Second MSI K7T Turbo-RAID v3 recapped
  • Sudum Gumudu
    • Sep 2005
    • 97
    Just finished recapping my second MSI board. Didn't take any pictures of this one. For pictures of board layout, caps changed etc see my previous post https://www.badcaps.net/forum/showthread.php?t=1772 . They are identical.
    All of the caps looked fine except for the Chhsi:s by the AGP slot, which had vented slightly. Was in fact running fine, but I recapped it anyway, as it was just a matter of time.
    The recap was uneventful, it posted on the first attempt, and has completed the burn-in test without errors. When I first tested it, it refused to soft reboot however. Neither CTL-ALT-DEL or reset button would work. Power off and on worked. After pondering that for a moment, I removed the CMOS battery for a while, and put it back. That did the trick.
    It goes back in its case later today. Another one saved.
  • browny1978
    Recapped BP6 and HPT366 issue
    by browny1978
    So I'm an owner of a BP6 and it was in fantastic condition, with none of the original capacitors showing any signs of failure. But one day a year or so back, it failed to Post, after working fine just a few hours earlier.
    So I did the usual, swapped all the components etc. etc. to no avail. So I boxed it up and thought I'd deal with it another day.
    About a month back i recapped the board with Rubycon caps all of the ratings as per this site, but still to no avail. No post.
    So I bought some SST BIOS chips that were of similar spec to the winbond one...
    08-25-2021, 01:07 PM
    Wise Wing F199 19'' LCD monitor - recapped
    by momaka
    Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
    I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
    When I saw the Craigslist post, I wasn't...
    08-24-2020, 10:58 AM
  • LaPorta
    Recapped PowerMac 8100 PSU and now unstable
    by LaPorta
    This is my first thread, and I am new here. I am part of the 68kMLA forum, and I was referred over here by one of the members there who is a member here as well.
    I have a power supply from a Power Mac 8100 (Delta Electronics, Model # DPS-225AB Rev: A0, Apple Part Number 614-0040). It worked fine prior but, being close to thirty years old, it was time to recap. I have done a lot of capacitor replacement, but am by no means an expert at all. I looked up the replacement parts and ordered on Mouser. All electrolytics were replaced with same capacitance...
    03-14-2021, 02:14 PM
  • Amraks
    Sasmung la40m81bd - Recapped
    by Amraks
    History:
    PSU only recapped.
    This TV was not turning on a few weeks ago I then recapped it as I recall I swapped all capacitors except a 163v 1uf as I didn't have this value.
    A few weeks pass.
    The TV now is coming back to me with with a picture fault.
    https://youtu.be/sYJE7VpX4yE
    Any idea what may cause this? could it be that 163v 1uf I didn't recap?
    Just want this customer to have their tv back as I have their other one at the moment as well.
    12-12-2018, 04:54 AM
    Sense Adjustable Switching Power Supply ReCapped finished
    I bought this switching supply power a few months ago but did not have time to do anything but now because of being in between jobs I now have time for projects that were waiting for me to have time to do them
    What do think about this switching power supply pictures are below
    One note theses pictures are after I had recap this power supply
    The capacitors were actually not that bad ESR value wise expect for a couple of them low UF value under 100 for non brand name capacitors
    One other note I moved the indicator LED light to the outside of the...
    11-20-2020, 09:50 AM
