I had an Asus Cusi-M, when i turn it on the board powers up but suddenly it goes to standby and it doesnt post.... the fan wuld start spinning the it would turn off.....
Asus Cusi-M doesnt post
Tags: None
Re: help here plssss....
can you give more information?
did the board work good before?
did it stop working when you changed something?
did it stop posting one day but was working ok before that?
do you have video or nothing?
are there any beeps and if not did you wire up the speaker correctly.Last edited by willawake; 03-13-2006, 09:25 AM. -
i cleaned the board because it was so dirty, i didnt changed any settings.... i don have video and the speaker is correctly wired.... i saw that the VRM chip is rusted....Comment
so it was working before you cleaned it?
it would be good if you could post a pic of the vrm chip and anything else that looks not normal on the board.Comment
How did you clean it? A regular vacuum cleaner is a really bad solution because it's motor creates allot of ESD, that could potentially damage components..."The one who says it cannot be done should never interrupt the one who is doing it."Comment
i washed it with a soap solution.... ok ill take pictures and ill post it here....Comment
Originally posted by wonder_stepi washed it with a soap solution.... ok ill take pictures and ill post it here....
Locations which I've found particularly troublesome in this respect include:
1. The CPU socket
2. Under the larger BGA chips such as memory controllers (aka northbridge)
3. At the bottom of expansion slots
My current strategy involves ending the "cleaning procedure" by rinsing a board down with distilled water, drying as much as possible using tissues and a not-too-hot hairdryer, and blowing into, and under, the 'difficult places' mentioned with a compressed air can.
PS: 4. Inside the cans of 'vented-open' GSC caps.Comment
Originally posted by tiresiasPS: 4. Inside the cans of 'vented-open' GSC caps."The one who says it cannot be done should never interrupt the one who is doing it."Comment
It this was after putting a processor heatsink on, the processor likely got damaged. You likely cracked the processor core. Sorry.
Had the same symptom before back in 2002, because I rushed a heatsink and thus wasn't gentle enough with my newest processor! That was an Athlon T-bird 1.3 ghz 100 mhz FSB. That was when transfering the T-bird 1.3 to another motherboard.
After clipping on the heatsink, when I turned it on, after seeing the monitor light change, it went back to orange and there wasn't any bleeps. RIP T-bird 1.3 ghz!ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
not so easy to crack a p3 core. scratched trace maybe but water seems most likely.Comment
well i made sure that the board is well dried....
i washed it then after that i let it dry up for 24 hours then i also made sure that its really dry by leaving the board dry up under the sun for 5 hours.....
the processor is good and doesnt have any damage....Comment
already checked the traces around cpu socket and theres no damage.... maybe its a bad chipset... or something...Comment
Originally posted by wonder_stepalready checked the traces around cpu socket and theres no damage.... maybe its a bad chipset... or something...
If that's the case, and you're sure the CPU is good... it will be difficult to narrow down the problem. It could be anything, from a corrupt BIOS to a loose pin, to a burnt trace somewhere, to any failed chip or other motherboard component.Last edited by tiresias; 03-28-2006, 01:21 PM.Comment
yep the psu stays on but there were no beeps and the only sign is the orange led at the female lan socket....Comment
Re: Asus Cusi-M doesnt post
No beeps at all is not a good sign. Try a port 80 POST card, they are usually relatively inexpensive. Also, when you initially washed the board, did you remove the CMOS battery before?, and how long did you wait until you replaced the battery?Comment
If the motherboard isn't even bleeping at all, it's likely that the processor got damaged. Did you try another processor?ASRock B550 PG Velocita
Arc A770 16 GB
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:00 AM
- Loading...
