Latest Epox Mother boards
  • davmax
    • Dec 2005
    • 899
    I have been using Epox boards for some time now. It is obvious they madea big mistake with caps. However their board layouts particularly in the VRM area are good and they perform well.
    Looking at their latest product offerings I noticed something odd. All Intel chip set boards use solid polymer caps around VRM. For AMD boards they still use wet electros that look very like Teapo. Why is this I wonder?
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
  • gg1978
    • Dec 2004
    • 431
    Re: Latest Epox Mother boards
    I haven't looked at buying any Epox boards in a while now.. I've got no less than 4 of them in my "recap" pile, that still work, but of course have leaky GSC caps. Funny the Teapo caps on these boards actually seem to still be good. I've got another 8RDA3+ on the way that i'm going to see if i can fix.
    As for why they would use solid polymer on the Intel boards, and standard low ESR electrolytics on the AMD boards, perhaps the fact that the AMD chips are less demanding on Vcore than the Intel ones?? I mean if you're talking AMD64 (either 754 or 939) versus the Prescott in either 478 or 775 pin format, the Prescott is much more of a scorcher than AMD64 chips are, and much more demanding of the Vcore VRM. My overclocked Athlon 64, even with 1.5Vcore, finds it rather hard to get the core temp over 50 C, and 50C is more like idle temp for the faster prescotts.
    Like i said in the other thread, the Sanyo Oscon's have more current available at typical operating temps. Presumably this would extend to other polymer caps, such as the yellow Fujitsu's, or any other manufacturer that makes polymer caps.
    • RJARRRPCGP
      • Jul 2004
      • 6301
      Intel processors usually are less demanding with the Vcore. Intel processors usually have a lower Vcore than AMD, AFAIK.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • linuxguru
        • Apr 2005
        • 1564
        Lower Vcore and higher active power consumption translates to much higher Icore. The ripple is also higher, put far higher stresses on VRM output capacitors than on AMD boards. So they're more demanding on VRM design, as the OP stated.
        • RJARRRPCGP
          • Jul 2004
          • 6301
          But the thing is, at message boards, people are able to OC Intels farther than AMDs at the same Vcore! Has anyone noticed that?
          Arc A770 16 GB
          • SpaceFrog
            • Apr 2006
            remember AMD's aren't clocked as high as intels, ie. an athlon 64 3000+ runs at 1.8ghz and is the equivalent of a P4 3ghz.
            So u will see more performance gain from a 400mhz overclock on a amd than a 400mhz overclock on a P4.
            • RJARRRPCGP
              • Jul 2004
              • 6301
              Have been seeing many 600 Mhz and a bit higher OCs with Intel being posted.
              Arc A770 16 GB
              • MD Willington
                • Sep 2004
                • 702
                I've seen the Epox boards with chemicon/sanyo in the VRM... I also noticed that only the high end AMD boards use digital VRM's...
                Even my biostar has OST, but not in the VRM, they are low uF ~ 35V type. Sanyo/Chemicon in the VRM
                This is what I have for an A64 mainboard... hopefully will be built soon.
                Ya'll think us folk from the country's real funny-like, dontcha?
                The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                • ugamazing
                  Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                  by ugamazing
                  I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                  We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                  12-17-2024, 07:05 PM
                • ugamazing
                  Apple M1 Boards & Exclamatory Error?
                  by ugamazing
                  We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
                  Has anyone else run into this...
                  02-20-2025, 09:24 AM
                • ugamazing
                  Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                  by ugamazing
                  I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                  08-31-2022, 07:34 AM
                • hopkok
                  Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
                  by hopkok
                  Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
                  3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
                  I checked for low resistance on coils, no low resistance.
                  Anyone with same issue like me?
                  Thanks for any help.
                  05-24-2025, 04:21 AM
                • midnightg35x
                  Panasonic TC-P65S2 SU or SD Boards Bad?
                  by midnightg35x
                  I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
                  04-22-2019, 05:29 PM
