ASRock mobo with OSTs
  • Rainbow
    • Aug 2005
    • 1372
    Re: ASRock mobo with OSTs
    The problem is that most newer PSUs have strong 12V rail(s) and 5V is weaker.
    Total +5V & +3.3V power:
    SkyHawk: unknown
    MS Industrial KYP-350W: 188W
    DTK PTP-2007: +5V&+3.3V total output 110W
    And as you can see from above, the ratings printed on the sticker have no meaning.
    • hkivan
      • Mar 2006
      • 122
      The KYP-350W is quite OK for K7 if
      it can really give out 188W combine power.
      However, I think it can't!
      SO, in drawing a conclusion, don't said
      those m/bs poor or good without even
      given them enough power. A different
      PSU may lead to a different story.
      You don't need to chose High-end PSUs
      but also, don't chose those very cheap .
      For ATX 12V 2.0 or later versions PSUs,
      even 500W to 600W , they only give
      around 150W on 5.5v & 3.3V combined output.
      My huntkey 300W give out 180W combined power.
      It is ATX 12V 1.3 version. and It runs more or less
      up to its specification.
      It costed me under 200HKD only.
      ( 200HKD = 25.6USD )
      All in all, chose a right PSU for your m/b.
      • Chris1992
        • Apr 2005
        • 561
        We're interested in seeing a pic of your Huntkey 300w, hkivan. Post a pic in the PSU pictorial thread.
        The great capacitor showdown!
        • hkivan
          • Mar 2006
          • 122
          I dont have a digital camera.
          But here are the links for your reference .
          http://www.belson.com.cn/chinese/pdetail.asp?pid=728
          http://www.pcpop.com/doc/0/49/49162_3.shtml
          In fact, I brought it in ShenZhen, a city of china that
          just next to hongkong. Many of the PC parts there
          are a bit expensive than HK.
          • Harvey
            • Apr 2007
            • 264
            Originally posted by Rainbow
            K7S41 had shorted NPN transistor for chipset power, other two were OK.
            I've just had the same issue, a K7S41GX I've been using for testing and generally messing about with suddenly refused to POST, on investigation I found the northbridge supply transistor Q15 had popped its clogs (actually it fell apart as I was unsoldering it). Its a C5706, and as I've not got anything remotely similar handy I just bunged in a 2SD1802 ripped out from another board to test, and it works... but I'm not happy so I'll have to find something better before long.
            K7S41 has very serious problems with IDE bus loading - it corrupts data with slightly longer cables.
            There's a setting in the BIOS for IDE drive strength - but I've no idea why or what it actually does.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Much - and I tested with only Celeron 1.7GHz CPU. These boards claim Prescott support too...
              ASRock P4i48 and P4VT8+. There is no ATX12V connector and the Vcore MOSFETs are connected to 5V.
              That's oddball! And even with socket A, things were being migrated to the 12 V connector!
              Thus, probably the latest motherboard running off the 5 V rail is the Asus A7N8X family.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Putting Vcore on +12v was 'recommended' by Intel's design guides way back since the i810 chipset but no one (or few) made the switch until P4.
                Reason was probably available PSU's at the time had about squat on +12v and Mobo manufacturers didn't want to tell people they had to buy a new PSU too if they wanted to use their boards.
                Look at Vcore VRM in figure 4-1.
                - "Figure 4-1. Intel 810 Chipset Power Delivery Architecture"
                Mann-Made Global Warming.
                - Dr Seuss
                • Ibod
                  Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                  by Ibod
                  HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                  With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                  Not sure where to go from here ?
                  Is the PSU at fault or is the mobo causing the problem
                  Look forward to any help :-)
                  If I plug the 24...
                  02-08-2023, 11:00 AM
                • Exim
                  ASRock N100M, no picture no boot, but semi-alive
                  by Exim
                  Hi guys,
                  I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                  ASRock N100M special features:
                  - CPU soldered to board, small Intel 12th gen
                  - iGPU
                  - four POST LEDs
                  Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                  I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                  Symptoms:
                  - no picture/signal on any of the display connectors,...
                  04-01-2025, 02:36 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • eccerr0r
                  It's 2025: do you know where your 5¼" floppy drives are?
                  by eccerr0r
                  Oh wow.
                  As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                  Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                  Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                  Weird. Seems the PC drive is having trouble clamping...
                  07-07-2025, 12:49 AM
                • zklgfs
                  AsRock B560 Pro4 Possible Short on +1.8VSB
                  by zklgfs
                  I have an AsRock B560 Pro4 (boardview: https://www.badcaps.net/forum/troubl...pro4-schematic) that's completely dead (it doesn't even turn on the power supply when the power button is pressed or the power button pins are shorted). I do get about 3.4V on the power button pin, but 1.8VSB isn't there. The resistance to ground on the inductor PL53 is only about 0.1-0.4 Ohms. Am I correct in assuming that there must be a short...
                  06-07-2025, 02:22 AM
