Re: Why have almost all my failed motherboards been ECS brand?
Yes, ECS and PCChips are horrible brands. They are also at the lowest end of the price spectrum. They were the last makers producing 32-bit stuff, using KT600 and KT800 chipsets (AMD CPUs). So they are "behind the times" and producing for the lowest price point. Years ago I saw a Newegg review that said "at least when it caught fire, it did not burn down my house". That's ECS/PCChips quality!
And according to an old article online about PCChips, they once used FAKE cache chips on their boards (or they used counterfeit logos for BIOS manufacturers, I forgot which).
As for ECS / PCChips, stay away. Stay far away.
The K7S5A was the very board that initially turned me off ECS. Seeing many failed ECS boards in customer's PCs only confirms my opinion of them.Leave a comment:
I also have an old ECS K7S5A pro board (v5). It has survived several years of 24/7 use, it has outlasted that Antec SP300 that I needed to repair...
PCChips I have to agree as crappy. but the one PCChips Socket7 board I had, had a noname chipset on it... not even Via, not even SiS...Leave a comment:
I use a BioStar Socket 775 that was one of Fry's last mobo-CPU combo bargains, at $30. It has no PCI-E 1x slot, and it defaults the DDR2 memory to 1.95V, maybe to allow booting with junk RAM. OTOH the BIOS lets the RAM voltage to be set to a chip-frying 2.8V (absolute maximum for DDR2 is supposed to be 2.3V).
I also had a BioStar Socket A that was kind of unusual because it had only a 20-pin power connector but ran the CPU from the sole +12V wire on that connector. Also if something went wrong with the boot process, I'd have to remove the clock battery because merely moving the CMOS jumper didn't help.Leave a comment:
ive had lots of problems with ECS, Biostar is my favorite low end along with asrocks boards they usually have a decent mix of OST, Su'Scon and other quality middle grade caps.Leave a comment:
The Gigabyte ultra durable boards don't ever get bad caps, as they always use Japanese polymer caps (Chemi-Con, Nichicon or Sanyo OS-CON). ASUS often use low quality Apaq caps on their mid range boards.Leave a comment:
I will agree this is Badcaps.net
If you have the list of which caps fails first on those boards I will greatly appreciate it.Leave a comment:
Biostar has some decent stuff from the $150~ range and up.Leave a comment:
I've only ever seen two Biostar boards that I can remember, so I really don't know much about them.Leave a comment:
I have an ECS board with almost purely Panasonic caps, and it's got over 25,000 running hours on it. The only non Panny's are the OST near the PCI slots. I think ECS is better than Biostar.Leave a comment:
Intel are usually made by Foxconn, but ASUS have made a few models.Leave a comment:
I like ECS and Biostar.
Intel motherboards the worst, doesn't Asus make them?Leave a comment:
My failures with ECS mobos happened years after recapping or with original caps that looked good and measured good for capacitance and ESR (out of circuit).
OTOH my even older recapped ECS K7S5A Pro and a P4S5A2 mobos are reportedly still running well, and when I first got them they were full of leaky G-Luxons.
Also the Asrock mobos had loads of low quality Ltec caps that failed, but the mobos apparently had no other damage.
This new ECS is full of polymer and Sanyo caps but has a few OSTsLast edited by larrymoencurly; 11-27-2012, 04:05 PM.Leave a comment:
Intel aren't my first preference, but they are usually very reliable when they don't use bad caps, and I'll pick one over ASUS any day. My brother had a D945GTP, and that thing came with rubycon MBZ, and it's been fine. The CPU is a Pentium D, so who cares about the lack of OCing features?
Who cares about the features if the board dies young?Last edited by c_hegge; 11-27-2012, 02:27 PM.Leave a comment:
Looks that every converstation turn around capacitors.
Hey world... when I am saying my opinion I have and the features in mind.
Since 1995, I have use about 17 motherbords in my own system.
Mostly ABIT & ASUS, one MSI which was good at stock speeds, and one GIGABYTE.
Asus P4C800E Deluxe - Failed due shortcut caused by a USB memory stick.
Asus policy 5 years waranty.. they did honor it, I got a replacement.
GIGABYTE EP35C-DS3R sudenly failed to boot, it does reboot cycles but no beep and start.
GIGABYTE waranty is a joke, the company hides it self from the users and the problems.
Now days I got one fine LCR meter, I will check for capacitors issues, but this is not what a regular computer user has in mind when bying one MB.
My last MB an ASUS P5QC with three years waranty, this December I will complete my first 12 months with it.Leave a comment:
Agree on intel boards, had one in not too long ago. Full of bloated KZGs, required a bunch of Ruby MBZ to fix. Asus is crap too, had to fix a shorted VRM caused by auto voltage settings when overclocking - the board was so smart, it blew itself.
I remain biased towards Gigabyte. Biostar makes some decent stuff nowadays as well.Leave a comment:
All KZG class caps are discontinued... The question is which polymers will they use in place?
Intel using Capxon polymer and an unknown brand polymer (Possibly Matsuki/Lelon) in their latest generation flagship ($250+) motherboard:
Intel BOXDZ77RE75K
KZG in a $75+ B75 budget board:
Intel BOXDB75EN
by Stanley1843Hello,
has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.06-22-2024, 11:06 AM -
This specification for the HP Pavilion 15-cx0198tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-cx0198tx boardview and 15-cx0198tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...09-06-2024, 09:17 AM
This specification for the HP Spectre x360 13-ae511tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13-ae511tu boardview and 13-ae511tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 06:27 AM
This specification for the HP Spectre x360 13-ae510tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13-ae510tu boardview and 13-ae510tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 06:17 AM
This specification for the HP Spectre x360 13-aw0124tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13-aw0124tu boardview and 13-aw0124tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-06-2024, 12:25 PM
- Loading...
