calibre 8500gt blown cap
  • Agent24
    I see dead caps
    • Oct 2007
    • 4968
    • New Zealand
    Re: calibre 8500gt blown cap
    There are a couple of eBay sellers who sell good capacitors (I'll let someone else list the good ones, because there are also a LOT of bad ones) - perhaps try buying from them?
    Should be fairly cheap and might be a better solution than trying to find something decent locally if there aren't many good shops where you live.
    -David VanHorn
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      No, LXV aren't even close.
      You can't mail-order to Indonesia?
      They make caps in Malaysia which is right 'next door'.
      Hong Kong and Singapore aren't that far either.
      Big Pope is a member here and he sells Samxon caps out of Hong Kong.
      Drop him a PM.
      Mann-Made Global Warming.
      - Dr Seuss
      • c_hegge
        • Sep 2009
        • 5219
        If you can't order from the US, use the following:
        1500uF 6.3v
        680uF 16v*
        470uF 16v
        * These may be somewhat taller than the originals and may stop you using the next PCI slot, but they will still work OK as replacements.
        • mariushm
          • May 2011
          • 3799
          If you can paypal some money (or some other way), I think I can send you those at less than the digikey price + about 2$ for stamps ... but considering I'd mail them from Romania it will probably take about 2 weeks to reach you.
          Not sure what I have, could be just 470uF 25v instead of 16v or 680uF 35v but everything I have is Panasonic FM/FR and Nichicon HM/HN
          later edit:
          Yeah, just looked at my last digikey order, I should still have:
          P12377-ND CAP ALUM 680UF 16V 20% RADIAL 0 0.36340
          P14443-ND CAP ALUM 680UF 35V 20% RADIAL 0 0.57300
          P12343-ND CAP ALUM 1500UF 6.3V 20% RADIAL 0 0.39360
          UHM0J152MPD6-ND CAP ALUM 1500UF 6.3V 20% RADIAL 0 0.41800
          P12388-ND CAP ALUM 470UF 25V 20% RADIAL 0 0.36340
          even later edit.. actually i guess if you really only need 1-2 of each and you can't find them there and can't use Paypal, I may take the 2-3$ loss and mail them to you for free... i like to do some good deeds from time to time.. let me know.
          • benja1475
            • May 2012
            • 26
            • Philippines
            I have a GF 8500gt VGA with one capacitor blown, i replace it with same value but not same brand, in other word ordinary capacitor from our local electronic store, the card display again but with garbage display...
            • c_hegge
              • Sep 2009
              • 5219
              Originally posted by benja1475
              ...ordinary capacitor from our local electronic store,...
              That could be your problem. the capacitor should be replaced with a very low ESR series, Like Rubycon MBZ, MHZ, or MCZ, Panasonic FL or FJ, Sanyo/Suncon WG, Nichicon HM, HN or HZ, or Samxon GD or GC.
              • cmlewis89
                LG 47LB5DF blown power supply board
                by cmlewis89
                Hi folks,
                I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                09-03-2024, 07:50 PM
              • drscoot
                HP X360 convertible battery blown fuse error, not charging
                by drscoot
                HP Modelnumber: 14-dh0061nb​
                This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                All these 3 batteries are charging...
                12-15-2023, 05:54 AM
              • swerg
                Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                by swerg
                Hey everyone,
                I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                06-06-2024, 03:39 PM
              • MrzPdlch
                Blown fuses on Gigabyte GTX 980TI 6GB
                by MrzPdlch
                Hey everyone,
                I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                Find some pictures of the actual GPU together with a picture of how it should look like.
                I also wonder whther it might be a problem that there...
                03-10-2024, 04:14 PM
              • cheeky2
                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                by cheeky2
                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                06-15-2025, 05:12 AM
