AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
    The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the product's target shader count. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. AMD has paired 4 GB GDDR5 memory with the Radeon R9 290, which are connected using a 512-bit memory interface. The GPU is operating at a frequency of 947 MHz, memory is running at 1250 MHz (5 Gbps effective).
    Being a dual-slot card, the AMD Radeon R9 290 draws power from 1x 6-pin + 1x 8-pin power connector, with power draw rated at 275 W maximum. Display outputs include: 2x DVI, 1x HDMI 1.4a, 1x DisplayPort 1.2. Radeon R9 290 is connected to the rest of the system using a PCI-Express 3.0 x16 interface. The card's dimensions are 275 mm x 109 mm x 36 mm, and it features a dual-slot cooling solution.
    The Radeon R9 390 was a performance-segment graphics card by AMD, launched on June 18th, 2015. Built on the 28 nm process, and based on the Grenada graphics processor, in its Grenada PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 390. The Grenada graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 390X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 390 to reach the product's target shader count. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. AMD has paired 8 GB GDDR5 memory with the Radeon R9 390, which are connected using a 512-bit memory interface. The GPU is operating at a frequency of 1000 MHz, memory is running at 1500 MHz (6 Gbps effective).
    Being a dual-slot card, the AMD Radeon R9 390 draws power from 1x 6-pin + 1x 8-pin power connector, with power draw rated at 275 W maximum. Display outputs include: 2x DVI, 1x HDMI 1.4a, 1x DisplayPort 1.2. Radeon R9 390 is connected to the rest of the system using a PCI-Express 3.0 x16 interface. The card's dimensions are 275 mm x 109 mm x 36 mm, and it features a dual-slot cooling solution.
    The Radeon R9 380 was a performance-segment graphics card by AMD, launched on June 18th, 2015. Built on the 28 nm process, and based on the Antigua graphics processor, in its Antigua PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 380. The Antigua graphics processor is a large chip with a die area of 366 mm² and 5,000 million transistors. Unlike the fully unlocked Radeon R9 380X, which uses the same GPU but has all 2048 shaders enabled, AMD has disabled some shading units on the Radeon R9 380 to reach the product's target shader count. It features 1792 shading units, 112 texture mapping units, and 32 ROPs. AMD has paired 2,048 MB GDDR5 memory with the Radeon R9 380, which are connected using a 256-bit memory interface. The GPU is operating at a frequency of 970 MHz, memory is running at 1375 MHz (5.5 Gbps effective).
    Being a dual-slot card, the AMD Radeon R9 380 draws power from 2x 6-pin power connectors, with power draw rated at 190 W maximum. Display outputs include: 2x DVI, 1x HDMI 1.4a, 1x DisplayPort 1.2. Radeon R9 380 is connected to the rest of the system using a PCI-Express 3.0 x16 interface. The card measures 221 mm in length, 111 mm in width, and features a dual-slot cooling solution.​
  • jomaxx
    • Jun 2025
    • Brasil
    i use this
    • Much Bugs
      • Apr 2025
      • 36
      • China
      Another BoardView Format( *.tvw ) of Gigabyte R9 390 :
        AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
        The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
        10-01-2024, 01:07 PM
        AMD Radeon RX 470 / RX 580 Schematic & Board View
        The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
        10-01-2024, 12:52 PM
        AMD Radeon R7 340 / R7 430 Schematic & Board View
        The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
        10-01-2024, 12:36 PM
        AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
        The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
        10-01-2024, 12:20 PM
        AMD Radeon RX 6800 XT (RX6800XT) Schematic & Board View
        The Radeon RX 6800 XT is a high-end graphics card by AMD, launched on October 28th, 2020. Built on the 7 nm process, and based on the Navi 21 graphics processor, in its Navi 21 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6800 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 21 graphics processor is a large chip with a die area of 520 mm² and 26,800...
        10-01-2024, 12:17 PM
