Biostar M7VIQ SOCKET A Heat Issue
  • kingmelee
    • Jul 2006
    • 5
    I have installed a Biostar M7VIQ SOCKET A with a XP 1700+ in a backup machine. Problem is CPU temps reach 71 degrees C.
    I did notice 2 bulging and raised caps with values @ 3300mf 6.3v and ended up replacing 4 in total, and still the temp remains near 66 degrees C. There were 6 in a row next to the socket 462 ZIF.
    Originals were OST I.Q 6.3v 3300mf 105c and were replaced with 3300mf 6.3v 85c.
    I did leave two more that showed no sign of bulging. Should I just bite the bullet and replace those as well? Cost was $1.25 each.
    (edit) I have reseated the hsf with silver paste and the fan is fine for the cpu in use. I have read reports that this motherboard mis-reports core temp by +10 degrees, but even then 56 degrees is a tad too warm for my liking. The board is running fine, my big concern is the temp. PSU is 350W and the side panel is off while I attempt to resolve this temperature issue.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Biostar M7VIQ SOCKET A Heat Issue
    did you replace with high quality(japanese)low esr caps?
    always replace all when you see even one of its type bad.
    i would verify vcore is correct by measuring with a good vom.the onboard monitoring on most boards are inaccurate.
    • yanz
      • Nov 2004
      • 910
      is AXP 1700+ officialy suppported by the board? i have experiences that when i put barton or tb on old socket A board, the temp sensor unlogically report a very high temperature. updating the bios will cure the problem on this case.
      wrong orientation of the heatsink could also be the cause of that high temp. but surely you already know that... wrong/bad caps, like kc8 said, can cause noisy ripple for the cpu or for the vrm input and force those components to work harder and inneficiently, so heat will rise.
      check also the caps on your psu.
      • UraBahn
        Scrapheap Hound
        • Nov 2004
        • 165
        You shouldn't use general-purpose caps to replace low-ESR caps. All caps with 85c temp tolerance are AFAIK general-purpose. The low-ESR capacitors I personally recommend are Rubycon MBZ, MCZ, or YXG. Some users report excellent results with Samxon, but I have yet to personally test them.
        The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
        I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
        • MD Willington
          • Sep 2004
          • 702
          Via KM266 chipset, supports all 266 bus K7 processors...
          http://www.biostar-usa.com/cpusupportA.asp#M7VIQ
          MD's Temperature related standard checklist.
          Check the following for overheating or perceived overheating:
          - Is the heatsink correctly installed ?
          --> Verify it is correctly installed.
          - Is the heatsink filled with dust and crud ?
          --> Clean with compressed air in a can.
          - Is the heatsink fan operating ?
          --> Replace defective fan with similar or better unit.
          - Is the heatsink adequate for that application/CPU ?
          --> Verify it meet the requirements for the CPU being used.
          --> RETAIL heatsink? May require lapping and better TIM.
          - Is thermal interface material used between heatsink and cpu ?
          --> Verify it is used, and is applied according to the manufacturers guidelines.
          --> Recommended PCM's, thermal pads from "AMD Thermal, Mechanical,and Chassis Cooling Design Guide #23794.PDF.
          - Bergquist HF225UT Phase Change
          - Chomerics T725 Phase Change
          - Honeywell PCM45 Phase Change
          - Power Devices Powerfilm Phase Change
          - ShinEtsu PCS-TC-11T-13 Phase Change
          - Thermagon T-pcm905C Phase Change
          --> Recommended thermal interface material aka: grease, gel etc.
          - Arctic Ceramique.
          - Arctic Alumina.
          - Arctic Silver, 3, 5 etc.
          - Is the TIM pad cover removed from heatsink before installation, if using supplied TIM pad ?
          --> Remove the cover before installation, failure to do so will insulate the cpu from the heatsink.
          - Is there adequate airflow or case ventialation ?
          --> Verify airflow, add case fans if required.
          - Is the Vcore set higher than specified by the manufacturer ?
          --> Verify the Vcore is set to the manufacturers specification in the mainboards bios.
          - Is the temperature read via the internal temperature diode. Is the tremperature read via the socket thermistor ?
          --> Temperatures read at the diode can and will be higher than an external reading.
          - Is the temperature sensor properly calibrated ?
          --> Several boards have this problem, check manufacturers bios revision history for calibration fix.
          --> Does the heatsink feel warm or HOT, if it's warm it could be a miscalibration error.
          - Outside temperature high ?
          --> If the external temperature is high, then the case fans will be drawing in hot air, especially during summer months. Remeber, when it's Winter in the Northern Hemi-sphere, it's Summer in the Southern Hemi-sphere & vice-versa.
          MD
          Ya'll think us folk from the country's real funny-like, dontcha?
          The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
          • kingmelee
            • Jul 2006
            • 5
            Probably a good point, but should that be making a difference in the cpu temp; at this point? I would think that with the replacement of 4 obviously swollen caps the temps would have dipped to a noticable degree regardless of Low ESR or General Purpose caps having been placed on the board.
            I'll see if I can post a hex dump of the system from CPUZ or Everest.
            • yanz
              • Nov 2004
              • 910
              It could be something then just those caps.
              MD said: Does the heatsink feel warm or HOT, if it's warm it could be a miscalibration error.
              IME, anything can't be touchable probably are >50C.
              • kingmelee
                • Jul 2006
                • 5
                ------[ Motherboard Model ]------
                Biostar M7VIQ
                ------[ ISA Sensor Device at 0290 ]------
                0000 01 FF 01 FF 00 00 00 00 01 01 01 01 3C 3C 0A 0A
                0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                0020 6E 00 CA B4 CC 22 36 15 43 FF FF 85 2A 00 43 AC
                0030 20 00 C4 14 80 00 00 01 00 00 31 24 85 11 00 00
                0040 01 DE 0F FF FF 00 00 AF 2D 02 01 04 50 95 00 A3
                0050 FF FF 80 FF FF FF 00 80 60 50 FF FF 11 89 FF 05
                0060 6E 00 CA B4 CC 22 36 15 43 FF FF 85 2A 00 43 AC
                0070 20 00 C4 14 80 00 00 01 00 00 31 24 85 11 00 00
                0080 01 FF 01 FF 00 00 00 00 01 01 01 01 3C 3C 0A 0A
                0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                00A0 6E 00 CA B4 CC 22 36 15 44 FF FF 85 2A 00 43 AC
                00B0 20 00 C4 14 80 00 00 01 00 00 31 24 85 11 00 00
                00C0 01 00 00 FF FF 00 00 AF 2D 02 01 04 50 95 00 A3
                00D0 FF FF 80 FF FF FF 00 80 60 50 FF FF 11 89 FF 05
                00E0 6E 00 CA B4 CC 22 36 15 44 FF FF 85 2A 00 43 AC
                00F0 20 00 C4 14 80 00 00 01 00 00 31 24 85 11 00 00
                Reg$20 CPU Core: r = 110, r*0.016 = 1.76
                Reg$21 CPU Aux: r = 0, r*0.016 = 0.00
                Reg$22 +3.3 V: r = 202, r*0.016 = 3.23
                Reg$23 +5 V: r = 180, r*0.016 = 2.88
                Reg$24 +12 V: r = 204, r*0.016 = 3.26
                Reg$25 -12 V: r = 34, r*0.016 = 0.54
                Reg$26 -5 V: r = 54, r*0.016 = 0.86
                Biostar M7VIQ
                ------[ 1 SMBus detected ]------
                ------[ SMBus #0 ]------
                SMBus Type: Intel / VIA / ServerWorks / SMSC / ATI
                SMBus Port: 5000
                Scan Type : Full
                ------[ SMBus Device B00-D51 ]------
                0000 80 08 07 0D 0A 01 40 00 04 50 60 00 82 08 00 01 ......@..P`.....
                0010 0E 04 08 01 02 20 00 60 70 00 00 3C 28 3C 28 40 ..... .`p..<(<(@
                0020 60 60 40 40 00 00 00 00 00 00 00 00 00 00 00 00 ``@@............
                0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7B ...............{
                0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
                0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
                0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
                0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
                0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
                0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
                00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
                00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
                00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
                00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
                00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
                00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
                • kingmelee
                  • Jul 2006
                  • 5
                  To followup, replaced the other two caps with matching values. One of the two caps I left had since swelled as well. Replaced that and the other that still looked good, yet temps are still high @ 67 degrees Celsius 153 Degrees F.
                  Any help appreciated. Side cover is off. Internal ventilation is good. CPU fan working ok...
                  • kingmelee
                    • Jul 2006
                    • 5
                    What posts would I connect to to read the vcore value?
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      Take any ground, may be one of the screw pads near the cpu. Then touch with the other probe the 3 pin mosfets. In most cases it is the middle pin, e.g. the pin wich is soldered with the back to the pcb. If none of the midlle pins is at the estimated voltage range, try the other pins as well. If you have replaced the Ost caps with mediocre ones, the VRM controler will increase the voltage and is producing high voltage spikes in oder to compensate for the higher ESR los. This can lead to any sort of uncontroled side efect`s.
                      • Swedroid2K
                        Sony KDL46EX401 Heat Issue
                        by Swedroid2K
                        Hello!
                        I have an old Sony Bravia KDL46EX401 that has worked perfect since 2011, but four days ago malfunctioned.
                        Symptom is garbage graphics and artifacts, like a computer GPU gone bad. This gets worse and the whole units just hangs.
                        After dissasembly and troubleshooting I found no physical or electrical faults, as a last resort I took a CPU cooler and pressed it against the CPU on the mainboard and voila it worked to boot up and keep the TV alive.
                        The CPU on the mainboard has no cooler by default, but it does get very hot.
                        I now added a small flange...
                        10-30-2022, 08:03 PM
                      • rounin
                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                        by rounin
                        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                        🛠 Original Issue
                        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                        04-19-2025, 01:18 AM
                      • ugamazing
                        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                        by ugamazing
                        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                        12-17-2024, 07:05 PM
                      • shahnld
                        Lenovo legion 5 pro startup issue
                        by shahnld
                        Good day Experts
                        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                        08-24-2025, 12:31 PM
                      • ahmarzo
                        Acer laptop battery draining issue
                        by ahmarzo
                        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                        08-02-2025, 06:39 AM
