BF6 Mosfets
  • Smiffy
    • Feb 2006
    • 16
    Re: BF6 Mosfets
    Hi All
    My Tualatin 1.3Ghz is on the BF6 with 1.50v at 1690Mhz.The mosfets now hot again as is the vcore controller chip(RC5058M)Although the Tualatin processor is quite cool easily cooled by a 1U coppper cooler.So the plan is to replace the remaining caps with 1500uf although I may try 2200uf as I already have some.Then see if the FDB7030Ls work.Then if so heatsink them and the controller chip and glue a fan to the back of the Friendtech FTK-Slot/Z to cool the whole lot.Its an old board accepted but a Tualatin running at 1.7Ghz is still a pretty good folding rig.
    Smiffy
    • Chris1992
      • Apr 2005
      • 561
      Re: BF6 Mosfets
      Also, it's still a great daily driver. Probably outperforms a P4 celeron 1.7GHz at 2040MHz.
      The great capacitor showdown!
      • Smiffy
        • Feb 2006
        • 16
        Re: BF6 Mosfets
        Hi All
        What about this fella.Not 100A but input capacitance roughly same as original
        https://cdn.badcaps-static.com/pdfs/...899b875b5e.pdf
        Ta
        Smiffy
        • davmax
          • Dec 2005
          • 899
          Re: BF6 Mosfets
          The Philips FET looks good. If your planning to buy. Make sure you get the correct packaging eg Dpak.
          Gigabyte EP45-DS3L Ultra Reliable (Power saver)
          Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
          160Gb WD SATAII Server grade
          Nvidia 8500GT 256Mb
          160Gb WD eSATAII Server grade for backup.
          Samsung 18x DVD writer
          Pioneer 16x DVD writer + 6x Dual layer
          33 way card reader
          Windows XP Pro SP3
          Thermaltake Matrix case with 430W Silent Power
          17" Benq FP737s LCD monitor
          HP Officejet Pro K5300 with refillable tanks
          • Smiffy
            • Feb 2006
            • 16
            Re: BF6 Mosfets
            Hi All
            Will do Davemax.Thanks for all the help
            Chris1992
            I sandrad it at 123Mhz fsb with cpu at 1605Mhz.Compared to my work mates P4 1.6Ghz on PC133 its better
            P4 1.6Ghz
            CPU 3971/2142
            MM 9636/12395
            MEM 726/725
            TUAL 1.6Ghz
            CPU 5578/2198
            MM 14038/16916
            MEM 848/890
            Smiffy
            • BlackScreen_22
              Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
              by BlackScreen_22
              Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
              Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
              I had no problems connecting mosfets and capacitors,...
              08-27-2024, 12:46 PM
            • kotel studios
              Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
              by kotel studios
              Finally got time to fix this board up.
              At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
              Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
              04-22-2025, 05:08 AM
            • flerre
              Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
              by flerre
              Hi!
              Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
              No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
              So, could I safely assume all of these 3 mosfets are...
              03-13-2022, 12:14 PM
            • NanoTesting
              Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
              by NanoTesting
              I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
              With charger it turns on, fan spins but gives no image.
              Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
              Reflashed BIOS, same problem.
              Replaced both main mosfets.
              Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
              10-30-2024, 10:48 PM
            • debruina
              Pioneer VSX-859RDS with all mosfets gone
              by debruina
              I am working on a pioneer VSX-859. It started with only one problem but i ended up with a lot more. Probably caused by me
              Anyway it started with a DSP NG message on the display. That one was easy and was caused by a bad 5v rail. Replaced the capacitors and the message was gone. Everything seems to be working except for a blob sound every time i switched from source. Eventually i tracked that down to a leaking battery on the analog board. Repaired some via's and lines and everything worked ok. That same circuit also caused a not working DCdetect protection. ...
              08-29-2023, 11:54 AM
