Asus Cusi-M doesnt post
  • wonder_step
    • Mar 2006
    • 27
    I had an Asus Cusi-M, when i turn it on the board powers up but suddenly it goes to standby and it doesnt post.... the fan wuld start spinning the it would turn off.....
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: help here plssss....
    can you give more information?
    did the board work good before?
    did it stop working when you changed something?
    did it stop posting one day but was working ok before that?
    do you have video or nothing?
    are there any beeps and if not did you wire up the speaker correctly.
    • wonder_step
      • Mar 2006
      • 27
      i cleaned the board because it was so dirty, i didnt changed any settings.... i don have video and the speaker is correctly wired.... i saw that the VRM chip is rusted....
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        so it was working before you cleaned it?
        it would be good if you could post a pic of the vrm chip and anything else that looks not normal on the board.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          How did you clean it? A regular vacuum cleaner is a really bad solution because it's motor creates allot of ESD, that could potentially damage components...
          • wonder_step
            • Mar 2006
            • 27
            i washed it with a soap solution.... ok ill take pictures and ill post it here....
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Err... did you rinse it? Dry it WELL? water hides under chipsets and stuff.
              Ludicrous gibs!
              • tiresias
                • Feb 2006
                • 489
                Your problems may not be washing-related, but as 'dood' said, water can certainly linger in a motherboard's less accessible places for some time after it's been washed.
                Locations which I've found particularly troublesome in this respect include:
                1. The CPU socket
                2. Under the larger BGA chips such as memory controllers (aka northbridge)
                3. At the bottom of expansion slots
                My current strategy involves ending the "cleaning procedure" by rinsing a board down with distilled water, drying as much as possible using tissues and a not-too-hot hairdryer, and blowing into, and under, the 'difficult places' mentioned with a compressed air can.
                PS: 4. Inside the cans of 'vented-open' GSC caps.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  LOL, add some WD40 and you probably have an electrolyte solution better than the one that was in there to begin with
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    It this was after putting a processor heatsink on, the processor likely got damaged. You likely cracked the processor core. Sorry.
                    Had the same symptom before back in 2002, because I rushed a heatsink and thus wasn't gentle enough with my newest processor! That was an Athlon T-bird 1.3 ghz 100 mhz FSB. That was when transfering the T-bird 1.3 to another motherboard.
                    After clipping on the heatsink, when I turned it on, after seeing the monitor light change, it went back to orange and there wasn't any bleeps. RIP T-bird 1.3 ghz!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      not so easy to crack a p3 core. scratched trace maybe but water seems most likely.
                      • wonder_step
                        • Mar 2006
                        • 27
                        well i made sure that the board is well dried....
                        i washed it then after that i let it dry up for 24 hours then i also made sure that its really dry by leaving the board dry up under the sun for 5 hours.....
                        the processor is good and doesnt have any damage....
                        • Rainbow
                          • Aug 2005
                          • 1374
                          Check the traces around CPU socket for damage. On some boards, they're easy to damage when removing/installing CPU heatsink.
                          • wonder_step
                            • Mar 2006
                            • 27
                            already checked the traces around cpu socket and theres no damage.... maybe its a bad chipset... or something...
                            • tiresias
                              • Feb 2006
                              • 489
                              By "goes into standby", do you mean that the PSU stays on, power still reaches the motherboard's components, but the board itself gives no signs of life whatsoever? No beeps? Do you have a port 80 diagnostics LED?
                              If that's the case, and you're sure the CPU is good... it will be difficult to narrow down the problem. It could be anything, from a corrupt BIOS to a loose pin, to a burnt trace somewhere, to any failed chip or other motherboard component.
                              • wonder_step
                                • Mar 2006
                                • 27
                                yep the psu stays on but there were no beeps and the only sign is the orange led at the female lan socket....
                                • Lance Thornton
                                  • Jan 2005
                                  • 84
                                  Re: Asus Cusi-M doesnt post
                                  No beeps at all is not a good sign. Try a port 80 POST card, they are usually relatively inexpensive. Also, when you initially washed the board, did you remove the CMOS battery before?, and how long did you wait until you replaced the battery?
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    If the motherboard isn't even bleeping at all, it's likely that the processor got damaged. Did you try another processor?
                                    Arc A770 16 GB
