skywell sht on dell/nvidia agp
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    they missed the i on this series!
  • gg1978
    • Dec 2004
    • 431
    Re: skywell sht on dell/nvidia agp
    Hahaha... Ironically, that's a Sanyo Oscon right by them. WTF were they thinking putting a good Sanyo on there with those skywell ones?? The "SHT" name on them sure is right though..
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      skywell polymers on the asus 6600gt
      • Chris1992
        • Apr 2005
        • 561
        At least my dell AGP card has SAnyo WG lytics. it, however has Skywell polymers ): getting a 6600 GT anywys once I have $$$ fro that and a PSU upgrade.
        The great capacitor showdown!
        • DixiePenguin
          • Mar 2008
          • 77
          • Philippines
          Hey,
          I just ran across this thread and wondered if it might offer a clue on my card problem. I have a GeForce 6600GT OC, fan powers on but no video signal. Tested on three systems. No visibly bad caps but it does have 2 Skywell SHT 330uf 16V caps. I thought I might try a repair but if not, it does have a very nice gpu cooler and chipset heatsink that would work elsewhere.
          Thanks,
          Bill
          • GL9!
            • Jan 2009
            • 6
            Skywell caps in Leadtek Winfast 6600GT
            One day i was running 3dmark03 just for fun, and the card freezes. Reboot the system and, haha! No image on the monitor. The card never comes back to life.
            In the image are almost seven skywell caps. Strangely, they have no vents :S so i cannot tell if they are ok.
            And, ironically, like the dell/nvidia agp, a Sanyo cap stands with them
            • AKACyrano
              • Jun 2009
              • 3
              New member here. Imagine my surprise to join the forum to ask about this same card. Mine is also out of a Dell, was able to ID it as Nvidia FX5200 with 128mb of ram.
              What would be a good replacement for these SHT caps and what would be a replacement as a poly?
              • linuxguru
                • Apr 2005
                • 1564
                Nippon Chemi-Con PS* for anything up to 16v (that's the highest voltage rating you're likely to find).
                • AKACyrano
                  • Jun 2009
                  • 3
                  Thanks for the reply. A fellow tech from where I work had a stash of caps from some motherboard repairs and I traded him a couple of cards for enough Hitano EXR of the correct spec to do two cards. Have done one and it is running like a top. Will probably add a fan to it so that it will run cooler.
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • piernov
                    NVidia bumpgate
                    by piernov
                    Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                    Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                    May complete this post at a later date with more details.
                    Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                    03-27-2021, 10:34 AM
                  • aaronkatrini
                    DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                    by aaronkatrini
                    I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                    - Put the card in my testing motherboard and start running Heaven benchmark
                    - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                    - Try to start it again and I get a slight move from the PSU fan - a clear short
                    - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                    - Put the...
                    05-18-2025, 04:18 PM
                    NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                    The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                    10-02-2024, 08:52 AM
                  • Akhlz001
                    by Akhlz001
                    09-20-2025, 07:15 PM
