MSI P965 NEO - Question about capacitor type
  • thewk
    • Oct 2011
    • 18
    I have MSI P965 NEO motherboard which is not working OK. When I received it there was couple bad OST capacitors which I replaced, those were located here and there. The board does power up each time and you can configure BIOS etc, but when you try to boot Ubuntu or Windows it crashes, Ubuntu throws kernel panic while when booting Windows it might just shut down. This leads me to believe it is problem with processor stability and with capacitors surrounding the socket to be exact as the processor is known good. Those caps surrounding the socket are OST branded RLA 680uf 4V. They don't look bad but as far as I know with OST it is quite common for them to fail while still looking healthy.
    Couple questions:
    1) Does this sound like the problem is those caps?
    2) If it is, can I use these to replace them:
    http://www.ebay.com/itm/Free-Shippin...ht_2302wt_1114
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Re: MSI P965 NEO - Question about capacitor type
    Of course you can. Those a high quality (just look at the bong of the cap) genuine Panasonic caps.
    Caps come from China at a low price from Ebay. I really can't see any problems, what so ever.
    • Evil Lurker
      Warranty Voider
      • Feb 2011
      • 454
      Never ever buy caps off of Ebay. There is a high probability that they are fakes. Only buy caps from reputable authorized distributors such as Mouser, Digikey, and of course here.
      • Rob Northen
        • Jan 2010
        • 137
        • Denmark
        Try reading my post one more time, wait a minute and think of it...
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Those caps (in the picture on ebay) are actually Panasonic FL.
          These are wet lytics without a vent. You can commonly find those on somewhat older MSI mid-range motherboards. I've done a full recap on one of those boards, and the ones I've desoldered look 100% identical, right down to the circle bung.
          Just because it has a simple bung doesn't mean it's a cheapo chinese crapcap. The rubber bung on Sanyo OSCONs is flat too for example.
          I'd still not buy from that seller though, because you might get something completely different to what's in the picture (i.e. possibly junk or fake caps).
          If it really has to be from ebay for some reason, there are only 2 sellers I'd trust personally, namely audjade_chn and egekecu (a.k.a. the PC Motherboard Capacitor Store).
          • thewk
            • Oct 2011
            • 18
            Well there is no other reason of buying from eBay than price, capacitors are quite more expensive if I buy them from reseller here in Finland and then repairing this board might not be worth it because I might get fully working one nearly same price. I know that it is risky when buying from eBay but so far there hasn't been problems, altough I've always used bit higher rated caps than what is stated in the originals and those on that auction are not...
            • ant3202
              • Jun 2006
              • 275
              • Singapore
              you can give a try.... if you gotta fakes... then bad luck,
              and yes..... for the ost capacitor, i had those problems too, after replacement, it works well.
              • c_hegge
                • Sep 2009
                • 5219
                http://www.ebay.com/itm/NEW-2-Pcs-Pa...item231c4e34bb
                same seller, definitely fakes.
                I'd replace them with 560uF polymer caps like http://www.ebay.com/itm/4-Sanyo-SEPC...item45ef447fe1 , and fill up the empty spots with them. I do it on every MSI board I get with bad caps, and it works every time
                • larrymoencurly
                  • Oct 2004
                  • 960
                  Originally posted by c_hegge
                  But he has a 99.7% positive rating!
                  Has anybody reported him to eBay for selling counterfeits?
                  • c_hegge
                    • Sep 2009
                    • 5219
                    He gets positive feedback because no one realises his caps are fake. The seller's feedback rating isn't a good indication of whether their stuff is genuine.
                    • thewk
                      • Oct 2011
                      • 18
                      This motherboard / PC -project has been on ice for some time but now I'm back to it.
                      Situation is that I was unable to get picture on every boot so I replaced to caps made by Teapo, even though they didn't look faulty. Now it seems that I can get picture every time. However, sometimes it still requires couple attempts to actually be stable. This morning I used the PC several hours once I got it running after which I shut it down. After some waiting I was back again with the booting problems. I have also noticed that it seems that only those two memory slots which are close to CPU work, if I put RAM sticks on those other two the mobo wont boot, no picture. I have updated BIOS to the latest. I have tried with anoter power supply and I have different graphics card now, no change. There are (atleast) three tiny OST caps left, 470uf 10V, from what I have read, even OST has usually managed to make those smaller caps to last but I'm not sure, should I replace them also? Again, none of the caps look faulty.
                      http://aijaa.com/vF7Ip2
                      PCI diganostic card gives error code 45 when I put a memory on one of those faulty slots. At that stage on booting I guess it is memory check so mobo hangs there.
                      • MORETTIGIAN
                        by MORETTIGIAN
                        Title:
                        Description:
                        Procedure performed:
                        - Removed backplate
                        - Reapplied thermal compound
                        - Reassembled card
                        09-18-2025, 12:14 PM
                      • Prolog
                        by Prolog
                        12-01-2024, 08:27 PM
                      • Agent24
                        Dick Smith Q-1760 linear power supply filter capacitor question
                        by Agent24
                        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                        It has at least one problem.
                        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                        I have already ordered a replacement potentiometer, so that's not an issue.
                        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                        All are CapXon...
                        10-21-2025, 05:39 PM
                      • chth96
                        by chth96
                        12-22-2023, 04:34 AM
                      • chth96
                        by chth96
                        06-02-2024, 07:31 PM
