ASRock mobo with OSTs
  • Tom41
    • Oct 2005
    • 336
    • England
    At work we got a brand new 'kit' computer for one of our employees. The case, motherboard, CPU, HDD and DVD-ROM were all separate and required assembling on our end. (They wanted to charge us £80 for assembly )
    Anyway, one of the first things I did was check the caps on the board... and I found to my dismay that it's packed with OST caps. I hear that OST can have bulging/venting problems - though thankfully not as bad as GSC or Tayeh . The person who will be receiving this PC likes to keep his machine on 24/7, to minimise boot-up and login delays first thing on a morning. I'm wondering, with OST caps, how long do you expect the board to last like this?
    Whenever I get a new motherboard, before doing anything with the HDD/floppy etc I always power it up and see if it POSTs. Without HDD, floppy or CD it should at least test the memory and then do an error message when it can't find any boot device. With this board, it seemed completely dead at first. Fans spun, LEDs lit on the front panel, but nothing from the internal speaker and nothing on the monitor. Then I realised I hadn't connected the extra ATX 4-pin power connector - after doing that, it POSTed perfectly well
    Now got the HDD, floppy and DVD-ROM installed; just need to put an OS on there...
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • tiresias
    • Feb 2006
    • 489
    Re: ASRock mobo with OSTs
    Ensuring that heat doesn't accumulate to problematic levels (ie. having decent cooling) will help keep those OSTs in order even under constant activity.
    As for the OST themselves, well - they're not great as you know. On a hypothetical rating 4-star rating system, they would probably have 2 stars.
    That would put them at the level of G-Luxon and Hermei. That's much better than Chhsi, but not as good as Nichicon. Basically, they may work for years without giving trouble, but failures with OSTs are too common for them to simply be a case of "the odd bad batch".
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      you did not say whether it was an intel or amd board.
      i would like to add quality psu as well
      depends on the ost series anyway. some like the RLP last for years on the P3 boards, others like the RLZ on vcore of a p4 board did less than a year.
      if you want good caps then why buy a budget range board. it is more likely to get good caps at the high end.
      • MD Willington
        • Sep 2004
        • 702
        Asrock is the budget sector of Asus... much like PCChips is the budget sector of ECS (though I believe both are budget). I ran my PCChips board for pretty much 24/7, same caps, just died last month after ~ 18 months I'd guess.
        Ya'll think us folk from the country's real funny-like, dontcha?
        The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
        • tiresias
          • Feb 2006
          • 489
          Did it die due to the OSTs in any way, or due to one of those mysterious, irreparable issues that PC Chips boards are prone to developing?
          • hkivan
            • Mar 2006
            • 122
            I have a Asrock K7S41. It comes with KZE & KZG caps around the
            cpu socket but the VRM is only 2 phases. The mosfets are small
            and the coils looks high quality. My sempron 2200+ o/c to over 224 FSB
            and run 24/7 flawlessly.
            Later, I recap the KZE & KZG to some inferior brands caps.
            I dont remeber the brands but they are desoldered from a PSU.
            The PC also run fine 24/7. The PSU I used was just a cheap 300W
            from Huntkey.
            Although asrock begins to use OSTs, the stability & OC ability is fine
            on their price range. Even some mid-range m/bs are inferior
            compared with. My next m/b will sure be an asrock.
            Provided u have stable power and no thermal issue, asrock
            should be fine for 24/7. PCChip can't match with it.
            If U want OC to sky high, DFI LanParty is the way to go.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Later, I recap the KZE & KZG to some inferior brands caps. I dont remeber the brands but they are desoldered from a PSU.
              why do that?
              • Rainbow
                • Aug 2005
                • 1375
                I tested 3 ASRock boards - P4i48, P4VT8+ (P4) and K7S41 (Socket A) - lately and they're crap - mainly the BIOS and compatibility is really bad.
                K7S41 had shorted NPN transistor for chipset power, other two were OK.
                Both P4 boards power the CPU from 5V rail which causes problems with many PSUs. Tested with 3 PSUs, only 1 was able to run without problems:
                1. SkyHawk 250W (my testing PSU) - won't even power up, probably due to overload on the 5V rail
                2. MS Industrial KYP-350W - powers up but 12V rail is so unstable (jumping from about 11.8V to 12.4V) that HDD is unable to spin up - the load on the 5V rail is very high
                3. DTK PTP-2007 200W - works fine, although the 12V line varies between about 12.2V and 12.5V)
                K7S41 has very serious problems with IDE bus loading - it corrupts data with slightly longer cables.
                All three boards use good caps - Chemicon, Rubycon, although there are small 1000uF OSTs on one of them. But good caps do not make good board. The CPU power circuits don't seem to be powerful enough.
                When comparing with ECS/PC Chips, I didn't have any recent board from them - but e.g. K7S5A is much better board (only the bad caps which kill mosfets...).
                • MD Willington
                  • Sep 2004
                  • 702
                  The caps looked okay, but it was doing the boot up and run for 15 minutes then lock.
                  In all honesty I have no intention of troubleshooting it, it was a bargain board and was meant to only last until I could put together my A64 system. I'll just grab the other parts and keep them as spares.
                  The board will be having some extra high velocity lead added to it at the farm some day this summer compliments of my Little Friend
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    damn...all of you are armed arent you?
                    • tiresias
                      • Feb 2006
                      • 489
                      That's a great way to deal with misbehaving hardware! Second only to those 30 gram italian firecrackers... they can deal with even the toughest Compaq.
                      The BHP's very nice... it's actually the pistol I've always been able to shoot the best with... at least, it's the only one I've ever been able to win a trophy with at my old "Tiro a segno" (in Italy... not here in the Netherlands, obviously - here you need written permission from the minister every time you plan to fart).
                      PS. Are those earlier models inspired by the 1911? ... it sure would look that way.
                      • Galvanized
                        • Mar 2006
                        • 468
                        Inspired my arse!
                        John Moses Browning designed the 1911 45auto for Samuel Colt.
                        Sam was just very good at lobbying our Congress and giving expensive presents (Colt SA revolvers, engraved & inlayed w/gold) to the "right" people.
                        Sam was political...John Moses was a true genius at design=fact.
                        Just kidding with you tiresias.
                        • tiresias
                          • Feb 2006
                          • 489
                          No seriously, this is good information!
                          I was actually not aware of Browning's involvement in the 1911's original design - keep it coming.
                          • Galvanized
                            • Mar 2006
                            • 468
                            I'm no expert but did get real involved in firearms History at one time.
                            This should be in the lounge. I'll talk to stretch in the gun thread there and we can really kick-it around. I like the "cap"gun ideer.
                            Google punkin chunkin :-P
                            http://www.m1911.org/browning.htm
                            • MD Willington
                              • Sep 2004
                              • 702
                              ATM, I am using a friends "hardware"..though I do have a license of my own, considering a CPL as well, my state has some funny laws even though I am a permanent resident with background checks etc etc...
                              to avoid all that mess I need citizenship, shouldn't be a problem.
                              • Chris1992
                                • Apr 2005
                                • 561
                                ?! I thought Intel would not even allow selling of a P4 board if not powering the proc froim 12v!
                                The great capacitor showdown!
                                • hkivan
                                  • Mar 2006
                                  • 122
                                  why do that?
                                  My socket A sempron can't be unlocked. With
                                  the fixed multipler of 9x, it won't be oc too high.
                                  I just want to reserve the caps for future OC.
                                  Second tier is enough the K7 board.
                                  Also, I brought some rubycon RX30 .
                                  They are just sitting around. I can find MBZ,
                                  MCZ, KZJ, KZG... in my region. Only, Rubycon RX30,
                                  YXG, YXA, YK can be found in store.
                                  • hkivan
                                    • Mar 2006
                                    • 122
                                    I saw some Asrock K8 boards come with 16V caps on VRM input side.
                                    They should drain 12v rail. P4 need more power. How
                                    many amperage needed if they are feasted from 5V rail ?
                                    Which P4 boards u are talking about? Can u show me
                                    some pictures so that I can see the caps on them ?
                                    • Rainbow
                                      • Aug 2005
                                      • 1375
                                      Much - and I tested with only Celeron 1.7GHz CPU. These boards claim Prescott support too...
                                      ASRock P4i48 and P4VT8+. There is no ATX12V connector and the Vcore MOSFETs are connected to 5V.
                                      • hkivan
                                        • Mar 2006
                                        • 122
                                        The P4i84 is claimed to support upto 3.2G Prescott
                                        as I saw from the web. As the 2nd brand from Asus,
                                        I think they won't tell lies. But they haven't disclose
                                        the PSU needed.
                                        When there were few affordable ATX 12V 2.0 PSUs
                                        on the market, draining on 5v rail to feast CPU is wise
                                        provided technically feasible, especially for budget boards.
                                        Just like a PSU for K7, the combined output of 5V
                                        & 3.3v should be more than 180W. My 350W Hedy comes
                                        with 220W combined power.
                                        • Ibod
                                          Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                                          by Ibod
                                          HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                                          With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                                          Not sure where to go from here ?
                                          Is the PSU at fault or is the mobo causing the problem
                                          Look forward to any help :-)
                                          If I plug the 24...
                                          02-08-2023, 11:00 AM
                                        • Exim
                                          ASRock N100M, no picture no boot, but semi-alive
                                          by Exim
                                          Hi guys,
                                          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                                          ASRock N100M special features:
                                          - CPU soldered to board, small Intel 12th gen
                                          - iGPU
                                          - four POST LEDs
                                          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                                          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                                          Symptoms:
                                          - no picture/signal on any of the display connectors,...
                                          04-01-2025, 02:36 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • nolaryie
                                          BIOS .bin file for ASRock B450M Steel Legend
                                          by nolaryie
                                          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
                                          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
                                          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
                                          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
                                          Thank you!
                                          08-06-2025, 12:01 PM
                                        • khanhtq0
                                          Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
                                          by khanhtq0
                                          I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
                                          I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
                                          I suspect the original Intel ME and descriptor...
                                          08-06-2025, 02:14 AM
