MSI K2N2 Delta 2 LSR
  • Louiscar
    • 31
    I didn't see this one here so adding it to the list. A socket motherboard around 5 years old. I cannot see any ID on the caps but they are a red / brown colour which resemble some of the pics in the hall of shame and marked as KZG.
    Currently I've about 5 of them bulging their little eye out. One to the left of the sim slot, two to the left of the CPU slot (closest to the cpu), two south of the cpu slot and all 2200uf 6.3V. The others all appear ok.
    On thing when looking at new caps and their lifetime rating is that I notice a lot are around 3000 hours. This doesn't seem a lot - I leave my computer running most of the time. In 24/7 terms that's only 4 months. Am I missing something here?
  • c_hegge
    • Sep 2009
    • 5219
    Re: MSI K2N2 Delta 2 LSR
    3000 hours is the endurance lifetime. ie. the expected lifetime IF they are run at 105*C, with their maximum ratd ripple and voltage. the lifteime doubles for every 10*C below the maximum temperature.
    Replace ALL Chemi-con KZG caps on the motherboard, since they are bad caps and often fail with no visible signs. These should be fine to replace them.
    • Louiscar
      • 31
      Originally posted by c_hegge
      3000 hours is the endurance lifetime. ie. the expected lifetime IF they are run at 105*C, .....
      Thanks for that explanation, I thought it was a bit short.
      I guess that's pretty much 90%. There are some small green caps which I can't ID, apart from that, they are all red/ brown ones.
      Thanks for the adivice. I'm not looking forward to this but it has to be done
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        These caps you can't ID.
        What are the numbers/letters on them?
        Do they have a logo that looks like a shield?
        Mann-Made Global Warming.
        - Dr Seuss
        • Louiscar
          • 31
          Unfortunately I can only see one side of the cap which simply shows M 105c, There are some numbers on the top though.
          Some bad pics taken just now, best I can do at the moment whilst it's running and poking a full size slr into the case.
          This green cap is on the right of the memory slots. There's one other which is situated in between the agp and first pci slot. Any numbers writing on this is hard up against the pci slot.
          As with the red / brown ones I don't see any manufacturer mark on any of them. I've assumed KGZ only because they look so similar to the ones in the hall of shame.
          2nd pic just shows the redish brown 2200uf cap on the left of the memory slots.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5045
            • US
            wow that kgz looks completly aired out
            last you knew did this board still boot up? not sure you should try powering it on till you get those larger kgzs replaced
            • Scenic
              o.O
              • Sep 2007
              • 2642
              what's with everyone calling them KGZ lately..? it's KZG
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Originally posted by scenic
                what's with everyone calling them kgz lately..? It's kzg
                OH SHiT! - DYSLEXIA IS CONTAGIOUS!
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Top numbers just date usually.
                  Green cap looks okay anyway.
                  - Dr Seuss
                  • Louiscar
                    • 31
                    It's in use right now, I'm writing this on it. I am worried about it of course but at the moment I've not a lot in the way of an alternative at the moment. Using just one GB memory it's so far stable but that can change fast of course.
                    Simple transposition - does it matter that much?
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Only if you care about not confusing newbies.
                      Most of the 'regulars' here do.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Using a board with vented caps can lead to all sorts of additional damage including completely blown chipsets and fire.
                        - Dr Seuss
                        • Louiscar
                          • 31
                          Yeah the other one looks ok. In fact lots of the other KZGs *look* ok but then unless I have them checked should I trust them to be within tolerance?
                          Frankly, I'm kind of thinking if I'm going to have to do thie myself I might have a better chance of a bootup if I change only the bad ones. The more I do the more chance I've got of screwing up. My soldering skills aren't bad per se but I am nervous about applying too much heat and damaging the tracks or near components.
                          It's the critical soldering I'm not that experienced at and one tv repairer I contacted was worried himself about doing it when I asked, saying the most difficult thing can be getting the old ones out.
                          • Louiscar
                            • 31
                            Point taken.
                            I know I'm taking a chance but I have to use the machine or build a new one. I can't afford to do that right now so trusting to luck and getting on the case asap is what I'm doing.
                            I will order the caps from here and hope they don't take too long to arrive. In the meantime mb permitting I'm going to have a bit of a backup session and get ready for the possiblity of never reviving this after my abusive soldering.
                            Life if full of risks. :-)
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Mobo's are thick. That's about the only thing that takes getting used to.
                              You will do more damage using too little heat than too much.
                              Not enough heat means you'll have the iron on the pad too long [waiting for the heat to get all the way through the board to melt the solder in the hole] which may cause the pad to separate from the board.
                              You want lots of heat to minimize the -time- the heat is applied.
                              Most people go with a 50-60 watt iron and a small chisel tip.
                              - Dr Seuss
                              • Louiscar
                                • 31
                                sorry double post - delete
                                • Louiscar
                                  • 31
                                  Ok. Yes I should have said 'worried about overheating'. I've understood a lower heat iron can result in overheating. Normally I've found my little 25w to be ok for most stuff, it tends to melt fast, however, do you think I should not even risk that?
                                  If I were to try it would I be safe in playing the 3 second rule, ie if it doesn't melt in that time, just stop and don't try again?
                                  If it means anything I have an 'ANTEX' iron with a 3mm chisel tip.
                                  This one in fact:
                                  http://www.maplin.co.uk/25w-solderin...c=so&u=strat15
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    A 25 watt would just be an exercise in frustration.
                                    There are a few members [that solder often] that do okay with 40 watt irons [and when I started doing mobos that's what I used too] but just going from 40 watt to 50 watt is like an order of magnitude easier. At least for me it was.
                                    If this is a one time thing you could go with a hong-kong-fly-apart el'cheapo from ebay or something but you may have to file the tip to get it small enough and that means you'll be cleaning and re-tinning it for almost every joint. [They won't stay clean with the base metal exposed.]
                                    If it's something you might do often there are several stations that work well.
                                    I like Hakko 926 or 936 but there are other good ones.
                                    - There are a couple fairly recent treads on the topic that should have everything you wanna know.
                                    - Dr Seuss
                                    • Louiscar
                                      • 31
                                      Thanks for the information. If I buy the same make (Antex) from Maplin they get really expensive for the 50w ones. I see they have a temp controlled 50w station which is about 2/3 of the price of the Antex on its own and they are doing an offer at the moment that halves the price. I may go with that although it's got a needle tip so I'll need to buy some extra tips.
                                      I think though that you've convinced me not to even attempt this with a 25w iron. I could try (in the safe way I mentioned above) just to see but given your info I think it may not be wise.
                                      Do you think this would be worth getting - might be better than the HK cheapo?
                                      http://www.maplin.co.uk/50w-solder-station-35016
                                      • seanc
                                        • Nov 2008
                                        • 1319
                                        These may be out of your price range, but in case you want a point of view...:
                                        I have the 60w Maplin digital LCD soldering station, think it cost me £60/70 2 years ago.
                                        It works OK. I've had to replace the iron because I destroyed the last one. Irons are about £10. The - (temp down) button is faulty it's not the actual button since I swapped it with the Celsius/Fahrenheit button. If you sit twiddling it for a few minutes, it starts working.
                                        I struggled when I was doing an iMac G5 board, but most other motherboards are a piece of cake.
                                        RS Components do an own brand 80w station for about £100, wouldn't recommend them, my 2nd one died under the same pretenses as the first - stopped heating. They both didn't last more than a few hours. Still got to RMA the second.
                                        Where in the UK are you?
                                          MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                        • Junkrepair
                                          Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                          by Junkrepair
                                          I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                          I found this nice little description of the conversion:
                                          Calculating capacitor ESR from Tan(delta)
                                          https://forum.digikey.com/t/calculat...-from-tan/2633
                                          It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                          06-12-2023, 02:45 PM
                                          MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 06:11 AM
                                          MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:50 AM
                                          MSI Delta 15 A5EFK-088NL Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Delta 15 A5EFK-088NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-088NL boardview and 15 A5EFK-088NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 04:30 AM
