Winmodem with blown caps
  • keyboardcowboy
    • Apr 2006
    • 73
    I have a lucent Winmodem with two bad caps can i replace them with ordinary caps or will i need low ESR caps,and is there any visual method of identifying low esr caps from others like some markings on low esr caps
  • arneson
    • Sep 2005
    • 1267
    Re: Winmodem with blown caps
    A winmodem is a very low power device and low cost.
    Capacitors of the same rating will most likely last many years, just a good brand should do it.
    Jim
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      every modem i have seen with blown parts had swallowed a bolt of lightning!
      • odtech
        Asus UX490U laptop blown (caps?) on power board.
        by odtech
        Greetings friends.
        I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
        I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
        Any guidance...
        08-06-2023, 10:29 AM
      • zlr8r
        HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
        by zlr8r
        Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
        To begin with, this laptop was dead-dead.
        Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
        • am getting white power led
        • 5-long-flashes on CAPS Lock and NUM lock
        • then, fan full speed
        • CPU heats up some (smaller die PCH, does not)
        • always constant black screen no matter what's tried
        • no USB recognition
        • no HDMI output
        this is as far as I can get with it and not sure where to inspect next ?
        I tried...
        03-27-2024, 03:13 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • whc14765
        1070 - Blown SMD caps, short on 12V PCI
        by whc14765
        Hey
        I got a short on 3 pins of the PCI-E gold connector for 12V.
        I see a few caps near the top right (near main power connector) that look blown, one is showing a short across it to GND.
        Unforunately I don't have a schematic or board view for it (EVGA GTX 1070 FTW 8GB).
        Due to the large number of caps there, I think it may just be decoupling.
        Any ideas on figuring out the cap values? There also isn't any reference numbers for the caps on the silkscreen.
        11-23-2022, 06:42 PM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
