Sapphire Radeon X1300 Pro
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Got this card used and noticed that those 2 caps are starting to bulge a little...The card works fine (for now) but I'm wondering if this affects performance and how much longer it will function? The caps are G-Luxon
    Caps to the left of Radeon
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Sapphire Radeon X1300 Pro
    No one can really tell you that.
    But, can tell you when they do go they may no longer be the only problem.
    Series? Diameter?
    Mann-Made Global Warming.
    - Dr Seuss
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I ordered some Panasonic caps that I hope are compatible.
      The caps are 1500uF, 6.3V and it says 608B(M) and they are rated at 105*C
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        608B = date and/or batch code. [Guessing: that one is Aug 2006]
        (M) = tolerance for uF @ +/-20%
        Series code is two letters for G-Luxon. [Or a letter and a number but that's only one series.]
        - Dr Seuss
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          I bought some Panasonic caps that are the same uF, Voltage, Temp, and size (by mm) what are the chances that it won't work?
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            unlikely it won't work, if it works now
            keeep running it with bad caps it could blow the mosfets or damage the gpu
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              You need to meet or beat the ripple rating of the old caps if you want it to last.
              - Dr Seuss
              • c_hegge
                • Sep 2009
                • 5219
                do you know what series the pannies you got are? It's usually F__. You'd want FJ or FL for a graphics card. You may get away with FM, but hard to say.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  It says FL on them but I think I might have got jipped. It doesn't say Panasonic anywhere on the caps
                  • mariushm
                    • May 2011
                    • 3799
                    They usually don't say because Panasonic is owned by Matsushita (or whatever the spelling is). They're panasonic if the vent on top is a T with the - like a half circle and if they have a [M] or a M in a square somewhere...
                    Like in this picture: http://savedonthe.net/image/1058/Pan...C_47uF_35v.jpg (colors are a bit wrong though in this one due to flash but you get the idea)
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Sweet, they are just like you described! Thank you. I figured they might be fake because I got 4 of them for $2 and free shipping....darn good deal
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Recapped with Panasonic FL's I know it was only 2 caps but this was my first recap!!! The cap on the right is a Rubycon so I didn't replace it. Graphics card is working like a charm!
                        Yay for no more G-Luxon
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          did you get them on ebay?
                          (i hope not, ebay is full of fakes.)
                          sigpic
                          (Insert witty quote here)
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Yeah, I got them on ebay...
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              *glances at bag of FLs* They look genuine to me.
                              A working TV? How boring!
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Sweet i hope so...I have some in a bag if you want me to post them...
                                  AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                                  The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                                  10-01-2024, 12:46 PM
                                  AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                                  The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                                  10-01-2024, 01:07 PM
                                  AMD Radeon RX 470 / RX 580 Schematic & Board View
                                  The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                                  10-01-2024, 12:52 PM
                                  by momaka
                                  03-12-2025, 03:42 PM
                                • PeqNP
                                  Sapphire Radeon RX5700XT IR35217 configuration
                                  by PeqNP
                                  I have a faulty Sapphire Radeon RX5700XT with a short on the 3.3V PCIe rail. I was able to trace the short to the IR35217 which is responsible for managing VCore. The issue with these controllers is, that they need to be configured. I managed to get hold of a copy of PowIRCenter as well as a compatible USB flash device. What remains is, that I don't have the IR35217 configuration for that card. Does someone here own this card and can share this configuration? As this is a reference card design I would suspect that any other reference card would do the trick as well. The configuration...
                                  06-30-2022, 11:51 AM
