Asus p3v4x:burn out ,check mosfet?
  • supersabre
    • Feb 2006
    • 45
    My friend just gave me a p3v4x that has a burn out component. The component is HIP 6013CB.
    I notice that the orginial power supply has couples of bulged capacitors, and it possibly causes both hip6013CB and one of the ram to fail.
    The mosfet looks good from the outside and I check all of the (rubycon and sanyo) cap using esr meter and all of them are good.
    Question: Before i replace the HIP 6013CB, do i have to check the mosfet?
    Anyone know how to check it?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Asus p3v4x:burn out ,check mosfet?
    That IC looks to be the voltage regulator IC. If that's cooked, I guarantee the FET's are also fried as well, and quite possibly the northbridge too. I'd say its time to lay that board to rest. If you do attempt to repair it though, definitely let us know how it comes out!!
    TC
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      agreed.
      i have fixed worse but its more often than not time to drop it in the hole and kick the dirt over it.
      • Newbie2
        • Sep 2005
        • 885
        That motherboard is an old Slot 1 motherboard. Do what kc8adu said, bury that motherboard in the ground. Thousands of years later, somebody digs it up and it goes to a museum.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • Chris1992
          • Apr 2005
          • 561
          come on, don't hate on the slot 1 boards. abit BE6 in a school comp has a p2-266. runs Word great and has a radeon 7000.
          The great capacitor showdown!
          • Rainbow
            • Aug 2005
            • 1374
            MOSFETs might be OK. I've replaced VRM controller on some boards and the MOSFETs were good on most of them. Easy check is "diode test" available on most multimeters - if MOSFET its bad, it has usually shorted all 3 terminals together.
            The VRM controller is usually powered from 12V and it's usually the first thing that goes bad when a spike on the 12V rail appears (and Super I/O is the first one for 5V rail...)
            The biggest problem with replacing these chips is to find the replacement part. The only source is an unrepairable board. The bad thing is that there is a lot of different VRM controller chips - so I have at least 4 boards laying here that need a replacement and some dead boards with good VRM chips but not the correct types.
            And remember: with slot-to-socket adapter, you can run 1GHz P3 there or even a Tualatin (with some work). Or just a cheap Celeron.
            • supersabre
              • Feb 2006
              • 45
              I have another good hip6013cb from the junk board, so i don't have to worry about the chip.
              However, i am not sure how to test the mosfet, do i have to remove the mosfet from the board for testing?
              Also, i want to ask Rainbow, is the following the way you test the mosfet using multimeter?
              ****MOSFET testing*****
              If you have a suitable digital multimeter you can use this for testing
              MOSFETS. The diode test on some multimeters puts about 3v across the device
              under test. This is enough to turn on most MOSFETs - at least partially.
              So: connect the meter negative to the MOSFET's source.
              Then touch the meter positive on to the gate.
              Now move the positive to the drain. You should get a low reading. The
              MOSFET's gate capacitance has been charged up by the meter and the device is
              turned on.
              With the meter positive still connected to the drain, touch a finger between
              source and gate. The gate will be discharged through the finger and the
              meter resistance should go high, indicating a non-conducting device.
              • Rainbow
                • Aug 2005
                • 1374
                That's almost exactly the test I'm using to check the MOSFETs when they're out of circuit (and I haven't read that anywhere, just found that by accident ). But it usually does not work in circuit. If the MOSFETs are visually OK, I don't desolder them, but do just a quick check instead - one lead to GATE and the other one to SOURCE (and then DRAIN) to check if they're not shorted. With shorted MOSFET, you usually get very low reading (zero in many cases) and thus a permanent beep.
                If you have the chip, then carefully replace it after checking the MOSFETs. If it goes OK, then the board should work fine, if nothing else was damaged by the PSU.
                • gg1978
                  • Dec 2004
                  • 431
                  And even if you can't fix the board by replacing the VRM controller chip, at least you can unsolder the caps from it. The caps from Asus boards of that era are well worth the time unsoldering them.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    if the fets are ok give it a try.
                    expect worse damage but you might get lucky.
                    i remember fixing a few asus boards in the slot 1 days.
                    most that got damaged like yours had a psu overshoot.
                    • larrymoencurly
                      • Oct 2004
                      • 960
                      I had a mobo where some caps bulged and the MOSFET next to them turned from black to purplish brown and had a gate shorted to drain-source. I replaced the MOSFET and caps, but the new MOSFET ran very hot, 100C even with a big heatsink. I later took it to my friend's house to borrow his scope, where I saw that the voltage regulator chip, which showed no physical damage, was turning on the MOSFET only partically.
                      • davmax
                        • Dec 2005
                        • 899
                        If changing the chip. Check the MOSFETs with the chip removed. Because the chip is most likely shorted it must be removed. Start with one test lead connected to the metal part of the MOSFET body then check the two terminals. There should be no short circuit, zero ohms.
                        160Gb WD SATAII Server grade
                        Nvidia 8500GT 256Mb
                        Samsung 18x DVD writer
                        33 way card reader
                        Windows XP Pro SP3
                        17" Benq FP737s LCD monitor
                        • davmax
                          • Dec 2005
                          • 899
                          Checking with the controller chip removed you will also be able to compare the condition of all MOSFETs. This will help pick a faulty one.
                          Nvidia 8500GT 256Mb
                          33 way card reader
                          Windows XP Pro SP3
                          • AppleLover123
                            Asus X712EA 3 volts after the first mosfet
                            by AppleLover123
                            Hey guys,
                            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                            Now i thought something...
                            12-15-2024, 07:49 AM
                          • Scotchmist
                            Asus GA502D keeps blowing mosfet
                            by Scotchmist
                            I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                            I have removed the mosfet and can run the laptop no problem
                            The MOSFET is FDPC5018SG
                            Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                            08-24-2024, 02:23 PM
                          • MicroSMD Lab
                            by MicroSMD Lab
                            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                            01-10-2024, 06:36 AM
                          • Chewy6288
                            Asus FA506QE missing MOSFET
                            by Chewy6288
                            I recently bought this laptop to try to fix up because it was so cheap. It has no power so I figured it was a MOSFET or cap issue so I started with taking it apart, but when I had it apart I noticed one of the MOSFETs was missing. I'm new to this so I don't know where or how to look up what to replace it with. I do have the boardview for it so I somewhat know what was there which I attached ,and the missing piece is PQ303....
                            07-30-2025, 07:24 AM
                          • Timp74
                            Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
                            by Timp74
                            Hi All,
                            Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
                            I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
                            08-13-2021, 01:11 PM
