Model: Hitachi 40HYC42
                    Power Supply: 17IPS71
                    MainBoard: 17MB95M
                    Panel: VES400UNDS-2D-NO3
                    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                    Is there any variants on 17IPS71 power supply's?
                    UART output pins 10 and 12 on scart connector:
                    Code:
                    12:24:04.595
                    08-08-2024, 05:53 AM
